eastern red cedar posts for pole barn/shed?
/ eastern red cedar posts for pole barn/shed? #1
kossetx
TX
NH TC 40 A, AC 5020
Guys, I've never done this before but I have a lot of building experience and I'm a wood shop teacher in my real life. I want to build a 3 sided, flat roofed pole barn to house my tractors. They've been sitting around outside for too long. I'm thinking 20X30 or 20X40 with a 10' sloping to 8' roof would keep most of the equipment I own.
It's going to be housed in the woods for 3 reasons. 1. I don't really want to see it. It is going to be tin covered posts with maybe a crushed limestone or dirt floor. Not the most aesthetic of structures. 2. for security, out of site, out of mind. 3. the surounding oaks will deflect a lot of wind shear.
Around here folks use a lot of ERC to build fences and gates and such, but I don't know if anyone has used it for a building. I have a multitude of 6-8" perfectly strait, not very many knots(they grew close together) ERC trees that will yield at least 20' posts. These particular trees also are fairly uniform in diameter from top to bottom due to their close growth habit but without measuring i'd say there would be some variance, maybe 1" in 10'.
My questions are has anybody ever used ERC for pole barn posts? I have a fence that is 20 years old made from untreated ERC, but it's not a barn and I understand that. If I treat the bottom 2 feet of each post I think I'd get 15-20 years out of them, but is the troubles I forsee will come from the diameter differences in the logs be worth the 400-500.00 treated lumber would probably cost me. The money figure is a guess. Anyone ever do anything like this?
TIA for any replies. Mark
/ eastern red cedar posts for pole barn/shed? #2
We use the heck out of them here for building, matter of fact my entire house will be built out of ERC logs. I would say 15-20 years if you stick them in the ground is about right, but you could always dig some mini footers and set the poles on top of concrete. Then they would last hundred or more years. I did pier mini footers for my last log home. We just took a shovel & dug a 3' round hole that was bowl shaped & about 2' deep. Filled it with crete & sat the piers for the house on top.
If you are worried about wind, sink 'em in the ground....
RD
Wow, Thanks for the quick replies.
RD, how do you attach the posts to the footers. Angle?
Dan, I don't think they're worth the cost and effort to remove and transport vs. cost recieved. ERC is plentiful here and they're down in the deep woods.
I guess some things I should add. The area recieves 37" ARF and the soil is thin sandy loam with a red clay subsoil.
/ eastern red cedar posts for pole barn/shed? #6
I cut mine off the place in Smithville and built a 18 x 20 shed using them -- concreted 'em in post holes -- framed up around 'em -- used corrugated tin for the whole thing. I built it in 1984 ....it's still there and poles are fine. I picked the best ones I could - but they aren't dead on straight so -- I wrapped the poles with the 2 x 6's at ground level and at 8' ... then plumbed and squared off the 2 x 6's before setting the concrete, and let the poles end up however. Consequently the poles aren't plumb -- but the sides of the shed are.
/ eastern red cedar posts for pole barn/shed? #7
If you want to attach, i would do a wide post hole on the four corners(3-4' deep) then stick a 2-3' piece of galv strap in the crete leaving enough to attach it to the side of the pole. For the poles between the corners, i would just set them on top. A shed that size is going to be really heavy so it would take alot of wind comming from the open side to lift it, so i would think corner attachments would be sufficient.
You could also just treat then set them all in post holes, backfilling with gravel. It is the moisture that will get them over the years & gravel helps a ton.
You can really over build & spend more time/$, but if it is just a simple shed, i would keep it simple. Besides, i'll be lucky to be around in 20 years to replace those poles.....:D
RD
/ eastern red cedar posts for pole barn/shed? #8
i agree with motorseven. when i was setting posts , i was told never to use concrete since concrete acts like a bag to hold water and cause problems. good drainage around post is the key and ERC could last longer then 10-25 yrs.
/ eastern red cedar posts for pole barn/shed? #9
I'm building a shed (29ga metal sides and roof) for my haying equipment now. It's pole frame, 20x28 ft (two 14x20 bays), 10 ft roof height sloping to 9 ft. Using eleven 4x6x10ft P.T. posts (3 rows in 3-3-5 post configuration, cost $10.43 ea from Home Depot).
Using a $12 Simpson post base and $15 worth of concrete redi-mix for each post, so each post cost about $37 for materials. No worries about posts rotting in the ground.
/ eastern red cedar posts for pole barn/shed? #10
All of the sheds for my livestock were built using ERC for the posts. They are squared up using PT 2x4 and covered with tin. Some were built nine years ago, no problems yet.
Lots of good tips given here. Go for it. Homegrown posts will always cost less than store bought.:rolleyes:
I agree, Thanks for the good info here. I'll probably go with erc. Now I'm wishing I would have cut those posts in years past like I thought of doing.
Another question for you all. Would 2X6 be sufficient for 10' bays or should I go to 2X8, or larger? My bigger tractor is a little over 6' wide and sooner or later I'll have a 70+HP one so I figure 10' is mininum to keep from constantly hitting the posts.
/ eastern red cedar posts for pole barn/shed? #12
If you do 10' bays and don't put much weight on the roof - you might be able to get away with 2 x 6's. I used 10' spacing on my posts then used free 2 x 6's but I put 1 on each side of the post on the shed side that is supporting the roof. On the sides I have 3 horiz 2x6 runs holding the siding. HOWEVER if I did it again -- I'd probably go to 2x8 for the top plate. The 2x6's are still doing fine -- but they were free which is why I used 'em. I'd have to look at them to see if they are sagging a little .... but after 24 years - I'm sagging some too since then.
/ eastern red cedar posts for pole barn/shed? #13
My bays span 14 ft and the rafters span about 10 ft. So I use doubled 2x12 (= 4x12) nail lam beams to span the 14ft bays. I could have gotten by with 4x10 beams but I prefer to overbuild here since this is the weakest part of the structure. There are 25 4x4 knee braces to help tie the posts to the beams and to stiffen the structure. Right now the wind is blowing steady 20-25 mph with 40 mph gusts. I'm installing some of the knee braces today. It's getting a little dicy on my 8ft ladder. Two more braces to go and I'll quit for the day.
/ eastern red cedar posts for pole barn/shed? #14
One farm I worked on had several hay barns that were built in the 1950's using ERC posts and they are all still standing tall. The metal roofs are a little rusty but the posts are fine. I don't think you even need to go to the expense of treating the bottom of the post. The cedar has its own preservative.
Rick
/ eastern red cedar posts for pole barn/shed? #15
I built this gazebo from tamarack logs and scrounged building materials four years ago, it took 5X longer than anticipated due largely to the "natural" logs; nothing can be plumbed or squared :rolleyes: I am a carpenter by trade and it just drove me nuts...... I would never go that route again but for aesthetic reasons. 500.00 sounds cheap to save all that grief.
/ eastern red cedar posts for pole barn/shed? #16
Hey Davitk, by the looks of your gazebo you have clearly demonstrated your carpentry skills in overcoming the challenges presented by the tamarack logs. Good work and a nice looking project that will surely provide you and your family years of enjoyment.
There you go Kossetx, see what you can do with natural logs.
Davitk, Very nice indeed! You understand what I was saying about square, and I'm not as good a carpenter as you.
I've decided to use the native post and build I'm gouing to build smaller the first time. 20X24 or 20X30. I can always add on or build another later.
Thanks for those pics and thanks to all who replied.
/ eastern red cedar posts for pole barn/shed? #19
its not so much the water problem .... the lime in the concrete promotes wood rot
/ eastern red cedar posts for pole barn/shed? #20
Well, you could take a page from those old timberframe/post-and-beam guys. They eventually figured out that scribing and hand-fitting to match the sizes and angles of each axe-hewn log took too long and too much heavy lifting, so they started cutting all the logs back to a single set of simple known dimensions (usually to just fit their smallest log)--but only at the joints. ;)
You could do something similar by deliberately setting the posts a bit too far out and then cutting in seats for girts etc. with a chainsaw or sawzall until it all lined up right on your desired dimension...
2007 JOHN DEERE 120C EXAVATOR (A65056)
2007 JOHN DEERE...
2018 Hitachi ZX300LC-6N Hydraulic Excavator (A66734)
2018 Hitachi...
2012 BRENNER TANK PUP TRAILER (A67714)
2012 BRENNER TANK...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2014 KENWORTH T800 TRI-AXLE (A67714)
2014 KENWORTH T800...
2010 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2010 INTERNATIONAL...
