Hauling a MF 135
/ Hauling a MF 135 #1
Sam in TN
Member
West TN
Was wondering if anyone could tell me if I could haul a Massey Ferguson 135 on a Uhaul auto transport trailer. I am unsure of the year of the tractor and am posting a pic in case it helps.
The weight of the tractor should not be a problem, I am just worried about the width. I can't find the trailers minimum width, only the maximum.
This is the info on the trailer:
Max load: 4,000 lbs
The vehicle being towed:
Must have a maximum outside-to-outside tire width of 75"
Must have a maximum wheelbase (distance from front axle to rear axle, usually posted on the driver's side door jamb) of 133 inches.
What do you all think?
/ Hauling a MF 135 #2
I would guess that the inside to inside on the places the wheels go is between 51 and 39 inches wide (making the ramps between 12 and 18 inches wide).
Aaron Z
/ Hauling a MF 135 #4
To put it all in proper perspective, a 135 is SMALLER (width and length) than most cars. You'll be fine as far as physical size. Weight might be an issue. I see U-Haul's specs say max weight of 4000lbs. A 135 will weigh in slightly more than 4000 and if the rear tires are fluid filled, quite a bit more than 4K.
I see the PAVT rear wheels..... (Power adjustable variable tread) In the position they appear to be in, you should probably expect 68" to 72" outside to outside on rear tire width.
/ Hauling a MF 135 #5
75 inches is 190 cm... Common trackwidths for the 135 were 135 or 150 cm, with 12.4-28 standard tires that gives you 10 to 25 cm to spare.
Given the spacing between mudguards and wheels, i assume its 150cm trackwidth and 12.4-28 rear tires. This tire size wont hold much water, so you wont be much overweight.
My 3011 is about the same size and weight and it towed fine behind my 850 TDI at around 110 km/h. I did use a 3.5 ton trailer with proper brakes and tires though.
/ Hauling a MF 135 #6
If you are OK with the weight the trailer should work.
Worst case would be you may have to adjust the wheel spacing on the tractor to load it.
Front and rear spacing can usually be set in range of 52" to 72" center top center, more or less.
Figure rear tire width will be approx 12".
I can't tell from the picture exactly how wheels are set, but you should be OK. Take some tools just in case.
/ Hauling a MF 135
Thanks for everyones input. I will be going to pick it up this weekend. Then I can run the serial number and figure out what year it is. All I know is it has a 3 cylinder Perkins engine, which I thought was strange for a gas burner.
/ Hauling a MF 135 #8
I seem to remember that on the gas versions MF had switched from the Continental 4-cyl to the Perkins 3-cyl and then back again to the Continental 4-cyl. The Perkins gas is likely derived from a diesel block. I don't remember hearing anything bad about the durability of the Perkins gas, just that they were not as fuel efficient as the Continental 4-cyl and didn't run quite as smoothly. Good luck with your new tractor.
/ Hauling a MF 135 #9
...As long as the Perkins gas is more durable than the Standard Diesel, he'd be o.k. with it...
The Standard IDI 4 cyl. Diesels were notorous for their poor starting and oil consumption. Short said, bad engines. In Europe the switch to Diesel fuel in tractors was much quicker than in North America, in Europe the switch from 10% diesels, 90% kerosene, to 10% kerosene, 90% diesel, happened within 5 years. Availability and price of both fuels also changed because of that.
After some dealers began replacing the gas engines with the industrial Perkins P3 engines, Frank Perkins offered a complete conversion kit (with other requirements like radiator hoses and correct flywheel)
In the used tractor market, the P3 conversions would become worth more than the factory Diesel with the Standard engine. There is some more about this story which i cant remember, but in the end, MF bought Perkins and the P3 conversion became a factory version.
I think in either the Beauvais, France or the Coventry, England factory, they still produced partially with Standard engines due to an agreement they couldnt just quit.
/ Hauling a MF 135 #10
Back when that tractor was new, Massey Ferguson owned Perkins. (Caterpillar owns Perkins now) The AD3-152 (diesel) was the most fuel efficient tractor engine of the day in ALL sizes. (Univ. of Nebraska test in MF150) MF used the Continental Z134 gasser in base model 135's and the Z145 in deluxe models. In the late 60's, MF decided to switch to an "in house" Perkins gasser that was derived from the diesel (designated AG3-152) It SHARED many parts with the gasser, including same block, crank, rods, pistons, bearings, oil pump, ect. MOST parts have common part #'s (gas vs diesel) I've been told that production demand for the diesels out stripped capabilities to produce BOTH versions. (Several OTHER brands of tractors were equipped with the AD3-152 also) So, the switch back to the Continental Z145. (The Z134 version was never re-introduced)
BOTH gassers are VERY reliable, VERY efficient, and neither holds a definitive advantage over the other. Resale is equal amongst the pair. Arguably the Continental is a BIT smoother at certain RPM's, but not so much as to be too noticable. Any shortcomings (perceived or otherwise) for the Perkins gasser are overlooked based on the STELLAR reputaion of the diesel version.
/ Hauling a MF 135 #11
There are very few gas tractors to be found in France, because of the very high price of gas (heavy taxes). We didn't have 3-cyl Perkins diesels either, the MF 35 produced in Beauvais in the fifties and sixties had 4-cyl Hotchkiss diesel engines built near Paris. The two I use are still going strong !
/ Hauling a MF 135
So would it be safe to say that this tractor has live pto?
/ Hauling a MF 135 #13
I don't think it would be safe to assume that. You see that Farmwithjunk refers to the deluxe and standard versions. As far a I understand it only the deluxe models had the live PTO, but I'm not 100% of the ones in the late 1960's. Maybe someone can tell you from the photo if it's the deluxe version.
/ Hauling a MF 135 #14
In Holland we never had any Hotchkiss engines in MF... i did hear of the name but never saw one in an MF.. The ones i had (35 built in Beauvais !) had the Standard 4 cylinder engine, which is also used in certain A-C models.
The 133 i had (Coventry built), was a later one with a Perkins A4-107
The TEF my brother had, was a Perkins P3 conversion.
In Holland the same thing as in France, gas prices were outrageous due to taxes and the roughly 50% higher consumption of the gassers.
They were only sold because of the poor starting of the Standard diesel. I know of one man who home drilled some glow plug holes into the heads.
When the P3 conversion was readily available, the conversions outcompeted both factory diesel and gas versions, and today, a p3 conversion, or a later factory version with Perkins engine, is worth double the price of a Standard diesel engined 35
original gas or fuel oil TEF tractors arent worth a sh*t. The unchanged TEFs are mostly wrecked for parts to keep the P3 conversions in running condition.
This leads to the conclusion that the P3 conversion, is generally accepted as an original classic tractor.
/ Hauling a MF 135
Just wanted to clpse out this post with a big thanks for everyones help. I got the tractor home this evening, she fit perfectly on the uhaul auto transport trailer. Will be starting a new post shortly in the proper forum to get some suggestions on getting this old girl back up to speed. Thanks again.
/ Hauling a MF 135 #16
Glad it all went well and you and the new lady are safe at home!
Chris
/ Hauling a MF 135 #17
With a proper block heater, glow plugs and even a thermal blanket, and the 23c will not let you down.....Ours NEVER did!! We are in the process of a MF 35 resto with a Perkins conversion, and the only reason for the conversion is the lack of injector lines and other parts, other wise the 23c would be staying.
/ Hauling a MF 135 #18
Dad has a MF Industrial 30 with a Perkins diesel (~50hp IIRC) and as long as you plug in the block heater an hour before you want to use the tractor and store the battery inside (or keep it charging, the alternator doesn't work on his tractor) it will start in any weather.
Aaron Z
/ Hauling a MF 135 #19
When i was 13, i got a 133 for my birthday as a "project"
It had a frost cracked head so it hadnt ran for a while. We tried to crank it on the PTO with our 4712 but didnt check the oil. Someone also drained the oil. Result was seized engine.
Then my brothers bought 2 35's of a guy who just got married and didnt have time to finish the restoration. The engines were just thrown into bins, no one knows which pushrod belongs to what rocker, and what piston is seated to what set of rings and what liner.
I didnt have that much time and experience either, and my brother didnt have time to help, so in the end, when i was 16 we turned them all into scrap.
I could have supplied a lot of engine parts but we scrapped them 10 years ago...
Right now i have my 3011 as a project, i rebuilt the transmission 2 winters ago, i'm going to do a head job soon. I'm not sure if i'm going to restore the original mudguards, or will order some cheap Ursus C-360 mudguards which are still available and fit Zetors too because the design was handed over to Ursus...
I wont take a non-runner as a project anymore, but something i can do in stages, and put to use inbetween...
By the way, most injector lines can be made from universal parts. If you use brake lines it might be a good idea to replace all 4 so you cant get any difference in injection delay per cylinder. However the roughly 70 bar injection pressure of a Ricardo swirl chamber system, the injection lines dont deform much due to the injection pressure.
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
2007 International 4300 Bucket Truck 55' (A62613)
2007 International...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2012 Caterpillar CB54 Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2012 Caterpillar...
