New help, looking for trailer
/ New help, looking for trailer #1
Greg Jones
I just got a TC40 with loader and box scraper the tires have been fill for ballast.
Need to know what the ballpark weight of the tractor is to fit it to a trailer.
Thanks for the help
/ New help, looking for trailer #2
Figure 5,500 lb with the loader and boxblade as a minimum. 6,000 lb would be a safer bet. A tandem axle utility trailer with two 3,500 lb axles will be overloaded by about 500 lb. You really need a 10,000 GVWR trailer to haul your tractor. A 14,000 GVWR would be even better and allow you to add other weight.
I also would not haul that tractor with anything less than a 3/4 ton pickup and brakes on at least one axle. I tried to haul my tractor (a TC45D with loader) without loaded rear tires on my 18' 7k lb utility trailer without brakes. Even though my pickup is a 3/4 ton, a light rain put a slick glaze down on the highway. I went sliding through an intersection at a stoplight. Luckily, nobody else was in the intersection. I turned around and went home. Never have I hauled my tractor on that trailer since then. It ain't worth it.
/ New help, looking for trailer #3
What Jimman said.
5000 to 6000lbs
10k to 14k rated trailer, 20 to 24' long would be best.
Tow with 3/4ton or better truck.
Towing with F 250 4 WD 3/4 ton diesel
/ New help, looking for trailer #7
Many states (including mine) require trailers with multiple axles to have brakes on all axles.
It should be a requirement everywhere.
/ New help, looking for trailer #9
Greg where are you from I have lots of DooLittle brand trailers in stock ready to go.
/ New help, looking for trailer #10
You have the exact same basic setup as I do. My trailer is a 1974 Zieman metal decked gooseneck, 15,000 lbs GVWR, with electric breaks on both axles. The deck is 16' with 2' more of beavertail. I wouldn't want it any shorter in length but as it is, 16 LA loader bucket and Gearmore box scraper down on the deck, the tractor sits fine on the trailer. I do a 2-1/2 hour tractor tow up into the mountains 5-6 times a year with my Ford F-250 diesel/8' bed (long wheelbase counts when towing).
I am soon to be purchasing a backhoe attachment and I will then use the upper arm of the gooseneck to place the loader bucket.
Public scale weight of the trailer, tractor w/ loaded tires, 16LA FEL and no rear 3 pt attachment is 10,300 lbs.
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
3-Pt Backhoe (A66285)
1997 Capacity Spotter Truck (A62679)
1997 Capacity...
New/Unused Wolverine 3 Point Hitch Coupler (A65583)
New/Unused...
2000 Volvo Semi Truck (A66285)
2000 Volvo Semi...
