GC-2300 Peddle Adjustment
/ GC-2300 Peddle Adjustment #1
DEdwards
Benton, AR
BobCat CT-122
Can anyone tell me how to adjust the peddle on the GC-2300. When you remove your foot from the peddle, it should return to neutral (center). It is not exactly returning....Is there an adjustment?
Thank you
/ GC-2300 Peddle Adjustment #2
Have you greased the zerk fitting on the shaft?
/ GC-2300 Peddle Adjustment #3
My GC2310's pedal almost always requires a slight touch to return to "full" neutral, either from forward or from reverse. It will require some experience/practice along with a light touch to get it smooth.
/ GC-2300 Peddle Adjustment #4
There is an adjustment, I don't recall if it covers it in the owners manual. Sometimes, if it isn't too bad, you can just tighten the spring underneath a little bit.
/ GC-2300 Peddle Adjustment #5
I find that real annoying, too. Especially when creeping up to something I really don't want to touch, like a sliding glass door.
If anybody finds the fix, please let us know.
/ GC-2300 Peddle Adjustment #6
GREASE the rocker and tighten the return spring
/ GC-2300 Peddle Adjustment #7
Hi Neighbor.
Hmmm, it is appropriate to ask *why* you are sneaking (creeping?) up next to sliding glass doors with your tractor? :rolleyes::D
Jay
/ GC-2300 Peddle Adjustment #8
Hi Neighbor.
Jay
Officer, I swear I was just doing a little backdragging.
/ GC-2300 Peddle Adjustment #9
At least with the 23xx you don't have to take your foot off the pedal to stop the creep. On the 24xx-26xx do you have to do a pedal dance to stop creep?
Doug
2019 FORD F-350 (INOPERABLE) (A65643)
2019 FORD F-350...
2020 Cushman Hauler 1200X Gas Utility Cart (A64553)
2020 Cushman...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
90in. Work Bench (A65640)
90in. Work Bench...
2017 Ford Explorer 4x4 (A62679)
2017 Ford Explorer...
2005 Acura RSX Coupe (A64557)
2005 Acura RSX...
