Oil & Fuel Fuel system bleed
/ Fuel system bleed #1
golfgooroo
Member
Recently had a problem with the thermistor and possibly the fuel cutoff solenoid. However, I can't seem to properly bleed the system of air. I can prime the fuel to the pump but cannot see fuel at an injector. I don't have a manual on the JD 5210 so I'd appreciate any help on proper means to bleed the fuel system.
Thanks!
/ Fuel system bleed #3
You most likely have air in the injectors, which can be solved several ways. Luckily anytime I have had a problem on any of my tractors I coudl keep cranking the engine and eventually it woudl work through and fire. On the rare occasion I had someone else crank the engine and gave a small shot of either into the intake and it fired. Do not spray either in the intake then go around and crank it as the either will fill the entire intake and you have a long draw when it does fire and the engine will race.
The other option is to crack an injector loose and crank the engine, but keep in mind you are then dealing with a fluis under several thousand psi that is looking for a way out.
/ Fuel system bleed #4
Thanks!
Crack the line at the injectors and crank till fuel dribbles out.. do this one at a time.. it will likely start before you get them all done.
use tools.. keep hands away from high presure fuel and oil!
If it is a manual trans tractor.. sometimes they will like a pullstart after an out of fuel condition.
soundguy
/ Fuel system bleed #6
You can download an operator's manual for John Deere tractors.
Just to clarify Egon, while you may 'view' JD manuals on the web, downloading them is another thing.
Unless you got some trick up your sleeve you ain't sharing ? :rolleyes:
/ Fuel system bleed #7
[QUOTEUnless you got some trick up your sleeve you ain't sharing ?][/quote]
Oh oh, did I goof? :eek::D:eek:
I ain't savvy enough to have any tricks that others don't know about!:eek:
But I can Print the items I need.:D
/ Fuel system bleed #8
Yes, that's easy enough. And don't get me wrong, you can still save each page as a file on your computer.
Problem is their index page, all the links point towards 'their' harddrive.
/ Fuel system bleed #9
I just changed the original post to "Access" so that should dispense with technical jargon protocol!:D
I can access the site and print the information I require so that makes me happy!:D
Now; hopefully, information on the site will help the OP.
/ Fuel system bleed #10
Wow dude, I wasn't trying to get "protocolish" on ya, just thought you knew a trick I didn't.
/ Fuel system bleed #12
David, I lightly read over the Wget page.
To put in basic language, this Wget could fix the JD index page links so they point towards the correct locations on my hard drive ?
/ Fuel system bleed #13
Yes, with the command I listed, you would have a local copy of those John Deere manuals with the links pointing to the local files on your drive. The saved directory will be about 29 MB. Give it a try.
/ Fuel system bleed #15
There are some videos on Youtube that show how to bleed fuel systems. Search "bleeding diesel fuel system". They hav one on an old Massey 35 that is really good.
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
40in. Skeleton Bucket Excavator Attachment (A61567)
40in. Skeleton...
2020 Broyhill Load and Pack TD3.6 Mini Articulated Garbage Truck (A61568)
2020 Broyhill Load...
1978 Ford L8000 Fuel and Lube Truck (A61165)
1978 Ford L8000...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
