Box Scraper getting a box blade!
/ getting a box blade! #1
Sackett2
Eugene, Oregon
Montana 4344HST
Won the bid on e-bay; 72" for 102.50. its a lighter weight one without the option of a removable cutting edge. I just need one for light driveway maintenance so this will be fine... and the cost. :D
e bay number300269767085
/ getting a box blade! #2
Well Rick, you didn't ask any questions - so one must assume you are interested in comments. I'll take the liberty of offering two:
1. I hope you're going to pick it up yourself. $175 is big bucks for in-state delivery of a $102 item.
2. One glance at the A-frame straps is enough to conclude that you should pull this boxblade only. Trying to push anything substantial with it - especially behind a 43hp tractor - will soon pretzel the A-frame.
Having said that, you might want to consider gusseting the vertical flatiron of the A-frame against the diagonal lift braces - before anything gets bent.
//greg//
/ getting a box blade! #3
I think you may have got ripped off even at 100 bucks.
The rear blade looks like it's just folded over 3/16 metal like the rest of the construction. That will wear down very fast. Your tractor will destroy it fast, even just pulling it with the light construction. You have a welder? A buddy with one? A porta-power? You hook a root or a rock and it will twist easily behind a 40+ hp tractor.
Sorry to rain on your parade, but with BB's you do often get what you pay for. But, when you get it, please post up more photos. I would like to be wrong about this!
jb
/ getting a box blade! #4
The picture is no longer there, so I can't see it. I bet its not that much different from a typical United or KK, at least not much worse. I think the problem is not the 'cheapness' of the unit but the tractor size. I think it said it was rated to 35hp, which is probably a stretch. On a 20 hp tractor it would probably be perfect, but if his tractor is 43 hp and 4wd, he's going to have to be real careful with it.
For grooming a driveway, probably no problems and a good deal. But if doing any serious dirt moving or excavating, it will need to be handled with care.
/ getting a box blade! #5
Good Mornin George,
I cant imagine a 20 hp tractor pulling a 6 ft boxblade and doing any real work with it. But I do agree that if he has a welder or knows somone that can beef it up with additional plate, that may be a good option !;)
In any event good luck with your new implement !
/ getting a box blade! #6
I think if you sign in, you can see closed items. I have to dis-agree on that 20hp tractor point. It is a 72" wide box and that is too wide for most 20 hp tractors, unless you are just moving mulch or fluffy top soil from a pile.
Maybe my assesment is too dismal. Could be. My opinion is from using a 30 hp kubota and seeing what forces are generated by hitting rocks and roots. If he has neither, it may be ok. maybe.
/ getting a box blade! #7
Good Mornin George,
Just like with the 45 hp tractor, it depends on what you're going to be doing. By all accounts it looks pretty light, so dragging gravel with a 20 hp would probably be just fine and being light it probably isn't going to engage all that well either. Not ideal for either one, but unlikely to be destroyed by a 20 hp anyway.
I'll try to address all comments:
The e bay place is only 8 miles from my house- no shipping. I drive past the place to work every day.
I have a 41 HP tractor.
I am "Steve" not Rick
I realize it's a cheaper model, but I'll play with it around the house, on the driveway some- don't need the rippers as much. If I find it to be more than useful AND it gets tore up- I'll buy my a nicer one. I don't expect it to do everything- but at 102.50 I'm not out much.
/ getting a box blade! #9
Bingo. If there are no additional shipping costs this is at least worth a try at only $100.
/ getting a box blade! #10
It looks much like the BB I got.
For $100 you can go a little slower to not do so much damage.
Your tractor could probably damage a $1000 BB if you hit the right rock at speed.
Enjoy the BB and your savings. Its not as if these things are space age disposable.
You can do a lot of beefing up and strengthening for what you saved.
/ getting a box blade! #11
I agree with everything denmansoft said.
I would definitely look into beefing it up though. It's inexpensive to do and you can use remnant or scrap steel to do it. For sure it's another tool for you to get a lot of dirt/material moved and trails/paths/roads smoothed out. It may not be the best quality like a Gannon but didn't come with the price tag either.
beefing it up:
I can do that; I see where the upper arms will benefit from being tied together (like other brands) and eventually a "real" cutting edge, if I wear this one down. I'll watch it for signs of weakness and fire up the buzzbox when necessary
OK, got the blade home and played.
I can tell its not as heavy as others, and I didn't have a need to rip the driveway up, so on the first pass I didn't do much. Then I hit some soft gravel and the box did its job. Very satisfied with its performance.
Today I went into the pasture and used it to level a dirt mound. Much better results than the rear blade.
I am a contented tractor owner, that is until the next implement is spotted....
/ getting a box blade! #14
Use your new attachment and all others safely and well :D! Jay :)
2017 Ford F-550 Signalier ATR 45ft Bucket Truck (A61568)
2017 Ford F-550...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
2022 BOBCAT E35 R2-SERIES PLATINUM EXCAVATOR (A62129)
2022 BOBCAT E35...
UNUSED WOLVERINE TD-13-36R STUMP DIGGER (A62131)
UNUSED WOLVERINE...
2021 Big Tex Trailer Trailer, VIN # 16V3F4826M6084230 (A61165)
2021 Big Tex...
(INOP) HUSQVARNA LGT2654 RIDING LAWNMOWER (A62130)
(INOP) HUSQVARNA...
