air dryer for compressed air system
/ air dryer for compressed air system #1
jimg
I really need some sort of water filtration on my compressor and have seen a couple types...dry and refrigerated. Wix makes what looks like the easiest most convenient of the dry types called AquaChek. Filter costs start at $25/ and would need to be changed at least once/yr. Also they recommend a couple in line, one closeish to the compressor and another smaller down line. The other option is to roll my own using a refrigerated system. I see there are some plans on the net for this.
What Id like to know is which way did you go and why. If you rolled your own what did it cost and how effective is it.
ETA: The big question on the 'roll your own' is how to vent the condensed moisture from the compressed air stream. Not sure how to do that.
/ air dryer for compressed air system #2
I use 2 coalescing filters and a dessicant filter on my system.One Coalescing filter is just after my compressor. Then comes my dessicant. Last thing is a coalescing filter with my regulator. My system is hooked up with black pipe and this helps alot. My dessicant is about 40' from the compressor, so the air has cooled quite a bit by the time it gets there. This helps the separation of water. All my lines are sloped and i get as much water out of my lines as i get out of the filters.
If you go with dessicants, you can build your own filter out of a large (6" dia.) threaded pipe and end caps. Get the good dessicant from a pneumatic supply, it changes colour when its wet, and its reuseable (dry in oven) .
What is a 'coalescing' filter?
A big problem w/ my setup is the water sep is way too close to the tank. I like your idea of angled pipe. Is there a drain trap in your system?
/ air dryer for compressed air system #4
I need very dry air to use in conjunction with medical equipment sterilizers...
The most water by volume is removed by the automatic compressor tank drain valve... it has adjustable cycle frequency.
Next the air goes through a refrigerator/dryer which is also automatically drains.
Some of the runs are over 300' with the copper pipe is sloped back to the refrigerator/dryer.
Coalescing Filters are used at the end of all the drops... In a years times each filter will still pick-up a tablespoon or two of moisture,
Finally the units also have a 3M double filter pack that never have any detectable moisture.
Whether manual or automatic, frequent compressor tank draining is the cheapest and most effective.
The old plant actually had large 80 gallon air tanks distributed through out the facility fed from one central compressor. By the time the air travel to the large end of the line tanks the moisture would collect at the tank bottoms and not be a problem. Management wanted to get rid of the tanks and the maintenance draining several tanks throughout the plant and that is the reason for the refrigerator/dryer that runs 24/7
/ air dryer for compressed air system #5
What is your budget and how dry must the air be?:D
When that is decided you could start looking for a system.:D
OK, my interest is really in making something (cold drier) or perhaps buying a dry type unit. As for how dry the air should be I dont know how to answer that exc to say 'dry'. :D Hey, this isnt a rocket science thing...I just want to keep my air tools from dieing prematurely and perhaps squirt some paint. The AuqaChek units looked pretty neat, very simple and convenient. The down side is I would have to replaced the filters. If I could come up w/ a cold unit based on 'junk yard' tailings that would be even better. The prob w/ that is figuring out how to automagically vent the condensed moisture from the compressed air stream.
ETA: Oh wait...I think I understand whats wanted. There must be some sort of moisture actuated valve that opens once water reaches a certain point (its sensors). Not sure thought what that would be called. I think it wold do the job though.
/ air dryer for compressed air system #7
Using that system for the air tools and adding a desiccant type for the paint squirting may be the easiest way to go. As mentioned the desiccant can be dried.:D
/ air dryer for compressed air system #8
A coalescing type filter is a typical water separator. Its basically a membrane of different pore sizes depending on air volume and how "dry" you want your air. The water falls out of the air as it "squeezes" through the pores. That combines with the air expanding in the bowl creates the drying effect.
Having your filters on the end of a long run will help their efficiency alot due to the cooling of the air. I have drains on both ends of my line.
I wouldnt go with a refrigerated dryer unless you have to. My air is plenty dry for painting and sandblasting. Refrigerated driers work great, but they can be kinda spendy.
/ air dryer for compressed air system #9
Automatic tank drain valve, is that what your thinking about? There are several manufacturers of automatic drain valves.
If your only trying to remove moisture for air tools then you don't need to get to high speed. A good coalescing type filter and possibly one of the AuqaChek filters is all you would ever need. If you plan on doing any painting then you should get a desiccant filter. If your thinking big for the future then a refrigerated dryer is the way to go. Refrigerated air dryers are by no means cheap. I picked up a nice used one at a industrial auction so keep your eyes out in the auction listings in the paper.
To my eyes AquaCheck is a desiccating type drier. Media in the filter captures the moisture and holds it. That said conventional descants can be regenerated by heating whereas AquaCheck can't.
Just off hand I don't think a refrigerated system would be hard to build. (I know theyre very expensive to buy and thats why Im thinking of building.) To me a coil of copper to transmit the compressed air thru a cold coil would be all that was needed. The coil would be fitted w/ a trap and electric purge valve to vent the condensed moisture. Im sure this isnt going to be as efficient as a commercial drier but hey it works for a tiny fraction of the price.
Yes, I guess thats what I was thinking of...an automatic tank drain. Im familiar w/ the pressure actuated types...fitted into the underloader...and that wouldnt be so convenient. If I could get it an electric type would be best. It would sense moisture build up in the trap by completing a circuit when moisture accumulated to a certain level.
Thanx for the description of the coalescing filter...I have one in inline and need to move it farther from the compressor.
While not exactly what I was looking for something like this would work too...
Electric purge valve
/ air dryer for compressed air system #12
Ive seen on the net where people have made coolers out of the core from old house radiators. I think they are the "slant fin" type. Basically they're just soldered into a copper manifold on both sides. To increase the cooling, a exhaust fan is mounted in a shroud. The end result is similar to a industrial hydraulic heat exchanger. This might be easier than getting involved with a refrigerated system. The copper cooling lines can be picked up as scrap from remodels. This is probably the cheapest way to get forced cooling for a air system.
/ air dryer for compressed air system #13
You might be interested in making a deliquescent type dryer. They are different from a desiccant dryer as the deliquescent uses a salt tablet that absorbs moisture as it dissolves the tablets. The water is then drained from the bottom, and the tablets are simply replaced. These dryers reduce the pressure dewpoint by approximately 20 deg. F., which would be good for your purpose. The dryer is simple to make, but you are fabricating a pressure vessel, and that is another topic entirely. No filter, coalescing or other can remove humidity, only water vapor. The type of setup Scooby074 was talking about will work, but will only bring the pressure dewpoint to ambient temperature. I've seen where a water mist is sprayed on the fin tube before the fan to make a "swamp cooler", but that just complicates things more. A refrigerated dryer will give a pressure dewpoint of approxamatly 38 deg F, and a regenerative twin tower will go about -40F while molecular sieve type are about - 100F, but I don't think you're looking to spend thousands of dollars:D. Keep in mind the pressure drop from anything you put in the line. Whichever type you use, whether refrigerated, dessicant, or deliquescent, don't forget the filters, as the cleanliness is as important if not more so, than the dryness of the air. I read earlier that "this isn't rocket science". It actually is. There is a lot of engineering that goes into, or should go into an air system. Here is a link to Van-Air, a maker of deliquescent, dryers. They make a fine product. Also look into Wilkerson and Norgren for more info on drying air.
Deliquescent Dryers
/ air dryer for compressed air system #14
Personally i prefer the desiccant and coalescing system. My air is very dry as it is now, but i have been considering adding a fan assisted cooler if i can find the parts cheap. It will improve my efficiency ,reduce the air temp and reduce the load on my desiccant beads.
THe deliquescent system sounds interesting, but the salt used in it appears to be a consumable. The advantage of a (silica) dessicant is its reusable.
/ air dryer for compressed air system #15
No need to get fancy like that. I think you said you just wanted one that would be activated by a raise in the water level. You could easily build one yourself using a simple pneumatic electric solenoid valve that is actuated by a water sensor.
/ air dryer for compressed air system #16
Hard to build one that justifies the effort versus buying the timer type.
I also got some of the valves they use on trucks with the pull cable to drain the tanks.
Ken
Thanx VERY much for the help!!!
Ive seen the variety where a radiator of some sort is air blown over it w/ a small fan. Just want sure how well it would work. Does it really cool the air enough to drop a significant portion of the moisture. Thats the reason I was thinking along the lines of cooling the air around the coil/radiator.
Never heard of a deliquescent type. Thanx for mentioning it w/ the link. Any idea how much the salt tabs cost?
"No need to get fancy like that. I think you said you just wanted one that would be activated by a raise in the water level. You could easily build one yourself using a simple pneumatic electric solenoid valve that is actuated by a water sensor."
LOL, the only reason I mentioned that particular switch was b/c I could figure out how to build the other. :) I figured the timer type would work OK and perhaps come out a bit cheaper. If you could be more explicit that would help a lot. :D
/ air dryer for compressed air system #18
jimg, I've priced one with a water sensor and it was pretty high priced. Think I could build one alot cheaper, but the problem is finding the water sensor at a cheap price. Any ideas on that?
/ air dryer for compressed air system #19
Search google for vortex coolers. You might be able to make one and use it as second stage cooling to drop temperature bellow ambient. We use them to cool cabinets with control systems in hot environment.
/ air dryer for compressed air system #20
From the Kaeser air compressor site :"Highly efficient air-cooled aftercoolers from Kaeser are an economical way to remove water vapor and cool compressed air to safe, usable levels for many applications. They also prepare the air for further filtration and drying.
Compressed air is cooled to within 5ーF to 20ーF of the ambient temperature, and as the air cools, up to 80% of the water vapor condenses to a liquid."
KAESER USA ? Air-cooled Aftercoolers
They're also available watercooled for better performance.
From the Deliquescent site, the salt tabs were around $50-60 for 50 lbs. I dont know how long they'd last. The Silica desiccant I use is around $80 for 1Gal, but its reuseable.
