welding buisness
/ welding buisness #1
metalmeltr
Member
I am considerig very highly startin a welding buisness I am just curios how many ofyou guys culd benifet from such a service.
/ welding buisness #3
That and several of us like doing it ourselves, there are only the specialized items like cnc I have farmed out myself.
/ welding buisness
I am in southwestern ohio, i would eventually like to get a CNC plasma
/ welding buisness #5
There is an Amish fella near here that does welding, he's cheap and does decent work so he's usually busy. Biggest problem is getting stuff to him, another guy has a portable welding outfit and he makes house calls, more expensive but he also does nice work.
/ welding buisness
i was planing on doing stuff in my garage and moible.
/ welding buisness #7
All of the above being said....
I do my own welding too (not good at it, but I do it anyway...) and I've constantly got guys from work wanting me to weld stuff for them. Also, my dad made some money by doing welding on the side just from people in the neighborhood. Seems like there's always a market for the service around here.
So I think it's a great idea, as long as you can stay clear from any gummit' regulations, licenses, etc.
/ welding buisness #8
I do most of my own welding, but sometimes I need to hire an expert to do something. I tried a few of the local guys and the small operations, but found them to be too flakey. If I'm hiring it done, I need it done, and I don't want to deal with excuses or them not being there when they say it will be ready.
Now, I go to the biggest, and probably most expensive place in town. I tell them what I want done, and they do it. I pay what they charge and get on with what I'm doing.
The most important thing is not price, but being reliable. There are guys all over here who are struggling and don't realize it's because they are unreliable and have a reputation as a flake. When people are willing to pay more to do what they could do, but chose not to, is proof that there's plenty of work out there.
Good luck, there's always an oportunity for somebody who wants to start a business and is serious about it.
Eddie
/ welding buisness #9
Like Eddie I do most of my simple welding here at home. It isn’t pretty but it does the job. When I go to a welder it is for items I can’t handle and that mostly involves specialty equipment for precision cuts, bends or the ability to weld materials that cannot. It takes a large investment to equip a pro welding shop.
MarkV
/ welding buisness #10
Eddie has some great points. You are asking a question in a section entitled customizing, i think in this area most people do alot of work themselves.
I think it is a good idea to start your own business. Just make sure you do a quality job and be honest.
And just because someone around the corner is doing the same thing doesn't mean you start your bus. it is call competition.
Shane
/ welding buisness #11
I don't know a single tractor owner on my road who can't weld. Doing your own basic welding is virtually mandatory for the farmers in my area.
A welding business will require business license(s), bookkeeping, and other government mandated overhead. Have you looked into this stuff yet? Working in your garage may be problematic, depending on your local government's zoning rules and regs and/or your neighbors. Your homeowner's insurance is not likely to provide coverage and may be voided. Talk to your insurance agent about this and other coverage you will need for business purposes.
/ welding buisness #12
Even though I can weld and do much of my own work I do use pros. The only pros I tend to use are the ones who are certified. I suspect there is a fair amount of liability in not being certified. In welding there are many diferent certifications.
Andy
/ welding buisness
there is a lot of things such as lisences that i still have to look into but my dad did auto colision in the garage so I don't think zoning will be a problem and I have good neigbors so i don't think they will care especilly if i am doing work for them. If anyoe knows secificly the required lisences and such PM i to me.
/ welding buisness #15
What is your skill level with welding? If I pay someone to do welding I expect it to be strong and look good. What is your target audience? If it is farmers and landowners you are going to get called on the tough jobs they can't handle. If it is simple they will just run the bead themselves. Just my two cents worth. Good Luck
Take Care
Doug in SW IA
/ welding buisness #16
Be careful to count up EVERYTHING you will need.
As a hobby welder you probably have a lot of support tools, but to "go pro" you will need ALL of them.
I'm not saying buy them all up front, just know what you will need to be able to take on each job.
For a while you will probably find all your income going to tools and supplies.
/ welding buisness #17
I can't speak for all parts of the country, but around here unless you can round up some companies or oil field work to carry you along you're most likely going to have a tuff go of it fixing farm equipment as anything but a hobby. And that usually means insurance, high insurance.
I got completely away from welding altogther after my back messed up, but in the 30yrs I did fabrication, both in what I did for myself or for shops that I worked or contracted for, a lot of work of this nature was considered secondary and done more for good will then anything else.
Equipment, rods, gas, grinders, abrasive wheels, tools and materials get expensive quick and things need to be constantly replaced. it also really takes a pretty good stock pile of angle, flatbar, pipe and plate lying around or at least a good source. Warning: Some Wives tend to frown on these items strowed about in the front yard too. Usually when something breaks on farm equipment it's worn down, stress cracked or fractured and bent to heck and the section needs to replaced and strengthend. If you have mills that material can be found at cheap that would be a big plus. Company auctions are also a good place to look for equipment along, it would help to have some idea what is being sold before hand so you don't end up with stuff you cant use or 3 phase in a home shop. Machine work is also a frequent requirement so knowing a machinest with a little free time could be in your favor.
Here most people with equipment that can afford to fix it at your realistic costs and show a profit probably have a welding machine, know someone with one or carry it to a machine/ fab shop or dealer to have it repaired. Any more premanufactured implements are often hard to compete with unless specialized or a good source of steel is available. Some casts and alloy applications also require different methods to repair and it isn't impossible to make matters worse if not done correctly. Take a guess who will be expected to eat that and that's also when the price rate usually soars. So some good knowledge is needed on metals and it's good to have a good reference source availiable. Getting a good buisness going will depend on several factors worth checking into before jumping into it head first.
/ welding buisness #18
Take Care
Doug in SW IA
EXACTLY MY THOUGHTS
/ welding buisness #20
I was trying to do what you are looking at, my way of getting started was to do side jobs after work to build a customer base. You just don't call up the yellow pages, place your add and go to work. I did a lot of late nights and weekends for people for very little money just to get a name.
Also on equipment you need to be a pretty good mechanic to get the machine apart, weld the repair and reassemble the machine.
In the end I had some good customers and got a great collection of tools, but it was a big pain. I kept running into projects that I built like they wanted, but when it broke it was my fault, after all how could the design be bad. So I fixed them for free and sometimes had to take time off work just to fix it. that means I was not making money and I was losing my vacations time. The other side of the coin is that nothing breaks when you have time, hunting and fishing got put on hold for a couple years because they happen to be in the main construction season, so every long weekend they would give there guys time off and I would come in and do big repairs and rework equipment. Paid great, but i work every july 4th for years.
I still have several customers that I do small jobs for and some jobs I do just for the challenge. The added money is nice and I buy a attachment or two or more with the extra cash,(don't tell my wife) but there is no way that I will ever try to feed my family with my own welding company.
You live in a differnt part of the country and the market is differnt. If this is what you want to do good luck and I do hope it works for yo. I would suggest that you build up slow.
UNUSED FUTURE AD680 HYD PILE HAMMER (A65055)
UNUSED FUTURE...
2017 Nissan Sentra Sedan (A64557)
2017 Nissan Sentra...
2018 Ford Escape SUV (A64557)
2018 Ford Escape...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
1991 FREIGHTLINER FLA-89 T/A SLEEPER TRUCK TRACTOR (CABOVER) (A67148)
1991 FREIGHTLINER...
Hensley 16in. Bucket with Teeth Excavator Attachment (A64194)
Hensley 16in...
