Trailer Wiring
/ Trailer Wiring #1
JB4310
Super Member
Central CT
J.D. 4310 E-hydro
I will start a new thread here so not to hijack "brake controller" thread.
First of all I don't have any problems with either of my trailers, a 5 ton dumper and a 20 foot equipment trailer.
But with all this talk about trailer brakes and wiring etc I started looking how mine worked, I know, if it ain't broke don't fix it.
Anyway it started with the break away battery system on the equipment trailer, as far as I can tell mine does not get charged, next time it's hooked up I'll check the voltage to see if it's higher than 12 volt when the truck is connected and running, indicating it is indeed getting charged.
The reason I don't think it is, is because there is only one black wire coming off the battery and I'm pretty sure it goes straight to the break away switch, so how could it get charged?
Next is while trying to figure that out I was checking the 7 pin connectors, trying to determine where power could come from.
So this is the weird part, kind of a question and kind of just a statement. While checking my trucks 7 pin outlet I find I'm getting voltage from almost all the terminals except the running light blade at the 11 o'clock position and the ground.
Specifically as follows:
with key off, actually no key in ignition.
terminal at the 1 o'clock position, bat+ = 12.9 volts
term @ 3 o'clock, RT turn/stop light 8.9
term @ 5 o'clock, elect brakes 11.3
term @ 7 o'clock, ground 0
term @ 9 o'clock, left turn/stop light 1.3
term @ 11 o'clock, running lights .1
center terminal 3.9
with truck idling. but no lights on or brakes pressed.
term 1 o'c 14 volts
term 3 o'c 2.5
term 5 o'c 12.1
term 7 o'c 0
term 9 o'c .6
term 11 o'c .3
center term 3.9
Am I crazy, stupid or just unqualified to operate a multi meter?
How is this possible, like I said everything works the way it's supposed to, used both trailers this week lights and brakes work flawlessly. how could there be voltage at those terminals with nothing on especially the brake circuit? the only one that makes sense is the hot term reading of 12.9 with truck off and 14 when running.
I have the Drawtite Activator 2 controller.
ANY IDEAS ???
JB.
/ Trailer Wiring #2
You should have zero volts with the key off and with the truck running you should only have voltage on the term at 1 o clock. You have to have a bad connector somewhere on your truck. I would look at all the connections under the truck where they are in the weather. I would also take apart the 7 pin female plug on the back of the truck and look for water or a short.
You say everything is ok, but its not. Say you had a boat and left the trailer hooked up for 2 or 3 days why you took a trip. When you got back to the boat ramp to start the truck you would have a dead battery due to the drain on the system.
Chris
/ Trailer Wiring #3
I agree with everything Chris said except the voltage at 1 oclock might well be the battery voltage with the vehicle off. I think it is common to run a wire directly from battery positive to the pin at 1 oclock.
You definitely have a problem, not the least of which is that your trailer brakes are full on all the time. I'd pull your drums to see if there's anything left of the brake shoes. I would start by pulling the 7 pin apart, could be water and corrosion, or a single loose strand of copper wire is acting like fur, touching some of the connectors and carrying a slight current. I've also had insects make little nests in there and when they get wet they act like a sponge and short everything out.
/ Trailer Wiring #4
Mark and others, it is fine to do it that way but the problem is as the battery on the trailer drains it will pull down your tow vehicles battery if not running. It will not be a problem except if you were using a travel trailer or something similar it is possible to get in a situation where the tow vehicle will not start, like camping overnight with it still hitched up. Even a dump trailer hitched up the night before a big job may drain the trucks battery enough to not start in the morning.
Most factory installs and good aftermarket installs run it though a relay that allows it to only be hot with the tow vehicles key on or running. Prevents the above situation from happening. Trust me, it happens. My neighbor had a camper that stayed at a a remote property for a year. When they got there to take it home they hitched it up then spent the day having one last visit and cleaning up the site. When they went to start the truck and guess what. I got called out to drive 45 miles each way to jump start the truck. It was a 96 Dodge wired hot all the time and my guess as to what happened is the battery on the trailer was low and pulled a charge off the trucks battery. Got them both so low it would not start.
Chris
/ Trailer Wiring
Chris
It' crazy! when I say everything works flawlessly I mean it, brakes work perfectly, I dial them in as needed for different loads, lights all work normally. Truck is an 07 Dodge 3500, wiring was done by a top notch body up-fitter shop when I got my utility body installed.
I don't want to start taking stuff apart to fix some phantom problem, I know it doesn't make any sense, I even tried 2 meters my old analog and my new digital, it is bothering me, what if I was trying to diagnose a problem and I'd be getting all these whacking voltage readings, what could I be doing wrong? to do the testing I am using the ground blade in the socket for ground connection.
Unless I shorted something out doing all this poking around, haven't had the trailer on since I started doing the testing. or when the trailer plug is plugged in it straightens it all out???
Any other ideas, even unconventional ones.
JB.
/ Trailer Wiring #6
I really think you have moisture in one of the connectors the truck bed people had apart. They probably used the factory end then connected something they made up to it to get the lights on the bed to work. I am guessing the problem is there. Basically a lack of dielectric grease or a shorted pin.
Chris
/ Trailer Wiring #7
If I remember correctly, my controller sends a low apmerage current through the brake terminal and it is used to detect when the trailer is connected.
Russell
/ Trailer Wiring #8
On some new solid state equipment they might have some voltage on it even with it off. maybe they are using solid state in the vehicles?
A while a go we had a new apprentice at work had a similar problem with a solid state relay he put a meter on output and he was jumping around that out put was on and the light was off on the relay that the relay was bad I walked over with my wiggy and there wasn't any voltage on it.
He put his meter on with my wiggy and it read 0 he was confused I explained that there wasen't enough load on his meter to load the out put right.
I got a lamp and put it on and it didn't glow till we turned on relay
tom
/ Trailer Wiring #10
JB.
Hate to say it.. but maybee.. as you mentioned in the first message.. you are unqualified to run that meter. ;)
what's a testlamp show you on those pins..
soundguy
/ Trailer Wiring #11
That's why i like the breakaway kits that use a charger module on the battery.. lil bit of logic in there knows when the truck is running or not by compairing stating bat voltage to alternator ( charge ) voltage.
soundguy
Chris
/ Trailer Wiring
soundguy
I was trying to be humble :) but no I'm not an electronic whiz by any stretch.
I do know basic wiring ac/dc I know how to check for shorts, open, ground, continuity voltage etc. I don't have a very good grasp of resistance and current, ok I never use that side of the meter :eek:
So are you guys saying I could have voltage readings but no current?
I will check it with my light, My meter is a decent RS unit. I lock the range hold so the decimal isn't floating, so that's not confusing me.
This truck does have a monster size ECM mounted on the side of the engine block, don't know if this wiring is controlled by it but I suspect it, I had a cargo light (up by the high stop light) that was mistakenly deleted from the truck order, even though the light is there the wires are there and the switch is there, the dealer told me there's no way to get it to work cause the ECM was programed VIN specific.
It was told there was not to be a cargo light so now there is no cargo light. they can turn it on with the OBD tester but not program it to work with the switch.
JB.
/ Trailer Wiring #13
I think maybe you are using the meter ok, but not getting a good ground when using it. I have seen funny stuff like that before.
Yes, you can have voltage but no current; that is an open circuit. If you have nothing connected to the truck, and are reading voltages at the 7 wire connector, you have an open circuit.
Make sure the meter is all the way to DC voltage. Sometimes I do not pay attention, and only switch to AC voltage; that will throw you off. I have 25 years of high tech electronics lab experience. I still get in a hurry and don't turn the knob to exactly where it should be.
/ Trailer Wiring #14
I like this site for 6 and 7 wiring diagrams.
Marksrv.com 7 way wiring diagram page
I like that they show the numbering for the connectors. I have seen the connectrs mounted upside down, and also at 90 degrees. Makes debug hard when referred to as 1 oclock, 3 oclock ect. All the 7 wire connectors/plugs/receptacles I have bought in the past had the numbers on them.
center terminal 3.9
term 1 o'c 14 volts
term 3 o'c 2.5
term 5 o'c 12.1
term 7 o'c 0
term 9 o'c .6
term 11 o'c .3
center term 3.9
/ Trailer Wiring #15
Ditto what robert said.
I wasn't kicking you.. it's just that there are some electrical nuances that the average meter 'owner' aren't familiar with.. that's why I sugested a test lamp.. it's an easier go/no go test since it is much lower impeadance than the imput to that vom.. which will be many thousands of ohms.. and could show open circuit voltages that , when in circuit and loaded, simply wouldn't be present.. or would / could be quiescent leakage current.. etc..
soundguy
/ Trailer Wiring #16
I find myself using the little red light tester more often than my volt meter when wiring trailers. Just a lot easier for me to handle, has the nice sharp point to test wires anywhere without hooking up and unhooking up.
The test light works good for me and keeps things simple.
I think electrical is much more complicated than the layman (which I'm one of us) could ever imagine.
A good friend of mine is a master electrician, been one for 20 years, works on the big 1000 volt plus DC stuff in the tunnels for subways and the like, and to this day when I ask him a question about just how electricity works he'll say, you know, not many of us even totaly understand just how it works.
Joel
/ Trailer Wiring #17
Newer vehicles can feed back. When my S-10 shorted at the cigarette lighter the dome lamp had voltage coming from both sides. Thanks to a burned out brake lamp & a blown fuse. Computers multplex things so you couid have other issues.
Three summers of inspecting tractor tailers during, I was taught to never use the ground inside the plug. Always use an independent spot on the chassis...
Test lamps work well. Just never puncture wires with the sharp point. the tiny hole allows moisture to enter the wire & the resulting corrosion will wick along inside the insulation making problems.
/ Trailer Wiring #18
I have added extra ground wires on qd ends to all my trailers 'just because'
soundguy
/ Trailer Wiring #19
Thanks for the point on puncturing the wires, been guilty of that.
Joel
/ Trailer Wiring #20
electrical theory is fun, and frustrating.
past a 'layman' and basic use level for ac/dc stuff like 12v elec system and 120/240v single phase AC, which ain't all too bad... it turns into one of those things that you either really like it and get into the 'deep end' or you don't like it and stay in the shallow end.
soundguy
Joel
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
2020 CATERPILLAR D6 LGP HIGH TRACK CRAWLER DOZER (A62129)
2020 CATERPILLAR...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2018 ADDCO ROAD SIGN DH1000-ALS (A60736)
2018 ADDCO ROAD...
New/Unused CFG Industrial QK18R Mini Excavator (A61166)
New/Unused CFG...
