Snow Equipment Owning/Operating Snow clearing
/ Snow clearing #21
I have a rear blade, but I prefer using my landscape rake (since I can't afford either a snow blower or a plow attachment). Something that has really helped me this year (I have a Kubota 3400) is adding Calcium (whatever) to my tires. It has been the best overall $230 investment I have made, and I got to use it moving snow the last 3 days. Wow! What a difference in traction, handling, etc.
/ Snow clearing #22
i'm experimenting with a graphite paint product this year. the farmers use it on combines and such to help keep things flowing. i've already painted my backhoe bucket to see if it will help the wet clay empty out. next is the bottom of the mower deck, front face of the back blade and inside of the FEL bucket....
amp
Sounds very promising.... what's it called? And who sells it? Thanks.
AKfish
/ Snow clearing #23
The pros who plow use a product called Fluid Film by Eureka which is a spray rust proofer and lubricant and is Lanolin based. It helps snow slide off blades, impellers, chutes and keeps grass clippings from sticking to mower decks. It keeps tools from rusting. Once you start using the stuff, you will find hundreds of uses for it. The stuff is kind of pricey if you buy it in the single aerosal can running about 7 bucks a can at the local John Deere dealer, but you can usually find it cheaper in cases or by the quart or gallon. You can email the company and they have been very good about sending out samples for you to try just mention you are light agricultural and do mowing and snow removal.
Fluid Film
Previous discussion about Fluid Film on the forum:
http://www.tractorbynet.com/forums/owning-operating/111053-fluid-film-mo-deck-whats.html
/ Snow clearing #24
I could use some help here too with snow removal. I am getting frustrated at this point. I have a JD 1050, 4WD. I have about 1/4 mile of lane gravel, and the lane is poorly designed. We will fix the lane in upcoming summer months since it is the lowest point anywhere, and the snow piles there and is difficult to move anywhere. But for now, we are stuck with what we have.
The JD now has tractor tires on the front, which helped, but still has turf on the rear, and they are wide. The only way to change that is buy new rims and tires. I have chains on the rear, which also helped some. I have a small bucket on the front, which is OK for some things, but not really the lane. I have a blade on the rear. The entire combo just doesn't work well for removing snow. If you angle the blade to get it off the lane, as soon as the blade gets into anything deep, it kicks the rear of the tractor over, and leave the snow in a big pile. Even the front doesn't dig as well as I had hoped. Traction seems to be my biggest issue.
So what suggestions do you have? I haven't found weights for it. I think it could use front and rear to be honest. I have a bunch of lead pigs availble, but don't know how to mount them to the tractor (on the rerar at least). I have thought of liquid filling, but hear there are drawbacks to that also. Do I throw out the chains, and get new rims and tires and chains for the rear? I'm desperate here!:eek:
/ Snow clearing #25
We have about 6" of snow here this morning...Suppose to be going away later on this week, but, I'm gonna help it along today...Orange power!
Don
/ Snow clearing #26
I think we had about 10" by yesterday morning and then it seemed to snow most of the afternoon.
Blowing a path to the cellar door, mainly all down hill so I have to do this every storm or I might not be able to get back up the hill!
Today it is snowing again and the local weather report is an estimated 8 to 20 inches depending upon location. I guess I can expect close to 20 inches. Some are talking about a repeat of last year! It seemed like we had two storms a week through out the winter really makes one wonder how nice it is in the no-snow zones of the country!
/ Snow clearing #27
Wayne. How is that cab on your rig? Was it expensive? Does it work well to keep you warmer? It it hard to keep the vision clear? I would love to fab one up for my 1050 JD. I need to get it able to move snow properly first though.:confused:
/ Snow clearing #28
in response to the coating question:
it's called EZ-Glide graphite based coating made by Van Sickle paint company out of Lincoln, NE. i get it at the local Orscheln store (hardware and farm supply) but you could probably order from them direct or find a nearby distributor...
i'll start a new thread later to report how it works.
amp
/ Snow clearing #30
Conservation,
I have the younger brother to the 1050 - the 950; it's the middle child as there is an 850 too. In any event, I've got turfs with 4wd and it has been fine this winter clearing snow with the fel and a rear blade. I basically use the fel and then give a finish touch with the blade (I set the screw so that the 3 point only goes down to the desired level and I think you have the draft sensor control which would be a bonus). I just got the 950 this past summer and I believe the back tires are liquid filled but I don't know how to check for that yet.
I've had no need for chains yet and that's been with at least 6 or 8 inch snow falls....haven't spun tires in the least. You don't give much detail (and I don't have near the length of a drive) but I would suggest using the fel and when it begins to fill and bog down, veer off to the side and leave the snow there. When you get to the deep part of the drive, clear it on a 45 degree angle. Sounds like you need liquid in the back tires.
/ Snow clearing #31
I think I have figured out that the rears are considerably wider than the originals. Wide is generally bad in the snow in my experience. No liquid yet, but I am considering it. The thing that concerns me with filling is that I mow a lot of hills in the summer. I am afraid that the extra 800#'s will mean that I don't have enough power on the hills to go up in the gear I am used to. These are big long hills and it is rough mowing, so the engine is working full tilt anyhow. I really need to do better in the snow, but don't want to ruin it for the summer. I could get a set of winter tires that were narrower, and fill them. I would love to add weight somehow, but the factory wheel weights are outragous, and I haven't figured out how to mount the lead pigs I have availible to me. I use the rear blade, so I can't do anything that limits its use. My lane is poorly designed, and I think this spring I will change it for the better. It is all in a valley, and I don't have anywhere to put the snow. A blower would be a great answer, but I can't afford new right now, and haven't been able to find a good used yet. I'm still looking at front chains, but need more help from the rear too. I would love other idea for adding weight, or even using the lead that I have. These things are just so compact, it is hard to find a good place to add the weight. My bucket is narrow, and I run over snow with the rear as soon as I start. One big problem I have is when the rear blade is angled, the back of the tractor just scoots over as soon as the blade hits any deep snow. No rear traction. The chains helped a little. Please keep the thoughts coming. I appreciate all of them!
/ Snow clearing #32
"I don't know how to check for that yet."
Stand off to the side, and keep your face away, and then just depress the tire valve a bit. If the tires are filled, fluid will come out.
/ Snow clearing #33
Don't recall yet seeing anyone suggest adding weight to your rear blade. On a tractor like yours, that rear blade doesn't provide a whole lot of ballast against the FEL. If you add weight to the blade, it won't be there for your summer mowing.
/ Snow clearing #34
That is a valid suggestion. My only concern is that I use the rear blade a lot for clearing snow. When the blade is down, so is the weight. If it could be mounted up by the tractor side of the three point, it would always have the weight on the tractor. Hmm.
/ Snow clearing #35
My experience has been that a tractor with all three of the following will do a good job with a snowplow: 4wd, R1 tires, Liquid filled tires. If you are lacking any one of them, you are asking for trouble. Chains can make up for the lack of any one of the three but they will damage blacktop if you have it. A blower is another good option if you are lacking one of the three as this implement depends far less on traction force.
/ Snow clearing #36
I have 4wd, R1 liquid filled tires on a Kubota L4400. Plenty of power to go through just about any amount of snow but hit a patch of ice going uphill with a blade full of snow and she just spins. I'm expecting a set of chains any day now. That should do it. Also, I do not find the loader-back blade combo to be very satisfactory. It will do for now but a front plow with hydro angle is on my wish list. We got 14" on Sunday on top of more than a foot earlier. Snowing now.
/ Snow clearing #37
The more I use the tractor, the more I agree with the last two posts. I am pricing some rears for the tractor and looking at filling them also. I can change when I start mowing to the turf tires.
I have had lousy luck with the narrow bucket I have and the rear blade. But like Chuck said, it will have to do for now. I really like the plow setups I have seen. May have to do some fab work when I get my shop together.
/ Snow clearing #38
A rear blade works real good for me. I did a few things to make it work better. First, I have it facing backwards so I dont have to drive over the snow first. Hopefully you all are already doing this. Second, I made it about 10" higher by bolting a piece of 3x3 angle iron across the top edge and attaching a 10" wide piece of 3/4" marine plywood to that. That extra 10" height lets me push much more snow without spilling over the top. Third, I added around 400 lbs of steel weight to the frame which really lets it scrape good and provides additional traction. The blade also has some nice shoes which prevent it from digging in before the ground is froze up good over stone sections. I use it on a 43 hp 4wd with loaded R1's, no chains and I have never lost traction although I do not have hills. This tractor pushes much better than the old 2wd I used previously which had loaded R1's and chains. I also no longer need to reseal my blacktop driveways each year because of chain damage.
/ Snow clearing #39
Does anyone who is plowing with a dirt bucket worry about scratching blacktop or concrete driveways?
jmf
/ Snow clearing #40
jmf
Yes, I do worry a little about that. One TBN fix I have seen mentioned is putting a piece of PVC pipe on the bucket edge. That way the pipe rides on the asphalt and not the metal bucket edge. I have not tried that yet.
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
Stout Buckets HD78-3 Rock Bucket Skid Steer Grapple (A65640)
Stout Buckets...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
(2) Firestone Tires (A65640)
(2) Firestone...
2015 Isuzu NPR HD Porta John Recovery & Cleaning Truck (A62613)
2015 Isuzu NPR HD...
2014 TROXELL  140BBL VACUUM TRAILER (A65643)
2014 TROXELL...
