Slackdaddy ?
/ Slackdaddy ? #1
lawn_master
Slackdaddy,
I am going to pick up a new tractor on Tuesday. I am considering the same method in which you picked up your tractor from Wallace. Can you describe how you secured the tractor. I am thinking you used a Rider, City truck with a 16' bed.... From reading the other posts it seems you drill 2x4 into the bed surrounding the rear wheels. You used a strap on the front. What did you secure the straps to? Also will ramps support the weight of the tractor or do you absolutely need a bank to back up onto. I was going to use a combination of using a bank with two ramps to make the descend not so steep. Any advice would be greatly appreciated. Tractor, loader and mower will be around 2600 lbs.... Thanks in advance
/ Slackdaddy ? #2
Slackdaddy,
I worked with a Ryder truck recently, it was an Isuzu 2 ton. We hauled about 5-6k lbs, it did fine. I believe, he backed up all the way to the headboard, then screwed 2x4s surrounding both front and rear wheels, and it has an E-Track system running down each side that straps can be attached to.
Also, most Ryder trucks have lift gates, so it'll stick out further when backing up to a bank.
Kyle
FULL SIZED PORTA POTTY (A60736)
FULL SIZED PORTA...
2017 CATERPILLAR 120M2 MOTORGRADER (A59823)
2017 CATERPILLAR...
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2019 Autocar ACX Xpeditor T/A Heil 31Yd Side Loader Garbage Truck (A61568)
2019 Autocar ACX...
(10) Rolls of Galvanized Wire (A60463)
(10) Rolls of...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
