Replacing rear lollipop lights - B3030 HSDCC
/ Replacing rear lollipop lights - B3030 HSDCC #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Found and purchased a nice set of amber/red LED lollipops on ebay. Am just now installing them on a new B3030 HSDCC.
I noticed that each side has a little two prong female pigtail hanging unused up there at the lollipop mounting bracket at top of cab. Are these wires run to any cab switches or do they terminate in the cab someplace where they can be switched for rear work lights? I threw on each of the switches and didn't get anything out of them on my test light.
If I could, I'd grab a set of work lights someplace today rig them up if was possible.
/ Replacing rear lollipop lights - B3030 HSDCC #2
Those are for the Kubota factory work lights, the switch, brackets, and bolts come in the kit.
The power wires are above the headliner.
Get the rear work lights from Kubota (only) they match the front lights and are plenty bright.
/ Replacing rear lollipop lights - B3030 HSDCC #3
Ditto on what the WaxMan said. Keep in mind that if you reduce the load on your flasher (assuming our tractors have a standard flasher) enough with the LEDs, you will also need to buy an electronic flasher to make them flash.
Of course there's always a slight derailment of some sort. The new LED's are 3 wire. Red, white, black. The light is mounted into the factory bracket that the old lollipop was in. I grounded the black. I have power from the tractor's hot wire, because my test light will flash when touched to the wire. When applying the tractor's hot wire to either red or white wires on the light, I get zero.
Even taking into account your flasher statement, I took the light directly to a car battery and touched the black to negative and red/white to positive. No light. Obviously I'm no electrician but I thought that this would be fairly simple.
/ Replacing rear lollipop lights - B3030 HSDCC #5
Have you tried grounding the white wire instead of the black?
Ductape, you're a genius and just brightened my day! :)
I guess that I just went by the old automotive maxim of red/hot and black/ground instead of thinking like residential wiring and the black being hot.
/ Replacing rear lollipop lights - B3030 HSDCC #7
I just changed my lights over the black is parking lamp, the white is ground and the red to the flashers, Mine has no problem with the factory flasher.
I hooked up the parking light of the lollypop to my running lights.
I don't know if you seen my post on running lights.
/ Replacing rear lollipop lights - B3030 HSDCC #8
No, I'm no genius.............. but I did stay @ a Holiday Inn Express once!
Man I hate it when I have to scratch my head and then go find advice for something so simple. Thanks for the help. One job out of many to come is now complete.
Of course there wasn't an instruction to be found in the package for dunces like myself. As waxman notes, so far the factory flasher seems to be handling things OK.
/ Replacing rear lollipop lights - B3030 HSDCC #10
Great job you move fast , nice garage to work in too.
For your next trick,
On a semi related note, thanks for posting the headliner removal instructions on another thread. You had to go and do that, didn't you? :D
I purchased a pair of speakers and a stereo after reading how simple it was to remove the liner. Well, now speakers are installed and speaker wires run. Headliner is going back in now and the stereo will wait until the Kubota bracket arrives next week.
Edit: I placed a photo of an installed speaker over in WaxMan's B3030 stereo thread.
Note to self: Stop getting cab improvement ideas from WaxMan and 4shorts!
/ Replacing rear lollipop lights - B3030 HSDCC #12
Ok let me get this straight , you just yook delivery this week on a New B3030hsdcc and you already removed the headliner and cut holes in it because of my post.
Ahh I'm going to have to get liability insurance now.
Do you have any idea how long it took me to get up the nerve to cut holes in my liner. Do you even have 1 hr on the meter?
4shorts, ACHINBAC, mjncad, we have some serious competition here, this guy has no fear.
Good going JJZ, you can tackle anything , that should inspire other B3030 owners to do theirs.
Were the instructions i gave you accurate?.
Were the instructions i gave you accurate?. What speakers and grills did you get?
I didn't want to derail this thread any further, so I posted a pic over on your headliner/speaker thread.
But to answer your question, instructions were just fine. It sounded easy enough so I gave it a shot. All reinstalled now and waiting for a stereo. I just got a set of $30 cheapies from WalMart because that's where I happened to be today. Got a Pioneer stereo with front iPod jack to go with it.
UNUSED IRMC HIGH END MASSAGE CHAIR (A60432)
UNUSED IRMC HIGH...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
2014 Chrysler 200 Sedan (A59231)
2014 Chrysler 200...
Informational Lot - Financing (A61307)
Informational Lot...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
