b3030 push pull cable
   / b3030 push pull cable #1
BLANG311
has anyone had trouble with the push pull cable that runs the loader bucket from the joystick?
   / b3030 push pull cable #2
Huh?? My B3030 loader bucket is hydraulically controlled and doesn't have any cables that I'm aware of.
Thats what I thought to. The cable that runs from your joystick to the hydraulic valve is a push pull cable similar to that found on a ten speed bicycle only thicker. The end will pull loose from the wire cable and it seems impossible to repair without replacing it for 130 bucks
   / b3030 push pull cable #4
I have over 300 hours on mine with no problems and use it constantly.
You might try repairing it with a swage tool. Although I don't know where to find one you could try a steel cable vendor, marine or aircraft repair facility. It is similar to the process used to swage hydraulic fittings on your tractor. Possibly the tool your dealer uses for Hydraulic line has a small enough die for your cable? You can google (cable swage tool) for some ideas.
2016 Nissan Frontier Extended Cab Pickup (A50323)
2016 Nissan...
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
International 1420 Combine (A50514)
International 1420...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
