GC-2300 Peddle Adjustment
/ GC-2300 Peddle Adjustment #1
DEdwards
Benton, AR
BobCat CT-122
Can anyone tell me how to adjust the peddle on the GC-2300. When you remove your foot from the peddle, it should return to neutral (center). It is not exactly returning....Is there an adjustment?
Thank you
/ GC-2300 Peddle Adjustment #2
Have you greased the zerk fitting on the shaft?
/ GC-2300 Peddle Adjustment #3
My GC2310's pedal almost always requires a slight touch to return to "full" neutral, either from forward or from reverse. It will require some experience/practice along with a light touch to get it smooth.
/ GC-2300 Peddle Adjustment #4
There is an adjustment, I don't recall if it covers it in the owners manual. Sometimes, if it isn't too bad, you can just tighten the spring underneath a little bit.
/ GC-2300 Peddle Adjustment #5
I find that real annoying, too. Especially when creeping up to something I really don't want to touch, like a sliding glass door.
If anybody finds the fix, please let us know.
/ GC-2300 Peddle Adjustment #6
GREASE the rocker and tighten the return spring
/ GC-2300 Peddle Adjustment #7
Hi Neighbor.
Hmmm, it is appropriate to ask *why* you are sneaking (creeping?) up next to sliding glass doors with your tractor? :rolleyes::D
Jay
/ GC-2300 Peddle Adjustment #8
Hi Neighbor.
Jay
Officer, I swear I was just doing a little backdragging.
/ GC-2300 Peddle Adjustment #9
At least with the 23xx you don't have to take your foot off the pedal to stop the creep. On the 24xx-26xx do you have to do a pedal dance to stop creep?
Doug
2018 INTERNATIONAL LT SERIES (A65643)
2018 INTERNATIONAL...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
2014 Frontier BB2060 Box Blade (A65640)
2014 Frontier...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
John Deere 660 Hay Rake (A65640)
John Deere 660 Hay...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
