Grease on Joints
   / Grease on Joints #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Is anyone concerned with using a spary lubricant on the lift arm joints instead of grease? Is this really effective?
I have considered (just thinking out loud) drilling a hole through the bolt from the head end to where the center of the joint is. Then drill into the bolt radially to this first hole. Then you could put a grease fitting in the head and pump grease in. Would this be worth it, or will these joints last forever with just a spray on lubricant.
   / Grease on Joints #2
I have tried oily spray lubricants and dry spray lubricants. I prefer the dry spray lubricant because it is cleaner and I believe causes less wear to the joint. I used Super Lube dry spray for several years. I am now using Slipplate graphite spray because it is easier to find locally than super lube spray and less expensive. However, super lube spray is less messy to apply than the graphite spray. Personally, I see no need for adding a grease fittings to the lift joints on my machine. I cannot remember reading about more than one joint failure. It appeared to be metal failure rather than a worn joint.
Dale
   / Grease on Joints #3
Dale
Red spray grease caused this mess as you can see in the background. It's all I had around my shop at the time? All it does is collect dirt, dust which can cause more wear on the joints. I will be giving the PT a good cleaning soon this will be removed.
I may take your advice and use the Lipplate graphite spray. Does it cause less collection of dirt when digging with the bucket? :confused:
   / Grease on Joints #4
Barry,
Slipplate spray is messy to apply. I wear surgical gloves. Super Lube dry spray is less messy and I don't wear gloves. Both products are dry and do not collect dirt or debris at the joint. I have also used Commet graphite spray used for snowmobile clutch. It works as well as the other two products but is considerably more expensive.
Dale
   / Grease on Joints #5
DHS said:
Barry,
Slipplate spray is messy to apply. I wear surgical gloves. Super Lube dry spray is less messy and I don't wear gloves. Both products are dry and do not collect dirt or debris at the joint. I have also used Commet graphite spray used for snowmobile clutch. It works as well as the other two products but is considerably more expensive. Dale
I'll have to check into those products. Dale thanks for the information. ;)
   / Grease on Joints #6
I thought about doing that at one time, also. Some day I may.
As for the spray grease, I use white lithium grease and hold a shop rag behind the joint before I spray it. This keeps overspray to a minimum. I like the white grease as I can see where I sprayed it. And yes, it does seem to collect dirt. But think of it this way.... the joint is similar to the ball on the back of a 3point hitch arm. Have you ever heard any stories about that joint failing? I haven't. I had that old IH 2500B from the 70s and it was one abused machine. I never lubed those joints and they always worked. I think as long as you keep the PT joints lubed, they should be just fine and probably outlast the machine.
   / Grease on Joints #7
Dear MR,
I agree. Given the stresses on these joints, I don't think that these aren't the places to worry about lubrication failure on these machines. If you are really worried, I highly recommend Fluoramics Lubit grease. But you could pay for a lot of custom rewelding by the time the joints actually fail.
Given the design/build features of the PT, I believe that PT could have a better grip on what causes failure on their machines. Personally I think that hydraulic fluid cleanliness and filtering, oil filters, articulation hinge are all points of concern for me. Oh, and how many of us have done something to remove the abrasion points on our hoses? I found a hose that was cut down to the metal over the weekend. I assume it was during the installation process, but the edge of my tunnel was knife sharp, ready to do more damage.
Don't get me wrong. I love the machine, but it does have some (correctable) warts.
All the best,
Peter
   / Grease on Joints #8
DHS said:
Barry,
Dale
Hmmm not crazy about using anything where I need to use gloves. .;) Guess I'll check locally for the Super Lube dry unless you have a good online source for it. :eek:
   / Grease on Joints #9
I tend to agree, just enough is good, any more is just wasted, and will collect dirt. I would suggest wiping all the excess off. Grease on the outside is not being used. What kind of grease, what ever you are used to using. There is no magic grease. Some people grab the grease gun every 8 hours, or every time they use the machine. If you are using a lot of grease, there is something wrong, usually a sign of worn parts.
   / Grease on Joints #10
I've regularly spray lubed the joints as suggested, but have a LOT of play in the joints after 545 hours on PT-425.
However, the play is due to the ball turning on the bolt! Not sure if the bolt or the ball is worn.
I've continued to spray lube the bolt, also.
At some point, I'll take a bolt out to see what all the wear is.
Mark H.
   / Grease on Joints #11
Mark H.
Speaking of wear. I only have around 101 hours on my PT. I bought the (BIG WRENCH) around the 40 hour mark, for the middle joint. I've kept it tight and greased. I noticed what seemed like a lot of play the other day driving around. And it's as tight as it will go. :cool:
   / Grease on Joints #12
   / Grease on Joints
   / Grease on Joints #14
ksimolo said:
Here's where I bought my Super Lube in April but the costs has gone up:
11 OZ, Super Lube Dri-Lube, Aerosol, A Self Cleaning Lu at Underbid.com
My order:
Item Title:11 OZ, Super Lube Dri-Lube, Aerosol, A Self Cleaning Lu
View Item:
Underbid.com: The Same Products for Less
&item=1051752391
Details:
SKU:750687
Quantity:6
Price Each:$5.18
Total For This Item:$31.08
Thanks for the link, will be refreshing to use the dry lube, and avoid the collection of dirt and dust that sticks to the front joints when using the messy spray grease lubes. :)
   / Grease on Joints
I have had some trouble with the scissors on my Leatherman Surge knife sticking. They don't spring open by themselves. I sprayed some Super Lube on them and they worked for awhile, but then stopped after 20 (just guessing here) cycles. I them tried some Dupont Teflon Multiuse Lubricant. This has worked fine after over 100 cycles. This kinda reduces my confidance in Super Lube. Anybody has a similar or contradictory experience?
   / Grease on Joints #16
Where do you get the Dupont stuff? I switched from Superlube to lithium because I wasn't happy with the Superlube. I'm not sure, but I think the Superlube brand was sold a couple of years ago. I don't think it is the same stuff anymore.
   / Grease on Joints
I believe that the Dupont stuff was from Lowes. My supply of Super is about 2 years old. What did you not like about it?
   / Grease on Joints #19
It didn't seem to work as well as the original cans I bought. It just seemed like a different product, and I felt I was starting to get more wear than before. I don't remember exactly who was who, but the new cans seemed like they were made by a different company, but also with the Superlube brand name.
   / Grease on Joints #20
Dear Bob,
You might want to try Lubit-8 or Tuffoil from Fluramics. Ace hardware stores often carry it.
I don't use anything else on tools, unless they specifically call for another lubricant.
I can attest that it can make piece of crap machining move like a swiss watch.
All the best,
Peter
2019 GALYEAN...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2020 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
200 Gallon Tank (A57148)
200 Gallon Tank...
