L2800 your thoughts.
/ L2800 your thoughts. #1
Thomas
Epic Contributor
Lebanon,NH.
Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
Round 1.
Plan on purchasing B2920HSD w/loader,turf tires, mid march...$16.850.oo
Round 2...today.
Dealer made offer on L2800HST w/loader,R4's fill...$16.875.oo
Looking forward to your imput...Mrs. already gave for thought ;) L2800HST.
Thanks.
/ L2800 your thoughts. #2
The L2800 would be my choice but I guess it all boils down to what you are going to bei doing with it. If physical size is not a big deal I ould go with the 2800 just because you could do more with it.
/ L2800 your thoughts. #3
Round 1.
Round 2...today.
Thanks.
Sounds fair. I recently gave 18,900.00 for a new L3400 HST w/ loader. Good Luck (probably could have done a little better had it not been for a trade in with purchase)
/ L2800 your thoughts. #4
Oh no, the little mule is going??
I think you should go green this time Thomas.:p:D
FTCKUBOTA & firefighter jim.
Thank you for imput. :)
"Egon...Oh no, the little mule is going??"
It will be sad day indeed when piece of my heart place upon the flat bed,and I did try and convince the Mrs. we should hang on to the old girl...no dice. :(
"I think you should go green this time Thomas.:p:D "
We did check JD and I like control setup,but the dealer and I always had hard time seeing eye to eye over the decades.
/ L2800 your thoughts. #7
I miss the little mule. If only it would have had power steering.:D
I'd really wanted a B7800 but the Green was what I thought I could almost afford.:D
" If only it would have had power steering."
I agree!!!
900 on meter almost 14 years...1 tire tube & 1 hose replace the old girl done everything I ask of her and more.
Sure like to find or who ever purchase the old girl gives her nice roof over her hood. :)
/ L2800 your thoughts. #9
Mine had 3000 hours on it. It also had a few more repairs but most were type of usage related breakage things. Welds on the loader, a broken steering arm and a stick jammed into the hydro pedal linkage.:D
Dynamo, steering box, two seats and a bucket were the only real wear out parts for me. The bucket was sorta rebuilt with plate and new cutting edge.:D
The neighbour said I used it well!
Forgot the two wore out joystick controls.:D
/ L2800 your thoughts. #10
My L2800 has been a great piece of equipment for the past two years. No complaints what so ever. Don't know what you have in mind to use it for but for a compact tractor which is reasonably priced I highly recommend it.
/ L2800 your thoughts. #11
My thought is, you'll be kicking yourself for the life of the ownership if you don't pick the one best suited towards your needs. Just don't fall for the bigger is better trap, unless bigger is better for you.
I'm sure you know the basics, weight, width, loader capacity, fuel economy.
The only other major factor I can think of is, consider a decision that allows you to get the most out of your existing implements.
/ L2800 your thoughts. #12
I had a 2800 traded it for a 4400 to get more hp..
Never had a problem with it,,,good tractor...
Bob..
/ L2800 your thoughts. #13
Wouldn't the L2800HST have the potentially jerky three point hitch?Versus the B2920HSD with the quarter-inching valve?Or another thing to consider-the L has been around awhile vs. the B is a new model.Just a few thoughts.
/ L2800 your thoughts. #14
I would definitely go with the 2800 unless the additional weight and/or size is a concern.
/ L2800 your thoughts. #15
WOW Really?
~$19K?
I got my L3400 this time last year, with R1s, loaded rears, and the LA463 loader for $16K...
I have been happy with it, and the differences are minimal...
You will like it. Good Luck and enjoy!
Later,
J
/ L2800 your thoughts. #16
Your decision must be made based on your needs. The two tractors share many things except size. One is small the other is larger. Power and capabilities are similar except the additional traction and stability from the weight advantage of the 2800. I've seen times where my 2800 is a bit too big when working it in a close area. I dug some post holes last summer for a person putting a fence around his yard. One hole I couldn't get to where I could have with a small B series. If you believe you will be working in narrow areas, your choice is clear. If you will be working it in open areas, I believe I'd prefer the 2800. I have had no problems at all with my 3 point using the implements I own and use and if given the choice tomorrow, would buy it again.
/ L2800 your thoughts. #17
The L2800/L3400 are nice workhorse tractors for the money. If I were doing any reasonably amount of finish mowing around a lawn - I'd opt for the B series. They are nice and light and I prefer a mid mount mower for finish mowing.
For the money, think that getting the few extra HP with the L3400 is worthwhile. It will never stop though - you can get more for more money. I do think that you will get almost all the money back come resale time. In the used market, tractors often tend to be classified by HP and 'does it have a loader' - by the average buyer.
/ L2800 your thoughts. #18
WOW Really?
~$19K?
Later,
J
Story of my life!
/ L2800 your thoughts. #19
I see in your profile that you have a Kubota B7100HST w/FEL... are you upgrading? What are the main tasks you plan to do? :confused:
"are you upgrading?"
Yes.
"What are the main tasks you plan to do?"
Care 300' + driveway,small tree farm work,mowing couple acres field,snow removal-2 driveways,than the Mrs. list.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
iDrive TDS-2010H...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2022 EZ-GO ELITE...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
