latest bumper build
/ latest bumper build #1
TOMMYHPX4X4
schriever, louisiana terrebonne parrish
gator hpx 4x4
this is a front bumper we done for a 08 suzuki vinson 500. it's really heavy duty . you can hang the atv from a tree with it and it won't bend. i have to do the rear bumper to now . we sprayed it with some bed liner coating so it would match the rest of the racks on the atv.i mounted a 3000lbs gorilla winch in it to top it off.
i bent everything in a vise with my torch. i'll get a pipe bender one day.the top piece that has the suzuki emblem in it i cut that piece out of the original bumper but the rest is all new.
/ latest bumper build #4
How about some pics of it in design or build stage, before paint.
/ latest bumper build #6
i've never tried to bend a section of tubing with my torch......how did you keep it from collapsing? or do you just control your heat and how quickly you make the bend?
you get about 1"of it red hot then put a little pressure on it and as it starts to bend you work the heat up or down the pipe. everyone who tries to bend pipe with a torch just heats up one spot and thats where they mess up.if you heat one spot it will stretch the pipe and cave it in on the sides. now i do get a bit of cave in on mine but after i have it to the angle i want i then come back and heat up the whole bend and smack it with a 2lbs ball-pen hammer to get it back round again. but just remeber never heat up just one spot and try bending it work the heat with the bend.
/ latest bumper build #8
Another trick is to fill it with river sand, or some sort of sand. That will keep the pipe from collapsing as well and works pretty good.
Those are nice symetrical bends with a torch.
Case 2090 Tractor (A66285)
Case 2090 Tractor...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A64556)
2018 Ram 1500 4x4...
2020 Ford Explorer AWD SUV (A64557)
2020 Ford Explorer...
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
LOOK! (A63111)
LOOK! (A63111)
