BH90 fluid leak
/ BH90 fluid leak #1
RPK
Eastern CT
Kubota L3130 Cub Cadet 1554
There is hydraulic fluid leaking from the top of at least one of the valve assemblies on my BH90. Even without operating the BH the harder I work the tractor the greater the fluid leaks. I had a problem a while ago with one of the stabilizer valves. I had a local tractor mechanic take it apart to find out that one of the o-rings was twisted up. That one o-ring cost $30.00 (yikes)
Has anyone had this problem yet? I'm not much of a mechanic but I would like to try to fix it myself. Any advise on how to take the valve apart would be a great help.
Thanks alot
/ BH90 fluid leak #2
hey man I have the same hoe and the same problem, I looked at the explodedview and it looks like a simple oring. It doesnt leak too bad, but when I do tear it down, I will just go to the local hardware store and get a regular oring. the hoe will never know the difference and it will cost about .10
Dont get hung up on some OEM oring. An oring is an o ring:)
/ BH90 fluid leak #3
Dang man, I guess we all learn something new everyday.
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
2006 Ford F-350 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-350...
Caterpillar 977L Track Loader Parts and Service Manuals (A63117)
Caterpillar 977L...
208735 (A60430)
208735 (A60430)
Fimco 45 Gal Sprayer (A64119)
Fimco 45 Gal...
