3ph trailer hitch
/ 3ph trailer hitch #1
valleydweller1
Willamette Valley, Oregon
Kubota B7510
I put my Kubota BX2230 on CL last week for sale. So far I have had 3 calls; 1 for the tractor and 2 for the trailer hitch implement. It's just an old receiver hitch that I cut up and welded some steel on to build a hitch. Apparently there is a demand for these?
I'm thinking of building 5 of them as a "test marketing" and seeing if anyone bites. I've got a pretty good idea of the time and cost involved for these first 5, what do you all think I could charge for them?
Greg
/ 3ph trailer hitch #2
I think they are a great first attachment to a new owner. I made one due to getting things in the barn and moving things around. I would do a few and see what happens? Ebay has a few listed 89 and up! BTW, Nice job you have!:D
Dan
/ 3ph trailer hitch #3
Greg
Tons of people are making 3pt trailer hitches of various design.. mostly based around a drawbar with an a-frame, and then you add a ball, and some have a toungue welded on.. and some have the reciever for the toungue welded on... Tisco even makes a kit to turn your 3pt drawbar into a trailer hitch ball carrier.. 25$ for the a-frame kit.. you supply the drawbar and the ball...
browse around and see what the other 99 suppliers are charging..
soundguy
/ 3ph trailer hitch #4
It does seem folks like those things. I have seen them from the about $75-$300 depending on the design (some can take a gooseneck)
Personally, I weld square reciever tube on most of my implements so I dont have to take them off just to to move a trailer around. Just pop the ball on and go.
/ 3ph trailer hitch #5
Greg,
There's alot of them out there, you'll have to come up with something unique about yours, there's still room for new ideas, always some new receiver accessory coming out that every one wants.
I bought one of the more expensive models and only used it a couple of times, I use the one I made for my bucket almost every day, toyed with the idea of marketing my "bucket buddy" something that anyone with a loader could use, but there so easy to make most guys would just make it them selves.
/ 3ph trailer hitch #6
This a very utilitarian one I came up with. I put a 2" ball on the side. It is just a tad off center. I also use the chin and lift stuff off of ground or pull t-post out of the ground.
JC,
P.s. John.. I like your bucket hitch system.. only draw back is that you need to just go backward all the time:D
/ 3ph trailer hitch #7
I made almost the exact same set up as JC - Jetro except I added a bolt on reciever hitch under the draw bar. It works great for me.
/ 3ph trailer hitch #8
JC,
I know that this thread is a little old, but the information is timeless. I'm new into the tractor world and am reviewing all of the "Make It Yourself" entries. I'm now up to page 33 :)
JC, I have a question.
How do you pull a t-post with your chain? I don't see a hook and I have a number of posts to pull this spring. I'm making a version of your trailer hitch and would like more information on how you use the chain.
Thanks,
Clem
/ 3ph trailer hitch #9
Greg,
I use the one I made for my bucket almost every day, toyed with the idea of marketing my "bucket buddy" something that anyone with a loader could use.
JB4310
1)
On your bucket hitch, when you hook up to a trailer does the front of
your bucket (CUTTING EDGE) hit your trailer or the jack on a trailer?
2) When you bolted in on the top, does your bolts come out on the inside of your bucket?
(on my bucket there is a hollow space on the inside of the bucket at the top, was just thinking about welding it on top)
Several years ago i put one on the inside of my bucket, i bolted it in
and when i don't need it i take it out. but when i go to hook up on any kind of a trailer it is hard too see, because it is down so low.
I make extension hitches, i have a slide in camper for a pickup truck
and pull a boat behind, if i didn't use the extension hitch the boat would hit the camper if i made a sharp turn.
(If i put the hitch on top of my bucket and use a extension hitch, do you think it would be better to hook up to a trailer)
/ 3ph trailer hitch #10
Do you happen to have a bucket that disconnects easily. Mine comes off with two lynch pins.
What I did was weld two 3X4 rectangular tubes across where the bucket hooks in. It really strengehened up the loader and is better for the bucket when on as it keeps the bucket from torquing when just using a corner.
By rolling the frame forward with the bucket off you have a perfect flat on the 2X4 to put a ball on and it is out of the way and is also handy to put a chain on when picking.
/ 3ph trailer hitch #11
JB4310
1)
1) The cutting edge doesn't hit any part of the trailer, on rough ground it may scrape the ground do to the hitch being high on top of the bucket, I have a small drop insert, a longer drop would be better.
2) Read my thread, I would probably weld it on a plate then weld the plate on now.
3) (If i put the hitch on top of my bucket and use a extension hitch, do you think it would be better to hook up to a trailer) Not sure.
I'm not sure what you plan on doing with yours, for me trailer jockeying is not the primary use, but it sure comes in handy, I do drive forward also as well as backwards, sharp angles will catch the trailer with the bucket sides. for serious trailer moving with the tractor, you can't beat the Flex Point or that EZ Mover modified horizontal draw bar.
Origanal thread, with more pictures.
http://www.tractorbynet.com/forums/...ng/93535-bucket-buddy-instead-weld-hooks.html
Good Luck,
JB.
/ 3ph trailer hitch #12
Thanks for the original thread on this!
Great pictures and a great setup with the Imatch, most of the time my backhoe is on, that's why i like the hitch on the bucket, if my BH is off the tractor then i just use the draw bar that came with the tractor.
I need to get a quick hitch, i don't know if you saw the thread on
connecting a pto coupling, there was a post about a hitch from JD called a (AUTOHITCH), that is a really good setup.
Thanks for the Thread
/ 3ph trailer hitch #13
Thanks,
Clem
Chem,
Sorry I did not respond to your question as I forgot all about this thread. Since I have taken the pic I added a grab hook to the chain. Let say I'm raising something up where there is a lip I can hook it up with the lip and partially lift and drag... nothing really precise. I can wrap the chain around a fallen tree trunk and lift the front some and drag easier. Heavy duty dragging/pulling and the draw bar is the proper way of pulling things. I have a hitch ball that I can easily use to to pull my trailer but have not had a need for it yet as the carry all is better for direction change and tight spots than trailer. Nothing can be easier than pulling a t-post, I just back up to the T-post, wrap the chain around the post an let the hook grab the chain and pull it out like the tooth pick out of warm butter.:D
JC,
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2018 CATERPILLAR 289D SKID STEER (A65053)
2018 CATERPILLAR...
2005 Terex TX55-19 4x4 5,000lb Rough Terrain Telehandler (A64553)
2005 Terex TX55-19...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
