Re-routing exhaust on JD 3005
   / Re-routing exhaust on JD 3005 #31
Looks great guys, I also feel the vertical exhaust is the way to go. That was the first thing I did when we got our little Cub Cadet diesel. Thankfully the exhaust is already side mounted, just had to unbolt the muffler, rotate it 90' and get an pipe extension. The pipe I used is the factory Kubota pipe for a B6200 tractor. Just clamps right on the factory muffler. Only rarely do I get exhaust in the face, usualy because its very windy. Then it only lasts a second or two. Before with the muffler pointed forward, I was running in a cloud of fumes all the time. Cheers Mike
   / Re-routing exhaust on JD 3005 #32
Nice work Botamike. Riding around breathing that diesel exhaust all day will kill ya:eek:.
   / Re-routing exhaust on JD 3005 #33
I just plowed snow and I have to say the vertical exhaust seems quieter. I think because there is a short mostly straight path for the exhaust there is very little sound coming from there. The biggest noise now seems to be from the engine itself. I have the exhaust turned to the side the exhaust is on and I think I will keep it like that. I'm happy with it.
Included a couple more pictures that I just took with my phone.
   / Re-routing exhaust on JD 3005 #34
Here's a couple of pics of how the vertical exhaust lifts off so you can open the hood.
Sincerely, Dirt
   / Re-routing exhaust on JD 3005 #35
I haven't driven it, just started it after I finished the install. I suspect I will point it to the side or maybe front. The vertical exhaust is much larger in diameter than the horizontal and a shorter run so it isn't as much back pressure. It seems to be quieter and has a more throaty sound. The extension cord goes to my block heater which since we are near 6" of snow will be used this morning.
I don't expect to smell much fumes. The exhaust is now the configuration of every tractor I've ever driven until this one and its never been a major problem before.
Your going to want to point off the left side, this will keep it out of your face
Tom
   / Re-routing exhaust on JD 3005 #36
That looks nice. With the exception of one, every tractor I have ever owned had vertical exhaust, and this is the first time it has ever made me about sick.
Was it still the anticipated $300 or is it less?
   / Re-routing exhaust on JD 3005 #37
The kit was $240 and then it cost about $40 to get a 3 3/4 inch hole saw. The hole saw would have been less if I would have been willing to wait for an online order.
   / Re-routing exhaust on JD 3005 #38
Sear's has a 3 3/4 hole saw online for around $12 if I remember correctly. You just need the guide bit it slips on to.
   / Re-routing exhaust on JD 3005 #39
Rear exhaust will kill you if unit is running and you have to do a 3 pt change out.
   / Re-routing exhaust on JD 3005 #40
That's the one I didn't want to wait for. The one I got locally was about twice that.
CRAFTSMAN TABLE SAW (A54757)
CRAFTSMAN TABLE...
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
UNUSED IRANCH 1RTPL 10,000# TOW POST LIFT (BLUE) (A57193)
UNUSED IRANCH...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2021 BOBCAT S740 SKID STEER (A52707)
2021 BOBCAT S740...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
