Trailer question
   / Trailer question #31
Not to criticize any of the creative ways some are hauling their tractors but many of them would not pass a DOT stop. To be totally in compliance when hauling a TLB both the loader and backhoe bucket must rest on the bed of the trailer and have their own chain, not strap, restraint. The tractor itself must be chained to four points.
DOT focuses on commercial users for the most part and let a lot of us home owners get a way with some violations. They do have the right to check and ticket anyone hauling a trailer and they do here at times. If you want to follow the letter of the law there is no way you can haul a BX on a 10 trailer and meet the standards.
MarkV
Got a link to those regs? Straps are used on everything down here. How about a 100' prop for a wind turbine? Got Straps?? :D
   / Trailer question #32
sometimes that funny feeling can be eliminated with the weight distrubuting bars along with sway bar as well. try it. its helps with better handling as well.:)
   / Trailer question #35
Concur, Mr. Radioman...I run a WD hitch and love it.
I think a Ford exp would not be the #1 choice for a tow vehicle, being a little shorter wheelbase and all. the new ones all have a longer wheelbase I think, not sure when the switch over was, before or after 2005?
The standard is 119" and the EL is 131". For comparision the Suburban is 130" and my F250 SD is 172"(CC, LB). 158" for a CC SB. I think I have the numbers right..
   / Trailer question #36
It's a Ford Expedition...not the Ford EXP, a 1980's 2-door derivative of the Ford Escort. That car didn't have towing CAPACITY, it actually moved better WHEN TOWED.
Kidding.
I totally agree that the short wheelbase Expedition is not the perfect tow vehicle. The new Expeditions are given a CHOICE of long vs. short wheelbase, a'la the Suburban vs. Tahoe. It isn't a "newer/older" thing. It doesn't do too bad, though. Not bad at all.
Interesting fact, though, is that I have to purchase a 3/4 ton Suburban with tow package to exceed the 9,000# tow capacity of my Expedition. The 1/2 ton models top out at 8,100# capacity.
Another interesting fact is that the Expedition EL (longer version) has a LOWER towing capacity than the "short" version (mine). Presumably because for an identical frame and powertrain system, there is more GVWR devoted to the VEHICLE than the trailer.
Didn't see myself towing a 10,000# trailer when I bought my Expedition. Suffice it to say that my next vehicle, if I bought right now, would be either a 3/4 ton Suburban 4x4 or some type of 3/4 or 1 ton pickup. I do tote the family around quite a bit, so I'd like to stick with some type of jumbo SUV.
   / Trailer question #38
Rob I don't have a file on the regs and am to lazy to go looking for it. This is information I got from one of the DOT guys in the area. We have a good number of them around here because of all the pulp wood haulers in the area. Those guys push the limits often so are looked at closely.
From what I was told straps are fine for a load that does not have the possibility of suspension movement, which includes rubber tires. Everything else requires chains.
Also I am not trying to be the safety cop. I haul so little for such short distances that when I do I don't meet the regs myself. It just isn't worth the expense of a lager trailer for as little as I use it. Just wanted to point out to new users that even if you meet the weight restrictions of the trailer you are not necessarily legal. Most rural areas seem to be pretty lenient for non commercial users but I am sure some are not.
MarkV
   / Trailer question #39
...possibility of suspension movement...
I can't say exactly what the regulations are, but I personally don't think it is possible to safely transport one of these tractors for any distance with straps.
I carried mine to NC a couple of years ago, before I got the BH. It was in my old 3,500# 5'x10'. That trip was my last with that trailer...I didn't carry my tractor anywhere else until I got my new rig.
My point: I tied my tractor down with 2 extremely heavy duty (6,000# or something)ratchet straps and two smaller (1,500#) straps. By the time I made it to NC (under 4 hours), all but one of the straps were cut. I made certain they weren't resting on anything sharp, but even the rounded corners of my BoxBlade chewed through the strap...it wasn't even tight to the metal, just firmly resting against it as the strap was holding elsewhere.
If you can tie up a tractor and have the nylon strap touch ABSOLUTELY NOTHING (the only thing touching any type of wood or metal are the metal hooks), then I would think you're safe. Other than that, I think chains are the only way to safely transport.
Personal experience.
I think those blades are safe because there is nothing rubbing against the strap. That's the same for a great many things that are towed with straps...bricks (they use wood or cardboard bumpers), wood (same), and most any type of immobile object.
I have never seen any type of commercial construction equipment (which my job keeps me around pleanty) moved with anything but G70 chains. There's a reason for that.
   / Trailer question #40
Kidding.
Hey man my first tow vehicle was a 1980 Toyota Tercel!! I made a 4x7 big wheel trailer out of 1.5"x1/8" angle. Ply deck. I could clean an jerk it over my head!!(I was a bit younger and it was attached to the Tercel)). It only hauled my Yamaha YZ250J. 220# bike give or take.
I think the tow rating has to do with simple weight. If I recall the F250 super duty with the gasser v8 (remember from 1999 specs) was rated to tow more than the diesel. The difference was how much more the diesel engine weighed. I have no idea how they rate them now.
Rob
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
