splotkin
Member
I just mounted the Kubota ballast box to my BX1850. The tractor shed is just shy of 12 feet long. With the Ballast Box installed the only way to fit the tractor all the way in is to raise the bucket almost all the way to the roof.
In the past when I had to do this I placed a 4x4 post cut just the right, length under the bucket, in case it leaked down.
I mentioned this to a friend and when he is working under anything with a hydraulic cylinder he will place a large piece of angle iron wrapped with duct tape on top of the exposed cylinder, so it cannot close down on him.
I liked the idea but I had no angle iron around. Instead I used a couple of pieces of Schedule 40 PVC pipe. I cut out a piece of the pipe lengthwise about an one and one half inches thick. These I can slide over the cylinder rods to keep the loader from lowering as the fluid leaks down.
I am concerned that the pipe is not strong enough. Especially when it goes down to minus 20 F. I did install them and then put the loader valve in float position. It seems to hold things up OK. I will probably try this overnight but with the tractor outside so there is not an accident if the pipes fail.
Do any of you have an opinion on how strong this PVC set-up is? Does anyone else have a suggestion on a light weight way to hold the loader up from the cylinder?
Thanks,
Scott
Thanks,
Scott
