smoke signals
/ smoke signals #1
peejay
missouri
Yanmar YM220D
my ym220d started smoking and knocking and then lost all power. my thought is to 1) put a new engine in it or 2) rebuild this one. does anyone have a resource for either a reeplacement engine or an overhaul kit for a 3T75HA engine?
/ smoke signals #2
Any idea what happened to it? Overheat? Lost oil pressure?
/ smoke signals
lost oil pressure. temp guage is not connected, but didnt seem too hot. its an old tractor that has been used hard by the previous 2 owners with not much maintenance. im steady fixing things on it. soon everything will be replaced and it will quit breaking down, right? ha.
/ smoke signals #4
I'd tear it down and see how bad it is before looking a new engine. The dealers on here have a good supply of parts for just about all of the little tractors it seems. I'd bet even if you have to have the crank turned and replace pistons, rings,liners and gaskets you'll come out a lot cheaper.
/ smoke signals
i suppose i need to get a shop manual then. any good source for one in english?
/ smoke signals #7
#1 is not an option since new/rebuilt engines are not available anymore. Option 2 is a very good option & can be done fairly cheap if you do the work.
The 220 is a US model so all of its manuals are in English.
Aaron
Parts@HoyeTractor.com
(940)592-0181
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
1998 REINKE TRAILER HEAVY HAUL TRAILER (A58214)
1998 REINKE...
2002 FREIGHTLINER CST120 (A60736)
2002 FREIGHTLINER...
