major drive problem's 5600"A"
/ major drive problem's 5600"A" #1
powerjoke
Central MO
GMC truck's, CaT equipment, and Newholland tractor's
First of all i would like to say Hello My name is RICK and this is my first post, i have been doing some reading on toolcat's on here and you all seem verry sharp;) none of the thread's that i have read seem to match my problem so here it goes......lol
{long post....for a short version see the last paragraph}
i have a '03 toolcat and it has had it's fair share of problem's. from overheat (2 speed fan valve) to misc, B/S
so now......back in july we were useing it to pull a bale acumulator, and it suddonly stopped! and sent it to the shop and they put a drive controller, and a F-N-R selector, on it and sent it back.....that's where the problems started
it has picked up the bad habbit of slipping the rear tires going down the road with a attachment (1200lb grapple) and slipping the front's while empty we use it to transport work tools among many many other chore's so it sees alot of road use and within 3 miles all 4 tires were JUNK!
so the dealer has picked it up and dropped it off 3 time's now :rolleyes: and still has a problem.
they have replaced the drive motor pressure releif's and adjusted charge/preload pressure's
does anyone have any ideas?.....i need help and i need it fast as this thing's going back in the shop this week and it's obvious they dont know what the heck they are doing :rolleyes: lol
so in conlusion it is still slipping the rear's while going down the road.....what's wrong with this p.o.s. lol
P.S. i know you have all seen a TC before but i just thought a pic would dress up the place lol
PJ
/ major drive problem's 5600"A" #2
Well, if you're the same Powerjoke as over on PlowSite, welcome aboard. Actually, even if you aren't, welcome anyway.
I have a "D" and have not experienced the same problems you have...so sorry, can't help in that regard.
LOL.....'cant hide nowhere huh? :cool: ..... i guess i coulda changed my name ....doh! :D
you like the "D"? ....i had intention's on buying a new one by now, but i bought a "A" for half price of a "D" as a trial thing.....but i don't think i want a "D" now lol. i may buy a new RTV 1100 and a 247Cat or a t-140 B/C for the sidewalk crew. ?
PJ
/ major drive problem's 5600"A" #4
"You can run but you cannot hide" :)
Yeah, I like my TC pretty well. My dealer is great and so I'm pretty happy with Bobcat in general. I have a 5600 rather than the 3-pt 5610. I use it almost exclusively (90%) for snow plowing/blowing.
I took my TC in for a "pre-winter prep" and they did $1500-$2000 worth the service/parts for free. I think they weren't too busy and they pulled all the Service Bulletins on it and addressed each one. Basically, they did some retrofitting on the steering to take care of a noise during turning (and crabbing), replaced all 4 struts (can't order shocks alone they said), replaced a pressure regulator on the hyd system (I was maxing out at 2400 PSI), fixed a leak on the hyd pump, and washed the entire chassis. Everything was under warranty.
Good luck with getting your machine back to 100%. I view my "D" as being a little temperamental but I can't think of anything I'd want to replace it with for what I do.
/ major drive problem's 5600"A" #5
Rick,
I have an 'A' as well that I use around my property for various chores. Fortunately mine has been very reliable with around 650hrs on it.
The service manual troubleshooting chart lists the following for "Drive axles turning at different speeds":
- Drive controller not working correctly
- Check drive codes
- Hydrostatic motor damage
- Hydrostatic pump damage
- Replenishing valve not seating
- Speed sensor not working correctly
Have you visually inspected the wires and connectors on the speed sensors? Do the symptoms occur in normal and rabbit mode?
dsb
the seizing of the front axle in reverse is noticed in slow or work.
but the tire chewing is noticed in rabbit.
i've looked at the wires and checked ohm's on the drive valves (4 of them) etc. Before the drive comp and F-N-R switch was replaced
thanks
pj
/ major drive problem's 5600"A" #7
Powerjoke,
Not sure I can help but I have an idea, after you said the problem of slipping happens in HIGH speed,, so here we go:
In the high/low speed positions there is a little piston, (its either one or two small ones) in the comer motor that changes the angle of the swash plate therefore changing the volume per revolution and thus the speed. The thought what if the front or the back is not changing or stuck causing slipping between the two. I think I would jack it up have it secure and put it in gear low then high and check your revolutions at each axle. If you find that one is stuck you might get lucky and take the Comer apart be carefull not to disassemble the pistons/cage assembly because their wear matched.
Good luck
/ major drive problem's 5600"A" #8
Also take your bypass filter off and cut it apart it is the filter by the battery have one to replace if it is OK, also read your private email I sent you.
thanks Rock:
the dealer has taken the front drive motor apart and visually inspected everythig,.......but who know's if they knew what they were looking for :rolleyes: lol
the bypass filter has been cut-apart and there was NO evidence of wear of anykind preasent,
i am going to pull samples today and send them to CaT, they give me the S.O.S. bottle's so i figured 'eh what the ****? lol
the difference in the speed's of the tires is not noticble, however the tires are just "chunking" off of it,
when i noticed one of the rear's with the tread ripped off, i asked one of the hired hand's what happened, he said he had no idea.
so i told him to go back to the other farm and drop off the grapple and get the trencher, so when he come back, the other rear tire was bad :dizzy: and not knowig what happened i called the dealer and asked them what they thought would be happening?.. know idea btw :rolleyes:
so then the machine got roaded again WITHOUT any attachment, and that's when one of the front's got chewed, (all of this happened within 30 min)
so, the only conlusion i came up with was, with the attachment the rear was loosing traction when it was trying to push the seizing front's. and without any attachment's the front's were sliding going down the road
my tractors with ground speed radar, will indicate 15-25% slip while in field, and you cant tell it from the cab, so i imagine that's the same thing that's happening here?
when the front's seize, in reverse, there is nothing you can do to make them start turning again if traction is low, and the machine won't back up. the rear's just sit and spin
BTW: all of this happens when it's normal operating temp ONLY! ?
thanks for the help....hope this peice of the riddle helps solve the problem?
PJ
/ major drive problem's 5600"A" #10
I would think if one set of tires was turning at significant different speed than the others, it would be more noticeable. Does toolcat seem to lack power or have difficulty getting up to speed?
no problem getting up to speed.
20% wheel slip you'll NEVER notice, in a tractor in a feild you wont even notice 60%.........except for th efact youre only getting 40% of youre stuff done lol
after it came back from the shop the third time it runs 25mph where it ran 18mph before :dizzy:
they're going to come to the farm and test the machine at the end of the week, so we'll see what happens :rolleyes:
PJ
/ major drive problem's 5600"A" #12
Here's my two cents on this issue. The Toolcat monitors both axle speeds whenever the machine is moving, through a separate speed sensor mounted on each axle. If it sees any discrepancy in speeds between the axles, it will stop driving the axles and set a code. It is very touchy about speed differences and can set this code very quickly, in less than a second in my experience. So that tells me that if your 5600 is able to run down the road with the axles turning different speeds, it is very likely to be an issue with the speed sensor circuit in one of the axles. The controller must think both axles are turning the same speed or else it would stop the whole thing and set that code.
Whichever axle you believe is turning faster would be the first one I would investigate the speed sensor and wiring on, a bad sensor or poor wiring would be more likely to drop some of the pulses from a sensor than to create more pulses than sensed by the actual speed sensor.
You might also check all the wiring connectors which were touched by the dealer on the last service, check each individual wire in the connectors to make sure they are locked into the connector, sometimes the lock that holds the wire in comes loose and allows the wire to back out of the connector, creating an intermittent connection. You can do this pretty quickly by grabbing each wire independently and pulling on it, it should not come out of the connector housing. If it does, bend the little lock tab out a bit and re-insert it into the connector, making sure it is fully seated and locked in.
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2006 John Deere 35D Excavator (A63109)
2006 John Deere...
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
(INOP) TOWABLE MANURE PUMP (A62131)
(INOP) TOWABLE...
