B3030 PTO
   / B3030 PTO #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
I notice when hooking up an implement on my B3030 that the PTO output shaft on the tractor does not freely spin like on my old JD 790.
Normally not an issue, but there have been times in the past where I had to rotate the shaft on the tractor if for some reason I couldn't spin the shaft on the implement to get the splines to line up.
Is this just the way it is with the Kubota?
   / B3030 PTO #2
It must be that the pto is not in dis-engaged position. Like "neutral" if it is in "gear" it won't free spin..?? JMHO
   / B3030 PTO
There are only 3 positions on the PTO select lever. Front, mid or both. No neutral position. Other than that the PTO clutch is either engaged or not.
   / B3030 PTO #4
To allow the rear PTO shaft to turn freely,place the PTO lever in the front position.Same thing,to allow the front PTO to turn freely,place the PTO lever in the rear position.I need to do this frequently with my front snowblower so I can check that it's not frozen when I go to engage it,as well as lubricating the chain at the 4 hour intervals.It's the way independent PTO works.Also I've noticed having trouble moving the PTO lever sometimes when not frozen.I can move the blower drive shaft a little and then it will change positions.Any one else had this problem?
2016 John Deer 5075E (A60462)
2016 John Deer...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
