Snowplow blocks headlight beam
   / Snowplow blocks headlight beam #11
I get the same thing with the stock headlights reflecting off the back of the bucket. You'd think they'd paint the back of the bucket flat black so it ain't so annoying.
Here's my lights rigged to the Roll Bar hinge so they work whether it's folded or up...It doesn't fit in the garage in the up position....witness the chunk missing from the top jamb (people on gin and tonics shouldn't be driving tractors)
My little Kubota has a spade connector pre-wired for a rear work light. I run a rear light and just made up a "Y" connection to a switch in the kick panel below the seat. I had a marine grade push/pull swithch lying around from when I rebuilt my Boston whaler into a flats boat.
With the wire running up thru the rollbar it's protected. I wonder if your Deere has the same pre-wire to the rear. If it does it's under a 1 hour install. Just bolt the lights into the hinge (grind of the bolt so it's short enough to close the RPS). There is a stock hole in the hinge on Kubotas. The only hole I drilled was thru the plastic kick panel for the switch.
Pay attention to your available amps if you're running any other electrical add-ons.
   / Snowplow blocks headlight beam #12
.... I've got a few spare electrical connections on the rear wiring harness.
Chuck
It's one of those!!! Should have read your post better. Get a $5 tester and just go with any free connection that is switched on/off with the ignition.
Install a rear work light for back up and changing implement. On mine there was a factory 3/8 hole in the fender to accept a generic $12 work light. Too easy!! Wire the rear light so it's always on. rig up a "Y" connector off the factory wire--one peice to the rear work light and the other wire off the "Y" goes to the switch (you supply) off of which you power both ROPS lights.
You will want the ROPS lights on a seperate switch. Trust me here. On a June night you will get a mouthfull of bugs...and you'll want to turn them off.
  • Tractor lights wiring.pdf
53- Thanks for the suggestion. The guys on the jd forum gave me the heads up on which electrical connections to use.
By the way, I had an 8122 Gravely. Fine machine it was.
Chuck
   / Snowplow blocks headlight beam #14
53,
That whole setup is great. I've got a 7610 and a new project for this weekend. BTW, cute kids. Watch 'em. They grow up fast.:eek:
   / Snowplow blocks headlight beam #17
My TYM has factory installed rear facing light that has switch in its housing. You might get one of those and it will save you additional switch and some wiring.
   / Snowplow blocks headlight beam #18
I should have mentioned that I need to keep the rops folded down to fit in the garage. It normally stays like that.
If it weren't for that, I would go with your suggestion Jim.
Why not modify the ROPS. Before I get shot down consider this:
You probably want to fit under a standard 7' (84") door way and your ROPS is currently around 92". If you had a non folding ROPS the spec height is 84" (according to JD site). Why not remove the top section of your ROPS and make a new section with a lower height? You are modifying a safety device but you can easily restore it to original.
If you did this you could also include welded structure for supporting a canopy;).
Redneck: I've got a 3x5 Peterson Mfg. light on order at our local ag store. 1 hot and 1 ground wire. The circuit it will be connected to is controlled by the headlight switch.
mwb: I know this is a whole other subject but I have a friend who has a jd4400. It wouldn't fit in his barn stall with the rops up due to a low hanging beam. He cut a section out and re-welded to make it shorter.
He parks it next to an old Farmall with no rops.
Chuck
   / Snowplow blocks headlight beam #20
Chuck
I did the same to mine; as-is the ROPS was way to tall and interferred with doorways, tree branches... I had a choice - cut it down to a reasonable height or leave if folded all / most of the time. I removed four inches and that made all the difference - now I can leave it up all the time.
6ft Rotary Brush Cutter Tractor Attachment (A55851)
6ft Rotary Brush...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
2025 GIYI Stump Grinder Mini Skid Steer Attachment (A53421)
2025 GIYI Stump...
Hose Reel (A55787)
Hose Reel (A55787)
