Markham Grapple's Here!
/ Markham Grapple's Here! #1
Lunk
WI
Branson 4720H / BL200 Loader
No - I don't have any pics yet (I don't even own a digital camera, so I will have to enlist the kids help to post some).
It arrived yesterday afternoon, along with my new toothbar. Came with 6' hoses, and about 4' of abrasion resistant sleeving installed.
Wow - Those Markham folks sure know how to build stuff!
I have to p/u the hoses this afternoon after work, so hopefully I can report out as to its function sometime tomorrow.
Feel like a kid on Christmas Eve, with a bike-shaped gift under the tree wearing my name...
/ Markham Grapple's Here! #2
Congrats on the new tool. I've been toying with the idea of a grapple myself. Please post some action pics as soon as you can.
Mark
/ Markham Grapple's Here! #3
Lunk, I think you and I were shopping at the same time. I got mine about 2 weeks ago and had a blast on it the first weekend. Cleared 1/2 mile of grown up roadway, ripping out trees with ease and creating house sized mounds of brush. Hope you enjoy your new toy! I think you will be impressed. Watch out for those hydraulic lines, for if any thing screws up, that's where it will be. I bought 20' of additional sleeve to encase my lines from the valve to the grapple quick connects, and then had a buddy put it through it's range of motion to check the movement of the lines, then secured it to protect it as best I could. When you are diving into trees and brush, it would be easy to snag one. We also found it better to carry big piles of debris away in reverse so that the limbs and vines weren't pulled back into the tires and hydraulics. Hit the trees high to push them over, back up, lower the tines to engage the roots, then curl and ease forward. 6" trees just pop out! I also used it to pick up and carry large (>1000 lb.) rocks. Way easier than trying to pick one up in a bucket. After putting it through it's paces, let us know what you think.
Well,
I got home last night and put all the fittings together, and routed the hoses as neat as a proffessional zip-tie installer can. Slapped it all together and fired it up. Hit the remote lever and the jaws open up about halfway, and start shuddering...won't open any further, or close properly.:confused:
Now I shut it down, and check the hydraulic fluid - Nothing in the sight-glass. It would appear that 44' of hoses and an extra cylinder sucked up enough fluid to cause a low condition, and my pump was cavitating. Checked one of the quick couples, and the fluid that dripped out was well aerated...
D'oh!
Manual says to only use Branson Hytrans fluid (of course), but I'm betting that the stuff from TSC will do just fine. I'm calling the dealer this morning to be sure...
Good things come to those who wait...(I hope).
I'll keep you posted, and hopefully have some pics up after the weekend!
HCJ -
I added 2 gal of premium hyd fluid to bring it up to normal, tried it again, and got nothing but a slight shudder from the grapple. It's almost as if it's trying to work, but won't.
Did you have any issue with yours?
Is it possible that the air in the lines / cylinder is causing this issue? I cannot believe that high-pressure fliud wouldn't displace any air in the system, but this is new stuff for me...
Thoughts?
Anyone?
/ Markham Grapple's Here! #6
The lines/cylinder will self-purge, but may take a few tries with 44' of hose! You are using a rear remote to operate it?
Yes I am!
2-16 footers for the grapple, and the 2-6 footers on the grapple.
I'll fool with it some more tonight when I get home. I hope it "self-purges" for me. I'm ready to loosen fittings up front to allow the air out if necessary, but don't want to deal with fluid being shot all over the place...
Bad news is that I won't be able to do much with it once it's working though...The great thaw has now set in, and everywhere I want to work has standing water and / or muddy conditions. I don't plan to stick the tractor for the sake of using the grapple.
The significant other is shaking her head at this point, muttering something about "a big waste of money..." I need sucess!
Thanks for the input. I hope you're right!
Lunk
congratulations on your grapple.... I love mine. did you get the bugs worked out?
Not yet.
I've been busy, so It's been one of those "spend 20 min dinkin' around" each day" narrowing the problem down.
I've removed each rear quick coupler from the hoses, and pumped the air out of the system using the valve control. The grapple opens when I do one, and closes fine when I do the other, but hook them both up - Nothing.
I wonder - The NAPA folks who made the hose used a male quick-coupler that was different than the ones on the back of the tractor, so I just bought female couplers to match the hoses, and simply replaced the ones on the tractor. They were the same size coupler, so that shouldn't make a difference, should it?
/ Markham Grapple's Here! #10
Is that a factory valve for your rear remote, or one you installed? If the later please post a part number for it.
Valve was installed by dealer, using factory kit. High $, but I wanted it done right. :(
I called the Dealer last night to pick his brain, and his guys are stopping by today to check on the valve function - gratas.
Fingers are crossed.
Markham has been unbelievably helpful, and told me that if it comes down to a faulty ram, they're there for me. I just haven't had the time to take it to the neighbor's, to try it on his skid-steer to narrow down the problem.
6" of snow last Sunday. 1"+ in rain on Monday / Tuesday, and today it's 13 degrees out with 40-50mph wind gusts...Gotta love WI in the springtime!
The only bonus for me is that it's so soft everywhere right now, even R-1 AG tires wouldn't keep me off the end of a winch cable...so I can't do much with it anyhow.
Hooray!
I just got off the phone with the dealer - Turns out the two hoses feeding the remote valve were hooked up wrong by them, needing to be switched.
Word is - I've now got grapple!
Sick feeling in pit of stomach - Gone!
Wifey - Off my back!
Dreams of all that I'll accomplish with the new tool - Priceless!
Thanks all!
Lunk
PS - Yeah, eventually there will be photos...
/ Markham Grapple's Here! #13
Know how you feel. Congratulations.
Thanks!
This has been a source of much frustration, despite the dealer and manufacturer support.
KUDOS to Markham Welding - Great product / Great support!
/ Markham Grapple's Here! #15
I'm glad you got your problem worked out. Seems like a nice easy solution. Now on with the grappling.:D Make sure you post some pics, I'm very interested.
By the way, while you have the camera out there, could you snap a couple shots of the hydraulic line set up? My 3510 is set up for a backhoe and I am wondering if your set up is similar. I'm kind of hydraulically challenged and I get a headache when I try and figure these things out on my own.
Mark
Mark
Will do.
/ Markham Grapple's Here! #17
Soooooooooo.......................how much longer do we have to wait for pics?
Probably a while yet.
Nothing's changed in my world as far as my ability (or lack thereof) to post pictures...
Sorry...:(
/ Markham Grapple's Here! #19
C'mon pitchers (-:
I know, "pictures".
C'mon pitchers (-:
I know, "pictures".
Some day I'll sit down with the boy and have him give me a quick instruction in the fine art of posting pics.
Problem is the home computer is iffy at best for the task, and the work computer is off-limits...
Someday.
JOHN DEERE 5075E TRACTOR (A64278)
JOHN DEERE 5075E...
2018 Ver-Mac S/A Solar Towable Speed Trailer (A64194)
2018 Ver-Mac S/A...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
