Backhoe Does anyone make a backhoe to 3 point adapter?
   / Does anyone make a backhoe to 3 point adapter? #1
BruceWard
Central, AR
I have a Kubota B21 and would like to be able to attach a rock rake and box blade to the end of the backhoe instead of removing the backhoe and attaching to the 3 point. Does anyone make a 3 point adapter that replaces a backhoe bucket?
This would be faster to attach as well as providing down force and reach.
   / Does anyone make a backhoe to 3 point adapter? #2
If you convert to a quick attach bucket (~$1000) you can add QA adaptors to the attachments and give it a go, but the results may not be as good as you hoped.
   / Does anyone make a backhoe to 3 point adapter? #3
I think if you are driving the tractor working a ground engaging implement on the end of the backhoe there is a high risk of damaging the backhoe.
   / Does anyone make a backhoe to 3 point adapter? #5
It think it may sound better / easier in fantasy than it turns out to be in reality.
Exactly. The lack of a float valve on the boom being one of the bigger issues. The other being the weight at a distance overpowering the hoe and potentially causing structural damage. But, it could work. Depends on the attachment, the ground, the operator, etc.
jb
26120 (A56859)
26120 (A56859)
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59905)
2019 WABASH...
2014 KENWORTH T800 HYDRO EXC VACUUM TRUCK (A59823)
2014 KENWORTH T800...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
1605 (A57192)
1605 (A57192)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
