TRUCK AND TRAILER TEAM.
/ TRUCK AND TRAILER TEAM. #41
WHICH ONE WOULD YOU PICK
I came across these 2 trailers.
Used 2007 16' tilt trailer dual brakes
$2000.
New 18'7'' dove tail car hauler $2400.
Your OP you wanted an 18 footer, can't beat the car hauler for cars, maybe tractors and some equipment.
The tilt beds are all the rage now for contractors who are taking equipment off and on everyday, not having to deal with ramps is nice.
I'm still looking for a decent used 5 ton equipment trailer, for a reasonable price, been scouring Craigslist and other classified ads. The car haulers are usually a little cheaper but I'd rather have the full wood deck and for my expected occasional use I don't mind dealing with the ramps.
Good luck, JB.
Good luck, JB.
This car hauler has a full wood deck.
/ TRUCK AND TRAILER TEAM. #43
LB59:
(my future neighbor)
I'll give you the benefit of my experience to further complicate your decision.
I have a 2006 F-350 diesel dually usually pulling a 24' equipment 14K trailer. I've added an extra leaf to the pack, a superhitch, and goodyear air bags. I've had my 4000 lb camper in the bed (5000 bed capacity) pulling my small 7X12' loaded trailer with no problem. I've had 4 compact tractors on the 24' trailer for a 600 mile trip with absolutely no problem. (about 18K trailer& load) The deckover is 8' wide, and sits around 32-34" inches off the ground, with a solid reinforced ramp in the back. (easy load & offload) I've got it chipped, and amsoiled throughout, it gets 11-12 mpg loaded, 15-16 empty. Obviously rides better with a load, but very comfortable/manageable without.
Sounds like you don't need/want the dually, so f-250 diesel sound up your alley...6.4 is worse than the 6.0 for mileage, and 7.3 beats the 6.0. Depends on how far back you want to go, and what kind of mileage you're willing to accept. Carefully consider the 03/04 6.0's, they had the issues. Good luck and have fun shopping!
/ TRUCK AND TRAILER TEAM. #44
Which trailer do you like the best?
I don't know but I'm starting to get the feeling that putting a truck and trailer together is going to be no easy task.
Of my trailers I have used the 20' tilt bed the most. In fact I recently sold my goose neck deck over because I didn't have enough use for it. Only have the tilt bed by H&H now and it does all I need it to do. No ramps to worry about either.
As far as the 2 you posted, Its a toss up. I like having a tilt bed but I also like having a larger trailer. Mine has removable fenders makes for easier side loading and no ramps to worry about.
/ TRUCK AND TRAILER TEAM. #45
1*I understand this but how would you load something like this little building that is wider than the space between your fenders?
Had I had a trailer like I'm talking about back in Nov. when I bought this building I could have hauled it myself and saved the 150 i paid to have this truck deliver it.
Sorry LB,
Could not get back to this.
I lost my only brother to a accident.
/ TRUCK AND TRAILER TEAM. #46
LB-
Why are you worried about loading from the side? You can always drive up the ramps to drop your load...
Kyle
I like the removable fender idea, but it still leaves the wheels above the bed floor.
That's what attracts me to a tilt bed.
LB-
Kyle
Which is exactly what I'm trying to avoid having to do.
Loading and unloading with the tractor on the ground is much safer than running up and down ramps with a loader full of stuff.
/ TRUCK AND TRAILER TEAM. #51
All the tilt beds I've seen have fenders, I've only seen a few but never seen a deck over tilt bed, that would probably make for to steep a deck to drive up.
JB.
/ TRUCK AND TRAILER TEAM. #52
True, but you gotta do what you gotta do. It can be done. Also, what ever happened to your rollback idea? That be better for you, a heavy truck, rollback, deckover...and older ones can be had pretty cheap. 1-2 ton rollbacks don't need liscenses.
JB.
Deck over tilt beds are actually fairly common. A lot of construction company's have them. We've thought about getting one.
Kyle
/ TRUCK AND TRAILER TEAM. #53
JD4300, I'm very sorry to hear of your loss.
what ever happened to your rollback idea? Kyle
There is a roll back in the paper for $9850.
There is also a Ford 350 1 ton pick up for $14900 and
A new 17'7'' Car Hauler trailer for $2400.
I must admit 9850 for the roll back is less than 17300 for the
Pick up and trailer.
/ TRUCK AND TRAILER TEAM. #57
LB,
* Did you buy a truck and trailer yet.*
/ TRUCK AND TRAILER TEAM. #58
Back a way's , someone mentioned that older pick ups were not as capable of hauling as newer trucks . News Flash !!! My '84 F-250 4x4 , although it looks rough , has on numerous occasions out hauled any current make of truck from 1/2 tons to 1 ton duals . 2600 pounds of landscape block hardly makes it squat . When we use to have a pellet stove , would haul not 1 but 2 tons of pellets at a time , ( course then I got smart an found out they only charged $35 for delivery including unload and stack :) ) My pick-up weighs in at 5280 with 1 tank full , max I have ever weighed was 10,880 , but had both tanks full and practically entire work shop stuffed behind seat . Was hauling sand gravel mix for cement .
Although load weight is important as is distribution of that weight , driving style is all to often the culprit of bent or broken axles , springs , etc.... . Simply put , normally you just fly down the road hitting them small potholes or those railroad tracks , etc... , when empty , BUT loaded , even with a small load of 500 or 1000 pounds , loaded incorrectly , A repair bill may not be to far behind .
Could tell many a story of loading next to newer 1/2 , 3/4 an 1 ton duals the last couple of years doing all the landscaping to finish our place and watching them freak with 1/2 yard or 1 yard of material and I would have 2 yards dump into bed . The kid in the loader loved it .
Take Care .
Fred H.
/ TRUCK AND TRAILER TEAM. #59
I think Fred's talking about my previous post (#17). I only stated what the manufacturers recommended tow ratings were a few years ago. Any idiot / person with a pickup can hook up to a 20K loaded trailer or put 4K into a pickup bed if they choose to do so and the truck will probably pull it although stopping may be a problem. I just don't want to be around them on the road. I have a neighbor who regularly hauls a 18K excavator on a 20K goose neck with a 1T dually. I estimate his loaded trailer weighs about 24-25K and is well above what his truck is rated for. That doesn't make it legal or safe. My posts are only to assist the poster (LB) in choosing the right vehicle and trailer for what he wants to do and be legal. I have a 2500HD with Duramax / Allison that is rated for towing 15,800. I know the truck could easily tow 25K but I won't do it. Have I ever exceeded my rated capacity? Sure I have. I think everyone who owns a pickup has exceeded its rated capacity at one time or another whether they realize it or not, it just doesn't make it legal.
Fred H.
So would you believe it when I say The 1971 3/4 ton Ford F250 Camper Special I had would haul 3000 to 4000 pounds with out a problem?
LB,
*Haven't found either one yet and it don't look like it's going to be easy either.*
GADNER DENVER PUMP ON A SKID (A60736)
GADNER DENVER PUMP...
2007 Hyster S30FT 3,000lb. LP Forklift (A60352)
2007 Hyster S30FT...
2016 Caterpillar 349FL Hydraulic Excavator (A56857)
2016 Caterpillar...
John Deere 12in Channel Tooth Bucket Excavator Attachment (A60352)
John Deere 12in...
2025 Pabreak 80in. Hydraulic Dual Cylinder 4-in-1 Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
KENT HYDRAULIC HAMMER ATTACHMENT (A60736)
KENT HYDRAULIC...
