JD 1050 2 stage (PTO Clutch stuck)
   / JD 1050 2 stage (PTO Clutch stuck) #11
Are you in for a shock, I have the clutch set for my 850 in my JD shopping basket just to check the price $2538.80 not includind the bearings. I watched it go up over the 5 years thats riduculous for a clutch. here is the line item.
AM878710 CLUTCH, COMPLETE DUAL 850,950,1050 ADD 2,538.80 USD 2,538.80 USD
   / JD 1050 2 stage (PTO Clutch stuck) #12
Whoa... that's not even reasonable... WTH..? :confused: With some luck, there might be an "aftermarket" kit and you won't have to buy a new kit from "mother Deere".
   / JD 1050 2 stage (PTO Clutch stuck) #13
I told my neighbor if the clutch goes so does the tractor. There was a someone on e-bay with remanufactured clutches, the price was not too bad I saw it on the 850 listing.
Here's my plan, split the tractor, dis-assemble the clutch, measure the wear disc's, inspect the pressure plates for flatness and overheating etc, and if I can get by with just a trans disc that's what I will do. (Given what it looks like now, I think that is were I'm headed) I have a local dealer that specializes in clutch work and I have had great luck getting clutch discs for a number of vehicles, trucks, tractors etc at VERY reasonable prices (parts only). So that's my initial plan.
Greasy Fingers
   / JD 1050 2 stage (PTO Clutch stuck) #15
A couple of suggestions - 1.) New throwout bearing. Cheap and one of those things that can/do wear out before the rest of the clutch/pressure plate assembly.
2.) See if your transmission shop can resurface the pressure plates (oh yah, the flywheel, too). Likely be some warpage and maybe even a "blue spot" or two. If there is; the new clutch discs will grab and you'll have uneven wearing and a shorter clutch life.
Good luck and let us know how everything works out.
AKfish
   / JD 1050 2 stage (PTO Clutch stuck) #16
50 Series John Deere CUT's had issues with the clutches sticking after non usage periods. As there have been enough comments on "how to attempt to unstick them, I won't add anything new there.
What I can recommend is during long non use periods, depress the clutch pedal and retain it there, otherwise the same problem will reoccur.
When JD went to the 70 Series they corrected the problem and vented the bell housing.
   / JD 1050 2 stage (PTO Clutch stuck) #17
Did you get this problem solved? I have a 1050 with the same problem.
   / JD 1050 2 stage (PTO Clutch stuck) #18
Potential options:
Discount Tractor Parts and Manuals for Older and Antique Tractors
Clutch Kit - Tru-Power Clutch kit. DUAL CLUTCH. Contains NEW : Clutch 9in. pressure plate assy (19 spline-36mm 6-pad), Heavy-duty 9in. disc (13 spline-25mm hub, woven disc) release bearing, pilot bearing. Fits: 850, 870 (s\n 016000 & up), 900HC (w\yanmar diesel), 970, 1050, 1070. (Part No: AM878710K) $1097.62
Release Bearing - Used with (Dual clutch), 2.164" I.D., 3.450" O.D., .765" Thickness. For Models: 670, 770, 790, 850, 870, 950, 970, 1050, 1070. (Part No: CH13099) $42.62
john deere 850, 950,1050, 870, 970, 1070 tractor clutch - eBay (item 190360056170 end time Dec-29-09 12:24:22 PST)
This is a rebuildt 9" dual stage transmission disc only for John Deere compact tractor $150
models 850, 950, 1050, 870, 970, 1070, 900hc, 990
1 3/8"19 spline woven tranamission disc
pad style disc also available $175.00
The dual stage pressure plate is also available $625.00 NOTE: this clutch may have a solid center disc instead of spring center
(send your clutch to me first and I will rebuild yours for $450.00)
This clutch is preset
pto disc available $100.00
release bearing $35.00
pilot bearing $10.00
I will buy the pressure plate core back for $80.00 and pay $20.00 towards the freight to ship the core back
   / JD 1050 2 stage (PTO Clutch stuck) #19
Any update on the 1050 clutch repair?
New member has a clutch question.
   / JD 1050 2 stage (PTO Clutch stuck) #20
Hi All, I had a JD2510 with a dual stage clutch and yes it was froze, After trying to free it from below thru acess hole I pulled the starter and there was a balance hole in the flywheel about .75" and I could see the clutch plate so I tapped it a couple of time with a screw driver being careful not to damage it and bingo she came loose. I did try all the other ways mentioned, rocking , pulling but nothing worked. Only pulling the starter. Hope this helps others. Yes I let it slip alittle later to polish off the rust. Works great now.
54in Loader Fork Attachment (A59228)
54in Loader Fork...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
1980 Gleaner F2 with heads (A56436)
1980 Gleaner F2...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
TANK MANIFOLD (A58214)
*Selling at Royal Auction Tampa, FL Location* 9, gooseneck hitch, (A59230)
*Selling at Royal...
