Tiller Query tiller rotational speeds
/ Query tiller rotational speeds #2
Can anyone tell me the Hi and Low speed range of tiller blades?
Are you asking about 3pt hitch or walk behind?
For my 3pt hitch Woods tiller I'm not sure. I just set my PTO speed to 540, drop it in and let it rip :D
3 PTH model.....
Considering taking the engine off of the 5 hp (1/2 a) 3pth tiller for my SS18 Sears and putting on a PTO to gear box, to V belt drive. No sense
in running a gasoline engine and the diesel JD 2305 engine both. Tiller width a bit narrow but will be better than nothing or a spring tooth cultivator.
/ Query tiller rotational speeds #4
The 540 PTO rpm is reduced to 200-240 tiller shaft rpm depending on model.
jb
/ Query tiller rotational speeds #6
KingKutter II tillers turn 210rpm @ 540 on the pto.
/ Query tiller rotational speeds #8
Thanks from me, too.
Exactly the info I was looking for -- Doing an Electric Motor driven Roto-Tiller, and looking to determine drive ratios to get the Tiller Rotation Speeds correct.
2021 John Deere 6120M Tractor (A63109)
2021 John Deere...
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
Quick Hitch Mini Excavator Attachment (A61572)
Quick Hitch Mini...
2002 John Deere 737 Zero Turn (A63116)
2002 John Deere...
Cat CB24B (A60462)
Cat CB24B (A60462)
2022 Belshe WB14 18ft  12000lb Trailer (A64047)
2022 Belshe WB14...
