Snowblower snowblower ideas please
/ snowblower ideas please #1
riopoco
barriere, bc canada
jd 790
We have a jd790 and are desperate to add a snowblower to get rid of all this white stuff! Budget is limited so am thinking of attaching a snow thrower unit that normally attaches to the front of a garden tractor. Say something like a toro 42". Does anyone have any experience in rigging something like this up?
Thanks
/ snowblower ideas please #2
Garden tractors often have vertical shaft engines and the front snow blowers are driven by a belt off of a pully at the bottom of the engine. I suspect your tractor likely has a mid PTO facing forward. I thought about doing something similar but it would be an expensive experiment to try and remove the pully drive system off the blower and fab a shaft drive back to the tractor PTO. Cheapest would be to buy a used blower for your 3PH. ( not sure how easy they are to find this year is some parts of the USA)
/ snowblower ideas please #3
I'm with David. Adapting a garden tractor syle blower will cost more for the average person to adapt than its worth. A used rear PTO blower will by far be your best bet. A few years ago i bought one for seven hundred dollars, but there are plenty of members here who have done much better than that.
/ snowblower ideas please #4
Welcome to TBN:D
I rear 3PH blower will probably be the cheapest way to get blowin'. Used front blowers come up rarely for sale but it sounds like your in a hurry! Does your machine have the mid-PTO?
Fill your profile out and let us know where your at, someone close may be able to help you...;)
/ snowblower ideas please #5
A friend of mine with a Kubota uses a rear-mounted snow blower in Winchester, Va. It's by far cheaper than a front mounted one. Long as you're comfortable either keeping your head turned to look back or kinda sitting sideways to see, it's a good way to go. I've a rear blade that I use, usually used while driving forward but in deep snow, think it would be better to push the snow in reverse. The rear blade is much faster than using the FEL.
Ralph
/ snowblower ideas please #6
Thanks
Is the wheel base of that JD 790 less than 42"? You need to have a snowblower at least as wide as your tires or you will be packing snow before you can get to it and blow it out of the way. I agree with the others and would say get a rear blower if you can.
rim
/ snowblower ideas please #7
I'm using a FEL, a rear blade, and a 3PH 60" snowblower. I love the blower, cheap, and POWERFUL! We got 18" the other night and it walked through it like it wasn't there. You should be able to pick up one for under a grand if you watch for craigslist and auction specials.
/ snowblower ideas please #8
Obviously winter is not the best time to be looking for a snowblower... I have a 42" MTD snowblower that I adapted to fit my Craftsman 21 HP lawn mower. It works ok and is just wide enough for the mower but wouldn't be wide enough for my small Kubota. The quality of the metal is also lacking on it, I think the kubota's torque would be able to bend it up. On my MTD, which is a 2 stage, the shaft comes out horizontal and then a belt takes a 90 degree run to go under the mower. I was thinking about running this shaft to the spindle on the front of my Kubota with a clutch but dropped the idea. Like mentioned previously, you would probably be better off with a rear one, sometimes they are cheaper than a new lawn mower style one (run over 1k). 2 stage is best. Good luck.
/ snowblower ideas please #9
Another post on here about snow blower performance and some having trouble blowing heavy slush.Although my 3 point PRONOVOST,doesnt seem to be affected by it,i chose the rear blower,so i wouldnt lose my front end loader,its still there to clean up anything the blower couldnt.Rear blowers arent bad on the neck if you can adapt to sitting sidesaddle on the seat,thus your only turning your head a little.In my situation having my loader on is priceless for other tasks in the winter like getting in the fire wood.
ALAN
Thanks for everyones feedback. Yup I was in abit of a panic as it has been snowing non-stop it seems for weeks. So I think after all the input I will just have to keep looking for a rear-mount snow blower. Any ideas as to what size a blower is too big for your machine? Afriend offered me his but just the weight of it was only about 100lbs shy of what my 3ph can handle, so thought maybe once the snow was in it that I would be causing myself a problem if it became clogged or something.
/ snowblower ideas please #11
I am not sure of the HP of your tractor, but my experience with my 30 HP Kubota and a 60" 3-PT snowblower has been exceptional. With the bucket loader in the front and the blower in the back there is nothing that stops me - even on a long hill of a dirt road. JRW of Canada made mine and it has been a beautiful machine - highly recommend it.
/ snowblower ideas please #12
If you can try your friends I would start there, I wouldn't be so worried about the weight as long as it's under the limit. From reading these forums, it seems the smaller under 20hp machines should be running 48" and the larger ones 60".
/ snowblower ideas please #13
Ithink the horse power [pto]rule of thumb is 5 hp per foot of blower.That said any thing larger ..go slow on the first pass:)
If your friends is 100 lbs shy ,your good to go
ALAN
Thanks everyone for the great ideas. This site has been great in giving a new comer like myself some valuable real world ideas on what works (or not) with our smaller tractor. She is a 27hp 4wd tractor and has been great so far. It came with a small backhoe which is probably only useful for digging holes to plant trees but the price was right.
Thanks again.
Henry
/ snowblower ideas please #15
How about buying a lawn tractor that fits the snow blower. I bet that would be the cheapest. I much prefer this myself. This is the rig I use
This is about 18 inches of 24 I got out of this storm. I have never had a problem with this walking through what ever I put in front of it.
/ snowblower ideas please #16
I too suggest checking your area craiglists and other used stuff sites for a PTO 3 point snowblower.
Last winter we had way too much snow :( My back blade/loader combo couldn't pile the snow any higher. Also, the novelty of clearing snow with my tractor had worn off as well.
I checked the "for sale" sites and ended up posting a "wanted" ad to which someone responded back to. He suggested his neighbor might have a used snowblower that was 5 or 6 feet wide. I called the guy and sure enough he had an Ontario Mennonite made 5 foot Agrotrend. I went to see it and it was like brand new;even the stickers were like new. I paid the man $700 and we loaded it on to my truck.
No more snow banks :) My 30HP (22HP at PTO) tractor throughs the snow up to 50 feet. I love my tractor and snowblower ;)
DELTA UNI SAW (A62131)
Kubota M7040 Tractor (A61166)
Kubota M7040...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63118)
2020 Takeuchi...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
