JJ and others - Post Hole Digger
/ JJ and others - Post Hole Digger #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I have been in the attachments section with a Post Hole digger question. Now it comes back to the PT.
In my design, I sense that it would be a good idea to be able to reverse the PHD. My initial plan was to run it off of the PTO circuit, but now I wonder if I should run it off of the clamping circuit.
Probably not, as I doubt there is enough GPM in that circuit. I am thinking of maybe an electronic switch but man, that is just more junk to wire...
In more train of thought stuff. I guess I could put the switch on the Tractor side. This poses the Oops question if I were to attach my mower or other device, would I wreck the device if it ran backward for a moment?
/ JJ and others - Post Hole Digger #2
Dear Carl,
You need the HP from the PTO circuit. You would die of boredom waiting for it to bore a hole from any other circuit.
Reversibility is a great thing. Just ensure that the motor can take it. Some of the PT motors can't. For my 1445, I specifically asked Terry about it with respect to the 72" tiller and brush cutters, neither of which can tolerate it. He said that he did make a couple special one offs for people that wanted it, but that generally you would break the motor running them the wrong way. Some of the non-PT models have much higher HP/torque motors and nice features like replaceable carbide teeth. Since your 1850 was designed as a slope mower, it has lots of hydraulic horsepower to power these units. i.e. think skidsteer...
Originally, I had been concerned about reversing the PTO, specifically the tiller jamming, but it hasn't been an issue for me. The few times that a rock has jammed it, I have been able to clear it in seconds, by turning the PTO off, and dragging the tiller backward for 4-6".
If you are planning on using it for posts, you might want to install a large angle meter or bubble level where you can see it from the driver's seat to keep your holes straight.
All the best,
Peter
/ JJ and others - Post Hole Digger #3
This is a straight forward solution for you reversing needs. It is only a 12 gpm valve.
Burden Sales Surplus Center Item Detail
This is a 12 v DC valve for reversing motors. Once wired up correctly, a flip of the switch will put the valve in detent for continuous operation. You need a single pole double throw switch. When you need to run it in forward, flip the switch to up or fwd, To shut the motor off, toggle it to neutral. To go in reverse, flip the switch to dn, or rev. Whatever the switch is labeled. The PTO lines go the new valve, and the output lines go to the motor. You can put QD on the lines going to the new valve, so anything you are using now will still work.
Whoever you purchase the post hole digger from, ask if it will reverse. Most of them should.
The easy way would be to just reverse the lines from the motors. You probably will not need reverse very often. except to get out of trouble such as a jam.
/ JJ and others - Post Hole Digger #4
So JJ, you love this Burden site. I get so confused as I do not understand hydrualics.
So what kind of motor would you recommend for the following
18GPM, 3000 PSI
A pto rated speed?
A 60 to 100 RPM speed
A 900 RPM speed.
The three projects i am mulling over is a Post Hole Digger, an adapter for a wood chipper, and a stump grinder / trencher.
On the Stump Grinder I am pretty sure I am going to go direct drive. And make it multi angle capable.
/ JJ and others - Post Hole Digger #7
Last year I was considering a phd for me 1430. Terry said he would fix one that would reverse - I do not know how much it would have cost or how he was going to accomplish the reversing - but evidently is can be done on the phd.
/ JJ and others - Post Hole Digger #8
18GPM, 3000 PSI
A pto rated speed?
A 900 RPM speed.
This is a wheel motor, and matches up to the gpm. and will turn up to 400 rpm, not that you need to go that fast. Burden Sales Surplus Center Item Detail It has a tapered shaft, so you would need a machine shop to make you an adapter for a tapered shaft to fit the auger you are planning on using. This same motor would also work as a stump grinder, Again, you need someone to make you the adapters for the motor to the blade and select the teeth you want to use. As far as a wood chipper, those blades turn really fast. You could gear up and get the rpm.
For a good intro on hydraulics, go on Ebay and look at those hydraulic Cd's, they cover just about everything. The nest time you are in a hydraulic shop, grab some of the manufactures catalogs, They usually show all the parts and explain hose makeup, and fittings and etc. Ask lots of questions.
/ JJ and others - Post Hole Digger #9
Exactly. PT just has to put in a motor that is capable of reversing. I gather that some of the motors that they use aren't capable of reversing.
All the best,
Peter
So here is a real dumb question JJ. I assume 540 RPM PTO speed is what you get when the engine is cranking - ie maximum top speed. And that most people are probably running there standard PTO at 400 RPM or so unless they are flogging the machine?
I ask because I am looking at this chipper that wants 35 HP and 540 RPMs Just making sure when I don't hit the RPM I am still OK...
/ JJ and others - Post Hole Digger #11
Carl, I have the Bearcat chipper shredder, and ;use it on my Kubota B-9200 diesel which has only 22 hp. It does a fine job of chipping and shredding. I also have two speeds on my PTO the other is around 850 rpm. I will look and see what size the pulleys are. I am almost sure the shipper/shredder shaft is turning fairly high. One of the PT owners has modified a chipper shredder . Did a nice job on it.
/ JJ and others - Post Hole Digger #12
No, PTO speed is typically a little less than maximum RPM. Most machines have a PTO speed mark on the tach. Except for PHDs, and perhaps a few other implements in which fine control is an issue, PTO speed is PTO speed. The operator sets the hand throttle so the tach needle sits on the PTO mark. The only thing I have that I don't run at PTO speed is my PHD.
You can't flog a diesel simply by running it wide open or at PTO speed. :)
No, PTO speed is typically a little less than maximum RPM. Most machines have a PTO speed mark on the tach. Except for PHDs, and perhaps a few other implements in which fine control is an issue, PTO speed is PTO speed. The operator sets the hand throttle so the tach needle sits on the PTO mark. The only thing I have that I don't run at PTO speed is my PHD.:)
So now it gets interesting. How do you know if a hydraulic motor is hitting 540 RPM? I mean, My tractor is rated at 18 GPM at 3000 PSI at what I assume is 2800 RPM on the tach. Now this is a huge assumption of specs on my part as there is no documentation on this subject (Guess it is a call to Terry) so maybe someone can correct if I am wrong. So taking my specs and looking at the motor JJ has suggested as an example,
# 8.6 cubic inches per rev. displacement
# 20 GPM rated flow
# 481 RPM max
# 3000 PSI max pressure
It seems Like I could not find the 481 RPM this motor might attain as I am at 18 GPM.
Next question. Why are wheel motors tapered? What is the benefit of this? I get loading if you had a bearing in between the motor and wheel but I do not get why it is tapered.
I have the funny feeling I am really overthinking this project but thanks for all the education guys.
/ JJ and others - Post Hole Digger #14
# 20 GPM rated flow
# 481 RPM max
One way to measure RPM is with an optical tachometer and a white line on the rotating part.
I believe tapered shafts are a safety thing. It's bad form for a wheel to fall off. Tapered shafts allow a controlled interference fit. Straight shafts do not. Also, if the interface between the shaft and hub corrodes, tapered shafts are said to be easier to remove.
/ JJ and others - Post Hole Digger #15
I'm also interested in the question of determining motor speed. I have 4 spare wheel motors for my 1845. I was thinking of using one of these motors for a phd since I already have a PT 18" auger left over from my 425. For the phd, it really doesn't matter as I can just use the throttle. However, I was thinking of creating a "Universal PTO Power Pack" that I could use with other std. tractor PTO attachments (e.g., shredder). Sometimes you can find tractor attachments cheap on Craigslist. However, used PT attachments are rare and too expensive when new (for me anyway).
/ JJ and others - Post Hole Digger #16
Harbor Freight has an optical tach for a reasonable price.
The hydraulic motor maker's catalog should have a chart showing RPM versus flow for their motors.
There ya go! Someone else thinking in my same mental space
/ JJ and others - Post Hole Digger #18
Carl, and Marrt,
Try and not make this to difficult for your selves. Speed is speed, and is controllable.
whether it is PTO speed from a tractor, or what PT users call their PTO speed. My PT-1445 PTO speed control is manual. others are solenoid controled and run wide open. Both the tractor PTO and hydraulic PTO one can be controlled somewhat by regulating engine rpm. I don't believe there is anything written in stone for PTO implements. For instance, some people run their bush hog mower at low speed, and others run it at maximum. On a hydraulic driven motor, a simple valve will control the flow to the motor and regulate the speed. The valve below will do what you need, but is one way through this valve. It will let you throttle the motor from 0 rpm up to the maximum flow in GPM. You might want to run a small auger fast depending on soil conditions. For something like a 24 in auger for planting trees/shrubs, would run better at a lower rpm. It is simply a choice based on experience and soil conditions, and the size of the auger. I can tell you for a fact that one of those gas augers running wide open with a 12 in auger will rip the auger right out of your hands and it hurts like **** . A hydraulic auger can be reversed, and is a good thing.
Also keep in mind that some augers turn counter clockwise. It all has to do with the gearing in the gear box. A single gear reduction will turn one way, and a double gear reduction will turn the other way. I have one of the augers that turn the other way.
When you hook up your hyd motor, check and make sure the auger is turning in the right direction, You want the teeth to cut into the ground. I have made auger bits that look like a spade bit shaped the size of a 1 gal , and a 3 gal pot. It will sling the dirt fairly fast.
This valve will handle 30 GPM.
/ JJ and others - Post Hole Digger #19
Do you mean something like this.
Whats a controlled interference fit?
Also, JJ you mentioned I would need to have a connector machined? Any chance they allready exist?
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
2012 International Prostar (A63118)
2012 International...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
