Backhoe JD 4X20 with 485 Backhoe
/ JD 4X20 with 485 Backhoe #1
sunnyside360
Central PA
JD 3720, JD 4320, JD 835R, Kubota M4D-071, Kubota ZD1511
I understand a 485 BH is fairly easy to attach/unattach to 4X20 series tractor once all the accessories for it are installed.
Question, is it fairly easy to connect & run standard 3 PH attachments after unattaching the 485 BH. ie, is wrenching on/off parts required?
/ JD 4X20 with 485 Backhoe #2
no tools needed but you will have to re-install the 3 pt hitch arms.They have to be removed when putting on the BH.
/ JD 4X20 with 485 Backhoe #3
Yep... (look out!) :D 4-snap ring pins - (2) on the upper and lower 3pt arms and 2 spring clips for the sway links. Oh, and the drawbar; 1 pin. That's it!!! You've just installed the 3pt.
AKfish
Great news. I've got a 485 BH on order and it should be delivered, installed and ready for work within a couple of weeks. Yesterday, while attaching the rotary cutter, I thought uh-oh this may be much more involved after mounting all the BH hardware :confused:. I can sleep better now that you guys have set me straight :D.
Many thanks for the info.
QA Plate (A64912)
QA Plate (A64912)
1998 JD #8300 MFWD (A68191)
1998 JD #8300 MFWD...
SCHEDULE 80 PIPING ON PALLET (A67714)
SCHEDULE 80 PIPING...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
