Rotary Cutter on 2720
   / Rotary Cutter on 2720 #1
Rob-D
Catskills
John Deere 3320
Anyone run 6' or bigger Rotary Cutter on a sub? I think my 2720 will run the pto fine but the weight of the 7' Woods is only about 50 lbs. more then the 6'.
Be nice to run a 7' but I may be stretching it although the 3pt. will lift 1250 at two feet out according to Deere and we know Deere takes extra care in their specs!.......Right!
Rob
   / Rotary Cutter on 2720 #2
I think 6' may be to big...the weight of a rotary cutter is pretty far back. You will definitely need your FEL on-and possibly some weight in the bucket.
   / Rotary Cutter on 2720 #3
Yep,.. might be able to disconnect the power steering pump, too. 'Cause those front tires won't hardly be markin' the tops of the grass!! :eek:
If it's a light-duty model like the JD LX6 you might get by. But the cutter weight might approach 40-45% of the weight of the tractor. Much less "pucker factor" if you went with a 5' model, though.
AKfish
   / Rotary Cutter on 2720 #4
If it is an open space you might consider a pull type cutter, much easier on the tractor. I used to have a Mohawk 6' cutter pull type, easy to hook up and did a nice job for many years.
Steve
2014 Chevrolet Cruze Sedan (A55758)
2014 Chevrolet...
Case 570MXT Turbo Tractor Loader with Box Blade (A55787)
Case 570MXT Turbo...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
