diff between min/no till drills
/ diff between min/no till drills #1
jimg
After looking at a number of drills it appears the only difference between min and no till is coulter type. Min till drills will have a very wavy coulter and no till is nearly flat. Am I understanding this correctly?
ETA: more questions...First, are there means other than wavy coulters that would perform tilling in the min till system? Perhaps that would take the form of some sort of hoe or??? In regard to min tilling into living sod how well do you think that would work? It seems that a wavy coulter might not do the job. In fact was the system even designed to work in sod?
/ diff between min/no till drills #2
No-till drills were initially utilized to renovate pastures without having to completely turn 'em black. Or introduce another grass variety or legume into an already established pasture.
The wavy coulter is designed to 1.) better displace crop residue and remove it from planting furrow 2.) create a seed furrow that is less likely to collapse and close off in a loose soil-crop residue field.
They're heavy... heavy. Way stout -big iron!
AKfish
/ diff between min/no till drills #3
Hi I'm pretty sure the min till's won't do a good job right into sod, extra so if it hasn't been worked recently.
Min till can mean lots of things but roughly it means strips of the ground are worked directly in front of the planting rows or the ground was just worked with fewer passes than conventional tillage. Can mean of lot of things.
/ diff between min/no till drills #5
Drilling anything into a living sod is a crapshoot with no-tillage equipment and even more so with mintil stuff. Even if you manage to get the seed in the ground at the proper depth, covered and packed sufficiently to provide good seed to soil contact, competition from an actively growing existing sod can totally prevent new crop growth.
/ diff between min/no till drills #6
Yep... there's a "germ of truth" there. But look at the alternative's! That's kinda like the the very old man; when asked how he's feelin' - he replies - I'm alive and that's better than the alternative! :)
AKfish
/ diff between min/no till drills #7
There's a distinct difference between the two concepts. (Minimum tillage vs no-till) but the difference in terminology amongst equipment manufacturers gets a little fuzzy. Some brands sorta meet in the middle, or attempt to be able to meet criteria for BOTH applications. In the end, neither is the answer to EVERY condition. And then you get different approaches to each concept. What works well one year may not work at all next. What works with one crop species may not work at all with another crop.
Personally, my BEST advice has come from our County AG Extention Service Agent. He spends time observing quite a few attempts at using a variety of equipment. Armed with MORE information on the possibilities, he can offer good advice based on conditions at hand to go along with equipment available at the moment.
As with ANY attempt to out wit mother nature, it's a roll of the dice as to what works and how well.
/ diff between min/no till drills #8
We used to use and early style of no-till drill to plant winter wheat into bermuda grass sod in the fall. Generally speaking that worked pretty well as a grazing supplement for out cattle in the winter, but for us, was eventually deemed to not really be cost effective. The deer sure loved it though.
/ diff between min/no till drills #9
Well said... Caveat emptor! Everything depends upon your own particular environment and your individual objectives.
Someone in western Kansas with 2,000 acres of intermediate wheatgrass would likely not prefer to have to chisel plow and disc to black soil in order to renovate a tired pasture. A good no-till drill and a recommended herbicide treatment could save him thousands of dollars as well as 2-3 years of reduced use of the pasture before the new stand of grass became well enough established.
But someone in Pennsylvania with 80 acres... well, the decision might be quite a bit different.
(The local NRCS here in Alaska has a real nice 10' Buffalo no-till drill for a nominal fee.)
AKfish
Sorry for the lag but Ive been really busy lately. First, thanx a million for the replies!!!
Guess it would help to understand what Im thinking about:
Now that I have my Timothy fields planted and going Id like to never have to burn down again. At least not any time soon. My plan is to dress up whats there as needed and occasionally rip using my pasture renovator. In regard to dressing up that means Im going to be drilling into some amt of sod. What I think Id like to do is 'plow' narrow strips (thats where the coulters come in) followed by dropping seed and fertilizer. The fertilizer would be dropped (not on the surface) in this 'plowed' strip beside the seed. Given my experience so far drilling into sod is really tricky...VERY difficult to get good germination. I really dont want to plow the entire field but think I need to plant into something other than sod. This is why Im trying to figure out strip-till. Also I have an idea that I might be missing some trash management devices. Im sure that would help too. I planted Timothy/OG into some really heavy trash (from the burn down) and it needed to be dressed up this spring.
/ diff between min/no till drills #11
"There's a distinct difference between the two concepts. (Minimum tillage vs no-till)...."
Yes, depending upon where you're at and what you are doing this is true. Here, for a long time, "min-till" was often considered making one pass with a chisel/disc and drill over a field in order to introduce new seed with as little effort with the belief that any new production from it was worth the limited effort.
That, and no-till really seems to work best in northern areas where the harsher winter and freezing conditions help with the breakdown of surface organic material to push the process along. I couldn't tell you the last time I was driving down the road and saw a no-till in use here....not very common.
/ diff between min/no till drills #12
Very low tech.....but it works. Google "Farnam Pasture Renovator". Lots of 'em floating about. They've been around for ages. Simple, relatively inexpensive, and they really do work. (seeds directly on top of fresh ripped strip. rips 0" to 9". works best (for me) @ 4" depth.) It's NOT a deep ripper.
John Deere 652R 52in Stand-On Commercial Mower (A56857)
John Deere 652R...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
2005 Vermeer 604 XL-Series (A62177)
2005 Vermeer 604...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
EXCAVATOR QUICK DISCONNECT (A58214)
EXCAVATOR QUICK...
