3-Pt Shudder
/ 3-Pt Shudder #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
I have a IH 384 tractor. Lately, I've noticed that when carrying a heavy implement while traveling, my 3-pt system shudders (load drops about 2"-3" then the hydrauics quickly corrects and picks the load back to original height). It happens about every 10 seconds and violently shakes the tractor. I checked my fluid and it is full. Any ideas what could be causing this?:confused:
/ 3-Pt Shudder #2
Does it happen with bouncing the impliment? It could be that the increased cylinder pressure when the impliment pulls some "G"s is causing the hydraulics to overpressurize and the relief opens and vents fluid to protect the structure. If you have a draft control, it then adds fluid from the pump to reposition the 3PH after it drops from the lost fluid. If it dosn't do it while stationary, that would be my guess. If it hasn't done it in the past with this same impliment and under the EXACT same travel conditions, It could be that the safety relief adjustment has shifted, or something is causing it to relieve at a lower pressure.
What is the rated lift force on the 3PH? What is the weight of the impliment?
/ 3-Pt Shudder #3
Does your tractor have draft control?
If so, I've seen heavy implments mess up it's head.
Fiddle with that and see what happens.
/ 3-Pt Shudder #4
It sounds to me like your hydraulics are "hiccupping." That's when there is a leak in a position control system that lets the position change until it is sensed. Then a shuttle valve shifts and the hydraulics correct the position. The tractor is shaking as a function of rapidly moving that heavy implement. Normally hiccupping is a symptom of a leak in a check valve or the main lift cylinder has a worn seal that is slowly leaking. Some tractors have an inspection port where you can shine in a flashlight and watch what is going on, but most likely you will have to pull the hydralics and rockshaft out to repair and correct the problem.
Many tractors have this problem for many years without getting much worse and people just learn to accept it. If you aren't doing something that requires close position control, it really doesn't matter. It is a pain to have that shaking when it corrects, but I'd wait if I didn't really need close control.
/ 3-Pt Shudder
Thanks for the replys. It happens when the implement is raised whether I'm stationary or traveling. It doesn't do it all the time. Sometimes it may do it for a few minutes then not at all the rest of the day. Some days it does it much more. I can live with it as long it is not making the problem worse (or putting more wear on my system) by not addressing it.
/ 3-Pt Shudder #7
Alt5600.. it's doubtfull it is cavitation.. that would happen on the pump side.. not the pressurized cyl side. I think Jinman hit the nail on the head.
The poster is probably seieng a system leakdown and then system regeneration in a position control scheme. Likely sources are relief or check valve, internal gaskets and oings, including the lift piston/cyl.
Ford/NH used a unloading type valve that will do this very thing.. their previous control valve setup pre 53 did the same as well.. it's quite common.
soundguy
/ 3-Pt Shudder
The shudder appears to be getting worse (more often). Also, the implement lowers itself when the engine is turned off. Could this be caused by a dirty suction filter or orifice filter? How hard is it to rebuild the hydraulic system or should I take in for repairs?
/ 3-Pt Shudder #9
If this is a 3pt implement and it lowers.. thinking that it is the filter is a leap... I'd say more like cyl/piston seal!.. or at worst.. control valve..
soundguy
/ 3-Pt Shudder
Yes it is a 3-point implement. With the engine running and the implement is raised, the implement will slowly fall and then the hydraulics abruptly raises it back up. With the engine off, the implement will slowly lower to the ground. Could this be due to air in the system?
Is the control valve the draft or the SLOW/FAST setting? How is this valve accessed to inspect? Thanks for your help.
/ 3-Pt Shudder #11
I have a Branson tractor that is doing same thing. Drives me crazy. But mine clears up when it is well warmed up, and is mostly a cold temperature thing, such as about anything under 65 degrees. A fellow member suggested that it could be an o ring in the 3 point lift piston and cylinder that leaked some fluid when cold, and causing the position control to try and compensate frequently and hiccup, and then when fluid was warm, and piston and o ring was warm, it swelled or expanded enough to stop the fluid leakage, and the position control now did not have to compensate every second or so.
I have done some research , and thinking on this, and perhaps a hydraulic oil additive that swells the o rings and seals a little to stop leaking might be an answer, without major breakdown and repair.
A couple of additives I found were:
Lucas Hydraulic Oil Booster and Stop Leak
Primrose 532-T Seal Saver
Maybe this could help your issues.
/ 3-Pt Shudder #12
Ahh.. you are describing more of a 'bobbing'.. not a shudder..
bobbing is indicative of a leak and regeneration within a circuit. .. in many cases it is the piston cyl.. not the control valve.. but could actually be anywhere int he pressure circuit.. like a gasket or oring.
got any inspection covers to pull and look for leaks?
soundguy
/ 3-Pt Shudder #13
soundguy
Hey Soundguy,
We just got the injector pump back on our Kubota L260 after almost a year of sitting up and we found our lift is leaking down and jerking back up in the same way as Rockin' G Ranch discribes.
What's going on???
/ 3-Pt Shudder #14
sounds like the same stuff I just explained... leak in the pressure curcuit..
soundguy
/ 3-Pt Shudder #15
When you are bouncing along it is the draft system that is doing the small jerks on the 3pt. the bleeding is a worn O ring. It isn't hard to fix. you will have to take the seat off and the top deck on the tranny. Before you start the teardown. Have the hyd pick the rocker arms all the way up. This will force the piston as far out of the cylinder as possible. This will make it easy to get hold of to pull out and replace the O ring.
Pallet Racking (A65640)
Pallet Racking...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
Snow Plow & Salt Spreader (A62613)
Snow Plow & Salt...
2004 John Deere 693 Corn Head (A66285)
2004 John Deere...
