Could a tiller direction be reversed?
   / Could a tiller direction be reversed? #11
I just spent some time looking at the Landpride tiller parts diagrams both reverse and normal. For the life of me I cannot see how they reverse direction. . I am attaching both gear boxes The RTR is the reverse drive.
I will look at my tiller tomorrow and see if there is anything obvious.
I don't think it is in the final chain drive on the end.
  • RTA gear box.pdf
  • RTR gear box.pdf
   / Could a tiller direction be reversed? #12
Landpride tillers all drive from the left side. RTA models are forward rotation, RTR models are reverse rotation. The parts breakdowns are available online. Peruse here:
Land Pride Rotary*Tillers
Edit: Clearly I type more slowly than Bob.
   / Could a tiller direction be reversed? #13
the output gear is driven on the front on one and on the back of the gear on the other.
   / Could a tiller direction be reversed? #14
If you take a right angle gearbox, and drive it to the left while sitting on the tractor, the tiller will till in the fwd direction, Flip the gearbox over, and the direction turns the opposite direction. So with a clockwise direction input shaft, the shaft to the left will cause the tined to till fwd. If the shaft drives to the right while sitting on the tractor, the shaft is still turning counter clock wise, and will drive the tiller shaft in reverse. Does that make sense?
   / Could a tiller direction be reversed? #15
Look at their videos.
   / Could a tiller direction be reversed? #16
Look at the RTR10, Page 40, shows the bull gear on the backside of the gear box, and this will allow them to have the shaft go to the left and still be reverse tilling.
   / Could a tiller direction be reversed? #17
Exactly what I have been trying to explain from the beginning. It's all in the setup of the right angle drive. There is no third shaft or gear.
   / Could a tiller direction be reversed? #18
How about this one?
   / Could a tiller direction be reversed? #20
I think I got it. On the drawing of the RTA gear box which shows the input drive shaft as 2 pieces the bevel gear is drawn reversed. It should point the other way and drive from the back side as stated by luscsmith a couple of posts back. The gear #12 would be assembled from the back side and then nut and cotter pin.
  • RTA gear box.pdf
2024 CRATOS ES-800 ELECTRIC DUMPER (A57192)
2024 CRATOS ES-800...
2012 Chevrolet Impala Sedan (A55853)
2012 Chevrolet...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
UNUSED FUTURE KH72 72" HYD 4N1 BUCKET (A57193)
UNUSED FUTURE KH72...
2013 Freightliner M2 106 Altec AA755 55ft Bucket Truck (A55852)
2013 Freightliner...
