Rotary Cutter on 2720
   / Rotary Cutter on 2720 #1
Rob-D
Catskills
John Deere 3320
Anyone run 6' or bigger Rotary Cutter on a sub? I think my 2720 will run the pto fine but the weight of the 7' Woods is only about 50 lbs. more then the 6'.
Be nice to run a 7' but I may be stretching it although the 3pt. will lift 1250 at two feet out according to Deere and we know Deere takes extra care in their specs!.......Right!
Rob
   / Rotary Cutter on 2720 #2
I think 6' may be to big...the weight of a rotary cutter is pretty far back. You will definitely need your FEL on-and possibly some weight in the bucket.
   / Rotary Cutter on 2720 #3
Yep,.. might be able to disconnect the power steering pump, too. 'Cause those front tires won't hardly be markin' the tops of the grass!! :eek:
If it's a light-duty model like the JD LX6 you might get by. But the cutter weight might approach 40-45% of the weight of the tractor. Much less "pucker factor" if you went with a 5' model, though.
AKfish
   / Rotary Cutter on 2720 #4
If it is an open space you might consider a pull type cutter, much easier on the tractor. I used to have a Mohawk 6' cutter pull type, easy to hook up and did a nice job for many years.
Steve
2016 Chevrolet Cruze Limited Sedan (A55758)
2016 Chevrolet...
2020 Ford F-150 Crew Cab Pickup Truck (A53422)
2020 Ford F-150...
(2) DOUBLE AXLE FENDERS (A54756)
(2) DOUBLE AXLE...
2000 Freightliner FL70 Manitex 14 Ton Crane Truck (A55788)
2000 Freightliner...
JOHN DEERE 4 BOTTOM PLOW, 3PT (A54756)
JOHN DEERE 4...
