front weight bracket
/ front weight bracket #1
chris28
central kentucky
2002 kubota bx2200 1998 john deere 6210
ok, i know i have posted this before but i need a picture of the front weight bracket for the kubota bx2200 and a price
/ front weight bracket #2
I don't have a picture of the bracket, but, I can tell You It is $95.00 plus the bolt kit, Which was priced to me at $6.00 per ($6.00 X 5)weight. The weights were priced at $60.00 each (5 Total)
/ front weight bracket #3
I had contemplated buying the weight bracket and weights for my BX 1850. I found some (45# each) generic small suitcase weights at a mower shop. I don't know what they came off of but they have the straight slot in them just like the larger farm tractor weights. I just slid them over the front part of the frame. I have three and could fit another on there quite easily. I believe these are the same weights that JD sells for thier mowers. In my case I paid $50 for 125# of weights and didn't need a special bracket.
/ front weight bracket #4
I ordered a bracket and bolt kit Myself this morning and should have them in a couple of weeks, I can take some pictures then, If You are still wanting to see one.
thanks sorry been busy whyere did you orderthe bracket at
/ front weight bracket #6
I ordered it from Steve Barlow in Somerset,Ky.
/ front weight bracket #7
See If this doesn't answer the question.
/ front weight bracket #9
Give me some time , I have all that information and will try to post it.
I thought about that route as well but with the cost of steel and painting , I found it just as cheap to just buy one outright.
/ front weight bracket #11
here is a series of pics from RiverV:
thanks for the pictures im sure i can make it im going to go draw it now
/ front weight bracket #13
Very handy to have. I made mine without this knowledge but adapted construction so I can use the Ford skidsteer weights I already have. Will also use kbota weights if I ever find any used.
Front weights can be very handy.
/ front weight bracket #14
Chris, Post some pics of the finished product, Please.
