New help, looking for trailer
/ New help, looking for trailer #1
Greg Jones
I just got a TC40 with loader and box scraper the tires have been fill for ballast.
Need to know what the ballpark weight of the tractor is to fit it to a trailer.
Thanks for the help
/ New help, looking for trailer #2
Figure 5,500 lb with the loader and boxblade as a minimum. 6,000 lb would be a safer bet. A tandem axle utility trailer with two 3,500 lb axles will be overloaded by about 500 lb. You really need a 10,000 GVWR trailer to haul your tractor. A 14,000 GVWR would be even better and allow you to add other weight.
I also would not haul that tractor with anything less than a 3/4 ton pickup and brakes on at least one axle. I tried to haul my tractor (a TC45D with loader) without loaded rear tires on my 18' 7k lb utility trailer without brakes. Even though my pickup is a 3/4 ton, a light rain put a slick glaze down on the highway. I went sliding through an intersection at a stoplight. Luckily, nobody else was in the intersection. I turned around and went home. Never have I hauled my tractor on that trailer since then. It ain't worth it.
/ New help, looking for trailer #3
What Jimman said.
5000 to 6000lbs
10k to 14k rated trailer, 20 to 24' long would be best.
Tow with 3/4ton or better truck.
Towing with F 250 4 WD 3/4 ton diesel
/ New help, looking for trailer #7
Many states (including mine) require trailers with multiple axles to have brakes on all axles.
It should be a requirement everywhere.
/ New help, looking for trailer #9
Greg where are you from I have lots of DooLittle brand trailers in stock ready to go.
/ New help, looking for trailer #10
You have the exact same basic setup as I do. My trailer is a 1974 Zieman metal decked gooseneck, 15,000 lbs GVWR, with electric breaks on both axles. The deck is 16' with 2' more of beavertail. I wouldn't want it any shorter in length but as it is, 16 LA loader bucket and Gearmore box scraper down on the deck, the tractor sits fine on the trailer. I do a 2-1/2 hour tractor tow up into the mountains 5-6 times a year with my Ford F-250 diesel/8' bed (long wheelbase counts when towing).
I am soon to be purchasing a backhoe attachment and I will then use the upper arm of the gooseneck to place the loader bucket.
Public scale weight of the trailer, tractor w/ loaded tires, 16LA FEL and no rear 3 pt attachment is 10,300 lbs.
57in Metal Mailbox (A65583)
57in Metal Mailbox...
2020 Chevrolet Tahoe SUV (A64194)
2020 Chevrolet...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
Corral Walk-through Gate (A66408)
Corral...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
