Engine
/ Engine #6
I've never had trouble, nor have I read any posts that I can recall where someone had issues with the engine. Then again, I've not heard of anyone with even 1000 hours on the engine either.
My only gripe is that in 30 years and 7 different diesels (Mercedes, VW, and Ford), this engine ranks far and a way as the hardest starting in cold weather. Aside from that, my engine has no discernible oil consumption, good torque and reasonable noise levels.
/ Engine #7
Interesting. Our 1523 has never failed us. All we do is cycle the glows, depending on how cold, up to 25 seconds, give it just a slight bit of throttle, and crank, if fires right up.
Wonder why the GC owners seem to have an issue. Ours is a late 07 1523, got 130 hours on it now. 1000 hours will not be too hard to attain.
/ Engine
Thanks - I guess there is no reason to dicuss it - maybe I'm to used to talking sleds (snowmobiles).
I'll look for a picture at Iseki, can't find one here. Try to figure out what indirect injection is?
Thanks again.
/ Engine #9
Thanks again.
What are you looking for pics of?? I can take some from our 1523 for you.
/ Engine #10
I hadn't started my 2310 in about 2 months, not even a charger on the battery, so I ckecked up on it today since it has been cold here in Ohio. Turned the key to glowplugs for about 10 secs. and turned it to start and it fired right up no problems. The only hard part of starting over auto based diesels is you are the glowplug controller.
Doug
/ Engine #11
Doug
Did you move from TX to Oh?
/ Engine
WILLIAM...
If you have time to post afew that would be great.
TX2310
Thanks for the link.
So...
How does the 100 #'s of pressure drop - from the pump...when you shut it off?
The dealer said I could raise the HP by incresaing pump pressure? :rolleyes:
Is that true?
/ Engine #17
In the or similar engines department, in addition to one of these iseki "E" series engines I own a Toro Reelmaster with a similar 3 cyl. Mitsubishi engine. The Mitts now has 3700 hours on it and it runs fine.
/ Engine #19
Bingo! Same engine as in GC2310 series. (I thought it was, but data plate confirms it.... Man, is that thing teensy -- and well hidden!:D)
/ Engine
Great thanks a lot - looks like we will have to build a stainless muffler.
So - any info on more HP if you increased the pump pressure....that is what the dealer said - to bring it up to the 2610HP?
Thanks
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
Pallet of 12 Metal Shelves (A65579)
Pallet of 12 Metal...
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
2016 Ford Escape AWD SUV (A64557)
2016 Ford Escape...
2023 KOMATSU D51EX-24 CRAWLER DOZER (A65053)
2023 KOMATSU...
2018 MACK PINNACLE (A65643)
2018 MACK PINNACLE...
