3PT drift-down
/ 3PT drift-down #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Hey guys, I'm still finding out what's good/bad about the used Challenger MT285B I bought. One thing that's a PITA is the 3pt drifts down about 1/2 way when I pick up my landscape rake. I don't think it's a weight issue, it just drifts down to the 1/2 way point & stays there. If I take one of the thumb screws and slide it up to the point where the handle stays still, it's fine.
Seems like it's something to do with the handle mechanism itself-not staying in place?? Is there a broken spring or something?
Ideas?
/ 3PT drift-down #2
On the shaft where the position control lever rides, there are two nuts. Loosen the lock nut then tighten the other nut until the lever is snug but not too tight. Then tighten the lock nut down again.
These nuts hold tension on a spring on the outside of the lever.
I think that's the way your model is designed.
/ 3PT drift-down #3
Jerry, you're just the guy I was looking for. I figure if anyone would know what the problem is it would be you. :)
I recently replaced the FEL valve on my GC2300 and now the 3 point hitch doesn't have any power. With high enough RPM it will raise, but not with a load. The FEL operates perfectly and with the hose configuration, it will either work or it won't.
The loader is a MF2350 and the replacement valve is made by Brand Hydraulics. It is a monoblock loader valve with regeneration and is a 2-spool loader valve rated for 10 GPM and 4000 PSI, with adjustable relief preset at 2000 PSI. Spool actions are regeneration with spring-centering and 4th position float.
Thanks
/ 3PT drift-down #4
Carl,
I noticed on another thread that you replaced the valve. Why did you need to replace it?
/ 3PT drift-down #5
Hi Jerry, its been a while since we last communicated. I think the last time was when the avian flu was the biggest news. Now, it's swine.
Something happened with the original valve and it started sticking and leaking. It was cheaper to replace it than it was to repair it, especially with no guarantee that it wouldn't leak again.
/ 3PT drift-down #6
Thanks
Sounds like you have not hooked up the power beyond line that feeds the 3PH properly, OR did not install the PB sleeve in the new valve. You do have 7 hoses connected to the new valve right?
/ 3PT drift-down
Thanks, I'll try that first. :)
/ 3PT drift-down #8
Yes, there are 7 hoses connected. Six of them are on the top and one is on the side. Four of the top hoses are for the FEL, and one is connected to the top side marked "IN" and the other hose which runs all the way to the rear is on the side of the valve. There is plenty of fluid in the system and like I have previously stated, the FEL works as it should. There seems to only be 2 hoses that could be reversed, but the system works the same either way they are connected. My thought right now is to put the old valve back on to see if the 3 point system functions normally.
Thanks for your replies..
/ 3PT drift-down #9
Is THIS THE VALVE you used? IF so, did you purchase/install the PB kit shown in the upper right corner of the page?
EDIT-See, I just replied to your other post...This will get confusing fast! You/We need to keep the discussion to one post! This is a perfect example why posting the same question in multiple forums is a bad idea.
/ 3PT drift-down #10
I bought the valve from Northern Tools and it didn't mention the PB kit. In looking at the old valve, it has something that looks like that, but it has larger threads and wouldn't fit the new valve.
Brand Hydraulics Monoblock Loader Valve with Regeneration, Model# PLV22RFSTKAB | Control Valves | Northern Tool + Equipment
As far as for the other confusing posts, I haven't posted anywhere else except here since you mentioned it. I figure if you are going to try and help me out, I ought to at least try and make it less confusing.
/ 3PT drift-down #11
I an not sure how Northern sells that valve...but you NEED to have that PB sleeve installed. As I showed in that link-SC sells is separately.
/ 3PT drift-down #12
Thanks for your help Kenny, the valve has be ordered. Now I can resume my Hurricane Ike clean-up and repairs. Hopefully I can finish before the new season starts next month.
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
UNUSED INDUSTRIAS AMERICA C10 10' FEEDER TROUGH (A60430)
UNUSED INDUSTRIAS...
Case 580 Super K Backhoe (A61166)
Case 580 Super K...
2000 CATERPILLAR 988F WHEEL LOADER (A60429)
2000 CATERPILLAR...
Decorative Pelican Statue (A61569)
Decorative Pelican...
