Which one?
/ Which one? #1
Grand Falls N.B. Canada
Hi I have been shopping for used compact tractors for a few weeks now, and have come up with a couple local choices. I would like opinions on what you think would be best for me.
I have about 3.5 acres of wooded land, and .5 acres landscaped. I want to clear some of the woods, aprox another .5 acres.
My driveway is 150 ft. long, and is l shaped ( in front of house) so add another 50-60 ft.
My choices are between a 2005 Kubota B7800, with a homade cab, rear snowblower, loader, blade, homade rake, 1 set of turf tires on rims, and 1 set of industrial tires on rims, both are in great shape, this unit has about 900 hours on it, and was used in a landscaping business. Asking price is $ 17,000.
Also included is a tow bar, and a motor that could be made into a post hole digger.
The second choice is a 2002 John Deere 4010 with a belly mower also with 2 sets of tires, same as above, industrial ones are about 60% though. This unit has about 500 hours on it but was used mostly for just mowing. It is also in better overall shape than the Kubota( appearance wise) I could also get a snowblower for it for an extra $2000. Asking price is $9500.
Both these units are 4WD, any input would be appreciated.
Oh and the guy with the Kubota said I could store the implements at his place, he lives about 1 km from here.
These prices are also Canadian since I live in Canada.
/ Which one?
Sorry for double post, but I forgot to mention that I can get a brand new JD 2320 with FEL MMM and SB for about 22,000 tax incl.;)
Or a JD 2305 with same equip as above for about 19,000 tax incl.
/ Which one? #3
I'd buy the JD and get the blower with it.
Both are good machines, but the price on the K seems high especially with it's commercial use history.
jb
/ Which one? #4
Moto, welcome to TBN.
I'd have to agree with John Bud. Getting much more tractor with JD (4010 ?). Much bigger chassis, more weight (less chance of getting stuck), much more lift capacity. HOWEVER, too bad it did'nt come with a loader. Would need to factor in an additional $5,000 (new) when you finally purchase one. Highly recommended as they are just too handy. Also note, with that size & weight of tractor, mowing the grass will leave ruts after a rain or in the spring when the ground still has alot of mositure in it, so best to get a riding lawn mower (or ZTR) to cut property immediately around the house. The belly mower is convenient from a cutting perspective but more difficult to remove & put back on than a rear PTO mower. Is the (4010 ?) gear or hydrostat ? Would be unfortunate if it was gear & would start making the Kubota look a bit better.
On the flip side, the Kubota being much lighter could be used to cut around the house. You are getting alot more attachments. It's smaller size would make it more maneuverable in the woods & it HAS A LOADER. The down-side as John & you have indicated, it more than likely has seen alot rougher work than the JD.
If the JD is hydro-static (or electro-hydraulic shuttle) it blows the Kubota away. The Kubota is just priced way too high & higher risks involved from a reliability perspective due to the work it's been through. Also, you would need to purchase a mower for it. If you get that blower & a new FEL for that JD, your getting a much more capable tractor.
The JD 2000 series are just too small IMHO. It's very difficult if not impossible to get one tractor size to do all applications well. For your property & tasks you have in mind (plus future ones you haven't thought of yet) the 3000 series JD would be the best selection. Mid size chassis (so not too big) but still heavier & good lift capacity.......additional 1000 Lbs on PTO over the 2000 series.
Just my 2 Canadian Cents........so lets see.... half an American penny.
Good Luck,
Vic
/ Which one? #5
Seem like the price of the orange is a little high. The green one seems like its just undersized for you to do any real work. I would keep looking.
Chris
/ Which one? #8
These are both compact tractors, the Kubota being a bit bigger, and 30 hp, where as the JD is 18 hp.
They are both 4WD, and both Hydro.
Right, I knew that. I still say get the deere for your sized lot. You're going to be able to move some large logs with it when you clear the 1/2 acre, no problem. It is going to be a good mower and a good snow mover. Price is also decent.
You can add a FEL. Koyker makes some decent aftermarket ones for a good price. Or Woods, bushog, Westendorf, etc.
jb
/ Which one? #9
Have you seen a JD 4010? Its a lawn mower and is not going to do very much work.
Chris
/ Which one? #11
my first tractor was a 4010. good machine but the hydraulics were pathetic. my 2305 is much smaller but could run circles around that 4010. the 18hp wasn't enough to get any real work done, so I stepped up to a 4310. kept it for improvements, then sold it to a buddy, now I have a 2305. great little machine. hydraulics are MUCH better, engine is more powerful, and the loader can actually get something done.
/ Which one? #12
It's a nice looking lawn mower. I can't get over the cost of that used. I know someone who just bought a Montana 4940 (49HP 4x4 with FEL) 2 rear remotes and shuttle shift and it was only $19275 brand new. I guess i'm used to having a tractor with a cheep poulan lawn mower for the yard. I dislike my poulan, but it was only $800 and i've had it for 10 years so I can't complain too much.
/ Which one? #13
Will it do more work than a 4 year old boy, 2 cats and a dog? lol
For your money there are tractors out there that can be had for that money that will get some real work done. I would even consider a new import like a Foton or Jinma. I have a 28 HP Jinma with a loader. I bought it with a 5 foot 3 point finish mower new for under $10,000. Its a good tractor for the money and weighs nearly 5,200# with me on it. I have the rear tires loaded and this thing will pull. It can out pull a 4x4 truck. I also own a Ford 861 Powermaster that was built in the 60's. Its 48 Hp but will only pull 2/3 what the Jinma will.
I would keep looking for something more hefty. The tractors you are looking at would be fine for mowing but would have trouble moving any real snow and I believe would have trouble turning a decent sized snow blower. And as for the clearing of the land they would be just a luxury for dragging a cart around and pulling small logs. Also that belly mower would probably need to come off for the snow removal and land clearing which is a pain in the AZZZZZ.
Chris
/ Which one? #14
I have the same size/type lot and situation - 3.5 ac, with about 1 ac cleared, and going for about .5 more. I have a BX24 and while it has its limits (capacity and ground clearance), I take it slow and am in no hurry. My first reaction to your post is go after the new JD SCUTs you mentioned in your second post
You haven't said how you plan to attack and use the extra .5 acre - just cut and skid trees? grass/garden/building? bring in and/or move dirt? Plan for the stumps? Need it done fast? Storage for tractor?
The SCUTs may be undersized, but it IS only 1/2 acre. Once you clear it you still have a reasonably sized machine for mowing and snow blowing (and storing) and a FEL for the odd utility work /landscaping. I personally could not live without the backhoe on mine, but YMMV.
My rational going with a new TLB was that I would have most (if not all) of what I need for the "projects" and still have a mower for life during and after the projects are done (yea...right). IMHO, I just see no long term advantage in either the B7800 or the 4010.
Just some thoughts,
-Eric
/ Which one? #15
I suggest a Kioti CK20. Way more capable than those subcuts, and a better fit size wise. A new one with loader and attachments should come in much less than the JD's you are looking at. Also a TYM T273: very nicely sized and equipped little tractor.
4010 is too small. The 7800 is priced way too high and if I were looking in that size, there are many good choices out there. I believe you can buy a new B3030 for less than what is wanted for that 7800. So, if that's where you are leaning, keep looking.
/ Which one? #17
The B7800 is definitely "larger" than the CK20. But, the 7800 is not a subcut. So, I wasn't talking about it. The 7800 is more comparable to a CK30, and is therefore probably a little more capable than a CK20. But, that price is ridiculously high.
/ Which one?
Thanks guys for all the advice, I priced a new Kubota b 3200 which replaces the 7800, and has more power 32hp, and I can get it for 17500. bare. the loader would be 4000 more, these are retail prices, and can be bargained. I also priced a bunch more k's while I was there, if you're curious I'll post em.;)
2013 KBH Hopper Bottom Trailer (A64047)
2013 KBH Hopper...
2019 GENIE S-80XC TELESCOPIC BOOM LIFT (A62129)
2019 GENIE S-80XC...
2021 Jayco Jay Flight 32BHS Camper (A62613)
2021 Jayco Jay...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
CATERPILLAR 255 SKID STEER (A62129)
CATERPILLAR 255...
UNUSED LANDHERO CHAINS & BINDERS (A62131)
UNUSED LANDHERO...
