Question on draft control
/ Question on draft control #1
Arkinsaw Dave
Member
Nw Arkansas
Mahindra 6520 4wd
On the back of my Mahindra 6520 where the top link attaches to the tractor there is a bracket with three possible holes to attach the top link. From what I have read in the manual this has something to do with the draft control when plowing ect. Can anyone tell me which hole I should for plowing or does it really make that much of a difference??? thank you.
/ Question on draft control #2
Yes it does make a difference. It depends on the ground engaging equipment you're using and how sensitive you need for your draft. As you've read in your manual draft control allows you to keep your impliment at the same depth regardless of the terrain your crossing. Most of the time you will use the center hole but it may be necessary to change depending on your circumstance.
/ Question on draft control #4
As the other poster noted, it depends on the draft load. The top hole for heavy loads, middle for intermediate, and bottom for light loads.
Thank you.
............what about doing something like bush hogging, does it matter which hole you use there since the draft control would be turned off??:confused:
/ Question on draft control #6
Nope doesn't matter. I usually keep mine in the center hole.
/ Question on draft control #8
Opt-Mist, i think my book says the opposite, Top hole is for light loads bottom is for heavy loads. I will double check.
/ Question on draft control #9
Thank you.
Draft control is only useful for ground engaging implements, and even then I don't believe that every type of ground engaging implement can make use of it.
/ Question on draft control #10
My 7520 is like this. Top hole is most sensitive while bottom hole is least sensitive. If you plowing in hard ground, you should be using the bottom hole.
2010 Honda Accord Sedan (A61569)
2010 Honda Accord...
2010 Case 580N (A60462)
2010 Case 580N...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
UNUSED REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED REMOTE...
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
Cat CB24B (A60462)
Cat CB24B (A60462)
