No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up?
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #1
solomon
New Hampshire
M-F GC2310TLB
I have a 2007 M-F GC2310TLB I bought new from a M-F dealer in the Concord area here in N.H. in May '07. I now have 100 hours on the clock. It was serviced per the manual. This winter whenever the temperature gets below 40 deg F the tractor doesn't have any hydraulic power though it can move forward and back but no steering power nor loader lifting power. The sight glass shows the hydraulic fluid is at the correct level. Operated fine last winter no matter what temperature, only difference is I kept the backhoe on last winter, disconnected it for this winter.
What's up?
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #2
I would be calling the dealer. Is the warranty still in effect. My guess would be a pluged hyd. filter. When it is warm the oil is thin and will pass through the filter. when the oil is cold it is thicker and wont pass through the filter.
Bill
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #3
What's up?
Aside from the obvious (filter is plugged-fluid too thick..doubt that's it though)
....are the hydraulic lines that ran your backhoe hooked up right ..ie: are they suppose to be in a loop? if yes..are they? If everything is in it's proper place, I agree with Bill, call the dealership service department..that ain't right.
BTW welcome to TBN
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #4
My guess would be that you have water in the system and it is icing the hydraulic return. The pump is then running dry and will fail MUCH sooner than you want.
The HST and the PS/hydraulics have different pickup locations and filters.
jb
Thanks for the reply. Before I brought the dealer into it (pickup/delivery, etc.) I was hoping to find an easy cure.
Thanks again.
Checked that first thing, everything is hooked fine. Doesn't seem to be as simple as I hoped so you guys are right - dealer is next.
Thanks again.
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #7
Do you have a service manual? If the hydraulic filter has been changed recently, I'd be looking for a pickup screen (non change-able filter) in the system. I had the same problem with a tractor I used to have. If you have a screen, remove it and clean it good. I believe kerosene can be used to clean it. They get gummed up and will not allow the hydraulic oil to flow at the lower temps when it gets thick.
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #8
How long do you let it warm up? A few years ago, a neighbor bought an old Oliver 85 hp tractor and the first cold morning, he went out and started it, let it idle a couple of minutes, then found the same problem you have; no power steering or 3-point lift (he didn't have a front end loader). He left it running, while he went back in the house to call the dealer from whom he had bought it. The first thing the dealer asked, was how long it warmed up. By that time, the tractor had been running about 10 minutes, and when he went back out, everything worked fine. Now of course this was a tractor that was about 25 years old, so maybe not similar to yours.
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #9
Sounds like you need to wrm it up. I have a dx35 HST at -20 it takes about twenty minutes for the laoder to lift. A trick to use If a HST is to leave it in neutral and hold the fwd pedela down thne the reverse. Give it ten minutes or so to warm up first then do this.. It circulates the fluid. I jsut throw the nipco on it for twenty minutes while it is warming up. then take it slow until it warms all that hydo fluid up.
Thanks to everyone - appreciated the helpful hints. Turns out it was water in the hydraulic fluid. Once the water freezes - no matter how long I let the tractor warm up, and I let it warm for an hour once - no go. Stopped by the dealer last week where I learned the 2007 GC2310TLB has a hydraulic pump vent tube just aft of the seat that is exactly where water collects and gets drawn right into the system...you woukd think the M-F engineers in Des Moines would know about ice.
Today was the first day above freezing we have had in weeks and everything worked as it should. But just to get ahead of the situation, I drained the fluid, changed the filter, and moved the vent tube.
Chasing another below freezing problem though: below 32degF I have to run the charge to the glow plug for 3 to 4 minutes to get the engine to start (battery came with the tractor, has a 100 hours on it, and holds the proper charge), the dealer said it should only be 20 to 30 secs. They didn't offer to deal with it even though it is under warranty (I will eventually force the issue) - anyone have any ideas?
Thanks in advance
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #11
Low compression ? One or more bad glow plugs ? Turning over too slow do to summer weight oil or bad connections to starter or ground. Can't think of anything else.
Thanks 638. Double-checked, and all those things are good. It will be the dealers turn to look into it as soon as the snow melts around here (another month maybe) and they can get a trailer to it!
Sad to say though (because I really like the tractor when it runs properly), I am starting to learn just how poor M-F dealers are with customer service. I have asked my dealer (Concord are of NH) twice for help and they could care less.
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #13
In addition to all the correct stuff 638 mentioned, there are a few others. You could have summer fuel in it that is starting to cloud. (The wax component of diesel fuel crystallizes and grows into flakes like snow. That is what causes the fuel filter to clog up). It could also be that there is water in the fuel filter, fuel lines, fuel injection pump, etc restricting the flow of fuel. I would get a product like Diesel 911 and follow the directions. AND add enough #1 diesel (or kero) to fill the tank. AND add a 3x dose of fuel injector cleaning additive with cetane improver. Then run the snot out of it for a couple hours and see if that helps. Also, check for any place where diesel is leaking out as air can be leaking in. A small air leak will give the same symptoms.
Given the issue with water, my suspicion is that the prior owner's maintenance habits may have been a bit lax. Oh, also don't forget the simple stuff. Check all fuses and wires. Fuses should be good and down tight and wires should have clean, tight and bright connections. Pay special attention to the ground wires. They are often loose for some reason.
jb
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #14
solomon- Are you familiar with diesel fuel additives? I learned that it's really a good idea to use an additive like Power Service in the white bottle to lessen the prospect of fuel problems in cold weather. I use it all year 'round just to be one the safe side. I figure it's cheap insurance against fuel gelling. It's sold in auto parts stores and Walmart.
That might not be related to your current problem of hard starting, but I was glad that someone told me about it. Fuel gelling is a problem I don't want to have to deal with.
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #15
Thanks in advance
Do you know if the glow plugs are working. Maybe one or two are dead.
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #16
My big tractor (100 90 Fiatagri, Heston) has a fuel preheat chamber rather than glow plugs.
Even on a bitterly cold day I can get the old girl to start with some patience and 10 seconds worth of the preheat switch.
I second the motion on fuel additives for the winter.........
Last but not least, does your tractor have a block heater? I have found that the MOST fool proof way to get my big AG running is to let the block heater run for a half an hour before I fire it up...... MAN it likes that!!!!!! all 6 fire up with a roar, nearly instantly!
My "little" tractor is a 3710 HST, it has plugs and has never failed to start, even in 20 below weather....... winter fuel treatment goes in the skid tank every fall.
/ No hydraulic power in my 2007 M-F GC2310TLB when temp is below 35 deg F. What's up? #17
Water in the hydraulic oil & cold weather, not good results. You'll probably need to change the oil a few times, or flush it real good. The screen on the side is where you need to concentrate your cleaning efforts, thats the suction screen that is freezing. Do yourself a favor and don't let it run too long while not getting oil, or you may have a more serious problem.
As for the starting issue, I would have the glow plugs checked. I would think with fuel additive and a good battery it should start pretty good.
Oh, and I wouldn't say all MF dealers have poor service. You can't really group them all together.
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
John Deere 5105M (A53317)
John Deere 5105M...
2010 Chevrolet Colorado LT Ext. Cab Pickup Truck (A59230)
2010 Chevrolet...
2025 44in. HWG44 Hydraulic Mini Log Grapple Skid Steer Attachment (A59228)
2025 44in. HWG44...
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2017 Case CX145D (A60462)
2017 Case CX145D...
