Getting soil ready for planting
/ Getting soil ready for planting #1
Knight
CT
Kubota L3400
I'm not really sure which attachments to use to convert a beautiful established lawn into a garden area....... area is 40' by 40'
This is what I have for attachments.
1. Backhoe
2. Box grader with scafires
3. Middle buster
Now I have access to a tiller, but I would have to ask a friend and go pick it up in a trailer, etc.. Do I really need to use a tiller or can I prepare the soil with what I have?
What order should I go in?
/ Getting soil ready for planting #2
Get the tiller......
2 to 3 passes and you will have garden ready soil.
/ Getting soil ready for planting #4
/ Getting soil ready for planting #5
Yep, rip-n- till.
/ Getting soil ready for planting #6
I've had pretty good luck with just the tiller... just takes 3 or so passes. Go longwise/crosswise/longwise and you should have it. Might actually be less tractor time then a bunch of closely spaced 'rip' passes with the middle buster.
/ Getting soil ready for planting #7
I'd get a truckload of compost, spread it out. Then middlebust it. If you have sandy type soil, it's likely, if it's dry when you do this that you will not need a tiller. There is a place called Gem Dirt here that sells leaf compost pretty cheap.
My 50x60 area is all raised boxes with lot's of compost. I have no need for my tiller anymore.. I do start it a coupla of times a year for grins..
/ Getting soil ready for planting #8
one word - tiller. No if and or buts. Better at prep, working it, and finish.
/ Getting soil ready for planting #9
If grass is growing, spray it first, then bust and till. Otherwise, grass will pop up for quite a while in new garden.
/ Getting soil ready for planting #10
I agree with charlz. you don't need to rip the sod first. I put in a garden for my wife last year where we had lawn. I tilled the area she wanted and waited a couple of weeks then spread manure-compost over the area and tilled it in.
/ Getting soil ready for planting #11
Knight,
Being that you live in CT, I am going to assume that there are stonewalls nearby and bits of ledge poking out of the ground near your lawn? If so, then I strongly recommend doing a recon with your ripper before tilling to establish the absence of ledge, boulders, cobbles bigger than a loaf of bread, etc.
If you don't see stonewalls nearby and bits of ledge, then I am going to assume that you live on what was once farmland. In this case I strongly recommend doing a recon with your ripper before tilling to establish the absence of burried fence posts, barbed wire, old metal bits, irrigation pipes, foundations, etc.
Then till away.
-Jim
/ Getting soil ready for planting #12
Litsten to the advice about doing recon with the middle buster or you could be facing some serious repair on the "borrowed" tiller. bjr
/ Getting soil ready for planting #13
1. Backhoe
3. Middle buster
Get the tiller and run a couple passes.
If you just use the middle buster...or...backhoe you will still need a tiller or a disc...to get the soil prepared right.
/ Getting soil ready for planting #14
I would second the idea of doing something about the grass first to keep it from popping up later. You will have enough to do fighting the weeds you are sure to stir up busting/tilling. My garden spot is tilled then black plastic is placed over it and the seedlings are put in an X cut in plastic or a slit about 4" wide by however long for peas/beans seeded crops. Does warm the soil up faster also to get in earlier.
Pat
Knight,
Then till away.
-Jim
I put the lawn in over ten years ago. 5000 yards of fill. There is no ledge in my backyard, at least for the first 20' down.
I might hit a sprinkler line. Nothing I can't fix.
I think I will hit it with the middle buster, then get the tiller. I want to play anyways. I just thought the tiller was overkill.
/ Getting soil ready for planting #18
The more passes with a tiller the better:D
Not so fast! Tillers are too easy. They'll tend to cause folks to OVER WORK soil. A tiller will pulverize dirt and turn it into talcum powder. First rain, and you have well compacted "concrete".
I prefer a minimum number of trips over an area with a tiller. I also use mine at lower rpms (well below 540rpm on the pto) to prevent/lessen the pulverizing action.
/ Getting soil ready for planting #19
:confused:
I have never heard of that..OR..never seen that before.
After i turn my garden....i run a disc several passes to have it as fine as i can get it.
And i also haul rich black top soil from the creek bank to my garden, and it is fine dirt.
(He has sod that he needs to get through...so the more passes the better.)
*I figured you would give YOUR OWN advice to him, how you plow yours...not how i plow mine:D
/ Getting soil ready for planting #20
i was going to post something similar to farmwithjunk. in doing my readings, i have run across many articles about how over-tilling is bad. this mostly has to do with destroying capilarity and micropores in the soil. the only time you need a really fine seedbed is for very small seeds that can't physically push up through larger clumps of dirt. (lettuce, carrots, etc.) most larger seeds will actually do better in a moderately rough seed bed. larger chunks provide slower and longer release of soil nutriets, allow water to penetrate more deeply, and perhaps most important of all, will allow oxygen to get down to the roots after that first big rain forms the hard crust farmwithjunk mentions.
all of these problems are significantly lessened if you have a nicey loamy soil to start with (rare). if you're like most of us, you have either too much clay/silt or too much sand/rock. the first option gives you the hard crust, the second option gives you drainage and fertility issues.
unless you are blessed with a fertile loam, unfortunately, you should have started soil renovation for this year's garden last year. then you could have done your subsoiling, tilling and sod busting/destruction operations last year, added amendments, and given it the winter to stabilize and settle. then a little spring cultivating and you would have been ready to plant.
but, that opportunity is gone now. your only choice to destroy the sod is to pulverize it beyond recognition or use chemicals. we hope you don't have bermuda in your grass, or it will most likely be a problem for you all year as it can come back from very tiny pieces of rhizome.
i would do the best i can this year and plant lots of green manure crops and a few hardy vegetables and then this fall, do a proper prep. you could also put in some raised beds, focus on soil amendment and focus on fencing the area if deer or other animal pests are a problem in your area.
things will be much easier for you next year.
good luck!
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A61568)
Detroit Diesel...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
CATERPILLAR GC25K STRAIGHT MAST FORKLIFT (A62129)
CATERPILLAR GC25K...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A61165)
2016 Volvo VNL...
2022 CATERPILLAR 289D3 SKID STEER (A62129)
2022 CATERPILLAR...
