Cat 257b tracked skidsteer
/ Cat 257b tracked skidsteer #1
bigvalley
Looking at a 257b with 820 hours with one new track and one I would rate at 50%. Current owner purchased on iron planet two years ago for 18,500. He has run it privately for about 150 hours and wants 18,500. Engine door has yellow writing that says Cat engine replacement @ 616 hours. A phone message back from my diesel mechanic said stay away from 257b, problems? My question is this, does anyone know what other problems may persist? I understand the engine was most likely replaced due to the oil feeder tube casuing engine failure.
/ Cat 257b tracked skidsteer #2
Stay away....the undercarriage on these are a nightmare...rubber and plastic rollers..hard to adjust...walk away
/ Cat 257b tracked skidsteer #3
Yup, great machines when they go good, but the undercarriage will kill you. Last I heard it was $5K to re-do the under side when the rollers/tracks go. I like renting them, but I'd go with over the wheel tracks if you're gonna own.
/ Cat 257b tracked skidsteer #4
I will echo the warnings above that it is all about the condition of the undercarriage. extremely costly to rebuild, the asv components are just not made to handle a suspension-less machine like the cats. i've been told by folks i've employed about these cat machines needing extensive work in as little as 1000 hours. less if abused. i think you'd be better off if you can find a similar asv brand machine at a good price.
Theo
/ Cat 257b tracked skidsteer #5
asv has the same poly/rubber undercarrige problem, look for a steel undercarrige machine, it will last a longer
/ Cat 257b tracked skidsteer #6
but asv machines have real suspensions. the asv undercarriage was specifically designed for a machine with a real suspension. doesn't that make a difference? the owner of a local construction company that does work for me seems to think so.
which tracked skidsteer loader has an all steel undercarriage?
Theo
/ Cat 257b tracked skidsteer #7
ASV signed a 10 or 20 year ( don't remember which it was) agreement for providing CAT's MTL undercarriages. So, Cat machines have an ASV undercarriage on them. Cat did just come out with a couple of model's that have an all steel undercarriage on them, other than the tracks. 279C, 289C and 299C.Models 277C, 287C and 297C have the old style rubber undercarriage. Not sure about the new style undercarriage ,but some of the old style machines had boggied bottom rollers which do ride alot better than the fixed bottom rollers.
Sincerely, Dirt
/ Cat 257b tracked skidsteer #8
Caterpiller MTL's have the ASV undercarriage, and the Caterpiller CTL have the new steel undercarriage, same machine above just different below
The new steel undercarriage is built by the same Korean company that builds them for deere
/ Cat 257b tracked skidsteer #9
every other company besides Caterpiller and ASV are steel
/ Cat 257b tracked skidsteer #10
Sincerely, Dirt
Son of a gun. guess i am all mixed up on this. i thought virtually all cat tracked skidsteer loaders new and old ran on asv components for a long time now.
sounds like i better stick to tractors. thanks guys for clarifying that.
Theo
/ Cat 257b tracked skidsteer #11
I have owned a Bobcat 763, a Cat 257, and now a John Deere CT332. I would highly recommend the John Deere rubber tracked compact loaders and would say you should really avoid the Cat/ASV undercarriage unless you don't care about cost. Another thing to pay attention to is the fact that the John Deere tracked loaders are capable of lifting more weight and have a lower center of gravity and are thus much more stable. If you want something that is reliable, powerful, and stable I'd say go for the deeres. The Cats have great controls and very fancy cabs but are in my experience much more expensive to operate. I traded in my 257 with around 700 hours and the tracks really needed to be replaced. My Deere CT 332 has around 500 hours on it now and the tracks look almost brand new. Furthermore, the Deere tracks are made by bridgestone, not ASV, so it is easier to find cheaper replacements as they are more universal parts.
/ Cat 257b tracked skidsteer #12
I am looking at a used 2008 JD CT 332 to replace a Bobcat 863. Any inherent problems with it?
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
2015 Nisan Altima S Sedan (A61574)
2015 Nisan Altima...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
2022 EZ-GO ELITE...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
JOHN DEERE 8 SHANK CHISEL PLOW (A63291)
JOHN DEERE 8 SHANK...
