Larry's axle kit with 62D question
/ Larry's axle kit with 62D question #1
2Malamutes
Kalamazoo, MI
I just received and installed my axle kit from Larry's axle Co., and while the product is great and works just as well as advertised, I came home tonight to find the relief valve on the top of the gearbox (now on the bottom with the deck perpendicular) dripping all of the fluid into a nice puddle on the garage floor. Anyone else had this problem? I figure I can just remember to remove the relief valve and install a plug every fall(and reverse the process in the spring), but I just wanted to see if everyone else's relief valves were acting similarly or if maybe mine has a problem.
/ Larry's axle kit with 62D question #2
I have used my mower axles for 3 or 4 years now with nairy a drop of oil leaking on my 60" MMM. Mine has no "relief valve" though, can you take a picture of it?
/ Larry's axle kit with 62D question #3
I used a self-made set of axles last winter and didnt have any leaks.. I dont remember seeing a relieve valve on mine (62D) either.. But I will go take a look and see if i have over looked it..
good luck
Brian
/ Larry's axle kit with 62D question #4
I also use a self made axle kit and have had no such leakage issues.
I am away from my machine, so cannot look right now.
The Deere parts catalog for the 62D does show a pressure relief fitting on the top of the gearbox right over the input shaft. I suspect that your fitting is loose or defective.
/ Larry's axle kit with 62D question #5
you guys with home made axles: can I ge materials/part numbers list and possibly photos?
/ Larry's axle kit with 62D question #6
I used the following...
(2) 16" long x 5/8" bolt and nut (galvanized was all i found in that size/length - Lowes)
(2) 9" long PVC 'axle spacers'
(4) 5/8" axle hole solid rubber wheels (TSC) - I used 8" wheels, but a 9" or 10" would be better - part of the mower hits the ground at times with the 8".
(4) 5/8" to 3/4" bushings - TSC/Lowes - (The holes in the mower are 7/8" - but the wheels were 5/8" so I was worried about wallowing out the mower holes and 3/4" was the closest I could get in a bushing)
Good luck
Brian
/ Larry's axle kit with 62D question #7
I recently got a set of Larry's axles for both my 62D and the 54C up north. I was considering building my own but after receiving the axles from Larry the price is worth it. The axles are sturdy enough to support the weight of the deck, and are drilled to lock in place. I should have bought them sooner.
I will check to see if my 62D is leaking, but I don't remember seeing anything the other day.
/ Larry's axle kit with 62D question #8
After reading this thread, I'm not aware of what a Larry's axle kit actually does. It seems like it takes the place of the original height axles in the 62D mower deck. I googled Larry's axle company with no luck. Just curious what this axle kit is for and where I can get information on the product. Thanks!
Attached is a picture. The manufacturer name is "Alemite", and when I look them up the part looks like their vent http://www.alemite.com/catalog/details.aspx?identifier=fittings_airventvalves but I can't tell what pressure. If it is a felt vent (0 psi), then what I am experiencing would be normal, but if it is a rated vent, then I don't think I should be getting the drainage. The leak is not coming from the threaded portion like it isn't tight, it is running out from beneath the cap. The cap on mine is completely loose and can be easily moved about with a slight touch. Can someone else with a newer style like mine see if that is normal? Thanks for checking.
/ Larry's axle kit with 62D question #11
My deck DOES NOT have the same top plate..
My unit is pretty much closed unit - no removable part at all - but it sorta/kinda looks like it has a pressed in plug on it - that may be removable, but just not easily..
I wish mine had the bolt on top like yours, it would make oil changes easier..
Brian
/ Larry's axle kit with 62D question #12
2malamutes,
I believe the vent/cap on my 62d is like yours. It is loose and spins freely and honestly, seems rather flimsy. I'll have to take a closer look later today.
/ Larry's axle kit with 62D question #13
My 62D, purchased last spring, has no vent.
Incidentally, I've been collecting the pieces to make my own axle stands, including 7/8" and 5/8" steel round stock and four 8" steel wheels with hard rubber tires.
After looking at the "Larry's" axle stands, I can't figure out how the wheels are big enough. They don't look like they're even 8 inches and I figure that with 8" wheels, the gauge wheel adjusters will have only about 1/2" clearance to the ground.
Anyway, my design will be a 10" long piece of 7/8" round stock, with a 3 inch piece of 5/8" round stock welded on each end. Then, I'll cross-drill the 5/8" stock to pin the wheels on.
Hope it works, but if it doesn't, I won't have much invested.
/ Larry's axle kit with 62D question #14
If I get time this afternoon I'll take a pic of the deck and stand. Clearance didn;t seem to be an issue, even on the gravel driveway.
While the attached pic doesn't illustrate the clearance well, there is plenty of clearance with the "Larry's" wheels. Since the adjusters are parallel to the axles, you would have to have a _/\_ shaped profile between the two wheels for the clearance to be an issue. I think you are more likely to get high centered going over something front to back than have issues with clearance between the axles.
/ Larry's axle kit with 62D question #16
<deleted text>
<deleted text>
I used 8" wheels and the wheel height adjusters hit the floor at times.. I am thinking about getting some 10" wheels for it..
Brian
2003 Proclaim Tanker Trailer (A64194)
2003 Proclaim...
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
