CDP BACKHOE BUILD
/ CDP BACKHOE BUILD #21
This is off subject but what hole saws do you guys recommend for boring in steel?
I have used high dollar and low dollar saws with pretty equal success.
While the high dollar saws are usually constructed better, a decent low dollar saw will work, providing: Slow the speed down and use cutting fluid!
/ CDP BACKHOE BUILD #22
Same here, I have bought Black and Decker, which were very good BTW, Morse, Rigid and Milwaukee and they have all been good. Slow and cool is the key to longevity. In fact, I am still using the B&D bits (I've never had to resharpen after hundreds of holes) and arbors and just replaced the saws.
/ CDP BACKHOE BUILD
Just about 2 weekends lost on other responsiblities than the backhoe work.
1 item or say tool which does not get to be taked about much in discussions about building a backhoe and for that matter is a sturdy level welding table. So I had to spend a good deal of spare time fabbing a table, which unfortunately I have not completed. (need to get 3/8 inch plate for top)
I also spent a great deal of time grinding and cleaning boom and dipper arms. Progress is slow, but I need to be patient, do good fit up and resource economical material ( ie: plate for table top, $270 cdn, for sheet 4 x 8 , wow). I included some pics.
/ CDP BACKHOE BUILD
Made some progress lately on my project. First the table is finished. 2nd the bucket is done except for one bushing. Tacked up the boom, and aligned the cylinder plates. I'll weld it up when I am sure that the fit and movement with the swing piece is correct. Started to put together the frame and swing part. Progress is slow as family and work commitments have taken up most of the free time. I only hope is that I will finish the hoe in time to dig my water entrance.
/ CDP BACKHOE BUILD #25
SLOWMANDOWN
Is this going to be attached to a tractor, or tow behind with the engine and hydraulics.
I built mine to attach to the front of my Power-Trac.
/ CDP BACKHOE BUILD
It will have a seperate power source which will be on axle and rims which can be towed. But I'm building it so it may also can be attached to my 3 pt hitch on my tractor.
/ CDP BACKHOE BUILD
J_J I do not see the swing cylinder. Does your hoe swing, or is it fixed positioned.
/ CDP BACKHOE BUILD #28
The fronthoe is not finished yet, It is advertised for 160 degrees swing, and I am trying to figure out a way to go 180 degrees. I am thinking about a chain on the bottom rotated by a hyd cylinder. I also added some more length to each arm, and I have several buckets plus a grapple. One day soon maybe. Do you have your joystick valves yet? Both surplus Hydraulics, and Baileynet.com have some good deals on the joystick, with PB.
What you have done so far, is looking good.
/ CDP BACKHOE BUILD
No. I am starting to price the valves now. I will check the web sites you suggest today. Keep in mind that the prices will be converted to Canadian dollars and depending on the exchange rate might increase substanially. I am still looking at using a 2 stage pump as I have one lying around, rather than buying a 4-5 GPM pump. I believe that you can by pass the low pressure section of the pump and only use the hi-pressure section. Not sure how that is done.
/ CDP BACKHOE BUILD
I have a question on the frame. Between the upper and lower plates of the swing part which connects to the frame it is left hollow and open. Should this not be boxed in and strenghten some how. My idea was to turn the tube I placed for trial fit and see on end and cut to size weld in place. That way there will be more support and be box in so muck does not accumulate. Or is there a reason that this area needs to be left hollow. I am thinking to order this valve (see attached). Will this work.
  • Directional Control Valves 220-951 Detailed Information.pdf
/ CDP BACKHOE BUILD #31
That looks like a nice valve, I wished they would of had them when I ordered mine duel joystick valve.
I believe my assembly is boxed in. I will take a look when I get a chance.
/ CDP BACKHOE BUILD
Thanks for the response J_J. I believe it will work fine as well. I have been told that it is not very advisable to run a 2 stage pump even if the low pressure section is by-passed. So looks like I will order the pump as well.
/ CDP BACKHOE BUILD #33
Thanks for the link to the valve.
I am building a backhoe and plan on, at least hope to, use the tractors hydraulics. I was considering the Salami valve but was curious about the Chief. Anyway, the specs did not mention or I didn't see any referrence to open or closed center so I called them. I was told it is a "Tandem center" a term I was unfamiliar with so after a number of internet searches I believe the tandem is the same as open with the added benefit of blocking certain ports when in the neutral position so the cylinder remains locked where you left it. Anyway, now I'm leaning toward your selection.
Thanks-
/ CDP BACKHOE BUILD #34
I looked at my machine, and it is not boxed in, looks like yours. Perhaps they thought to run the hydraulic hose through the tunnels.
/ CDP BACKHOE BUILD #35
To bend the back plate for your bucket. If you have a hydraulic press you could turn that into a small press break. Weld some 2" angle to a plate to create a valley and set the plate on it put some bar stock on top of the plate and press. move a few inches and repeat. This can get you close. I have a 20 ton HF press and this worked for 1/4" plate 14" wide.
Good Luck
Phil
Brilliant, thanks,
Joel
/ CDP BACKHOE BUILD
I am putting together the pivot and swing assembly and am a little confused about the bushing placement. Should they be flat to the plates of the pivot or slightly pertruding to keep the swing assembly from dragging and possibly getting caught up. If I weld flush to the inside top and bottom of the pivot plates then I will need to get some shims to space the pivot centered inbetween the plates. I could use your suggestions and help. A picture would be nice!:confused:
/ CDP BACKHOE BUILD #37
Here is a picture, am I nice or what? The boom is flat so it will ride against the flat surface of the receiver. If you put a protrusion on the outside of the boom, it would eventually eat a hole in the side plates. Besides that, the receiver is built to take a 4 x 4 box steel. Is your wall thickness 3/16, or i/4 in?
Do you have the complete plans for the BH? A picture would be nice, but not necessary. Mine is somewhere else right now,
/ CDP BACKHOE BUILD
Yah you nice. Thanx. I can see that I will need to put some brass shims apporimately .060 to .100 " on the swing assembly as I had mine milled parallel and flat. Thanx again for the pic. My plans ask for 3x3 tubing for the boom.The sleeve /bushings will pertrude by approx. 1/4". I can see that 6this might create a problem?! I will verify the plans but I'm sure they ask for 3x3.
/ CDP BACKHOE BUILD #40
j-j just a note about 10 yrs ago I rented a backhoe from a rental house that was about the size of a bota bcx 23 but it used a double chain wrapped around the boom mount to rotate it,not sure if the backhoe was wore out or poorly maintained but was hard to control ie: slammed into the lp tank and the renters prized roundy round car) adjusted chain tension, but then it started to bind and bent top pin in pivot assembly, I replaced the pin since I fiddled with kinda my fault until I discovered someone had used a hot rolled steel rod instead of a hardened pin, anyway never was able to get rid of the excessive play in the swing, not my machine I should have left well enough alone, after that I built my own towable backhoe, their maintennance man thanked me for fixing it :mad: lesson learned, but I was taught to returned items in same conditon or better than when I borrowed them;)
2016 Ford F-150 Pickup Truck, VIN # 1FTEW1EG0GKE69622 (A65563)
2016 Ford F-150...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
Allis Chalmers 1200 Field Cultivator (A66408)
Allis Chalmers...
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59910)
2017 FREIGHTLINER...
Lesco 50Lb Push Spreader (A64557)
Lesco 50Lb Push...
